Old 01-28-2009, 10:03 AM   #1
mcernik
mcernik's Avatar
Drives: Rally Yellow SS/RS VIN # 3931
Telescopic Steering Column?
I thought I saw on like the ordering workbook or something that the Camaro has a telescopic steering column.
For those of you that have sat in one of the "production" models at the auto shows do you have any details and/or pics of how it works?
mcernik is offline   Reply With Quote
Old 01-28-2009, 10:07 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I believe you are correct - it will have a manual tilt and telescoping column. I believe there will be a level that will allow one to lock and unlock the column to allow adjustments.
'20 ZL1 Black "Fury"
Old 01-28-2009, 10:16 AM   #3
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
There's a lever on the left side of the steering column. Push the lever down, adjust the wheel to your liking, then push the lever back into place to lock the position.
2023 GMC Canyon Elevation
Old 01-28-2009, 10:16 AM   #4
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
Yep, steering wheel has full range of movements.
http://www.gm.ca/static/english/vehi...tml?fdl=camaro
after link go to Cars>Camaro>multimedia>watch the sixth video!!!
After you watch that video watch all of the rest
Comments on the video go to this thread
http://www.camaro5.com/forums/showth...hlight=milford
Old 01-28-2009, 11:08 AM   #5
Supermans
Camaro & Stang Enthusiast
Supermans's Avatar
Drives: 2011 Mustang 5.0 in Kona Blue
I've had nothing but trouble with telescoping steering wheels.. Wish it was a normal tilt only one..
Bought my Camaro from Eric Hall(817) 421-7266
Supermans is offline   Reply With Quote
Old 01-28-2009, 11:17 AM   #6
Chevyrocker
Weekend Rockstar
Drives: Depends on the day...
The only problem with that is that some people (really tall or super short) really benefit from the telescopic motion.
Chevyrocker is offline   Reply With Quote
Old 01-28-2009, 11:25 AM   #7
ZYAL8R
ZYAL8R's Avatar
Drives: 2010 SS/RS
This is news to me and have never seen a telescoping steering wheel. I am intrigued by it to say the least, but not sure if I would like it. Does any current vehicles have this?
Just missed the link above, will have to take a look.
2010 Chevy Camaro Black on Black!
84' Chevy S-10
91' Chevy S-10 Ext. Cab
90' GMC Sierra Reg. Cab 350 V8
2003 GMC Sierra HD 4x4 Crew 6.0
2005 GMC Yukon 5.3
2008 GMC Ext. Cab 4x4 5.3
2008 GMC Yukon SLT 5.3
This truck man is about to go for something a little more sporty.
ZYAL8R is offline   Reply With Quote
Old 01-28-2009, 11:29 AM   #8
kmdrum79
Drives: 2018 Audi SQ5
My 2006 G6 GTP does.
kmdrum79 is offline   Reply With Quote
Old 01-28-2009, 11:42 AM   #9
Supermans
Supermans's Avatar
I actually had my telescoping steering column become loose in my Pontiac G6 and I had to have it towed to the factory since it was unsafe to drive.. I don;t know how common this problem is so I may be the only one..
On a side note, if the Camaro wheel will be the same as the Vette's where it will have soft stops, however if it does, you might have to do this if the seat control module needs replacement or is reset. Note I didn't have the problem below however I just did a quick search. There aren't any forums dedicated to G6 owners so I'm sure it will be hard to find others with problems or story's about telescoping steering wheels and their G6's..
http://forums.corvetteforum.com/c5-g...wont-move.html
Telescoping Steering Column Calibration
Telescoping Soft Stops
After replacement of the seat control module, it is necessary to program the telescoping soft stops. Each soft stop is a programmable end of travel that is set approximately 1.3 cm (0.5 inch) from the mechanical end of travel. The steering column has a soft stop set at each end of the telescoping in/out movement. The system uses soft stops to prevent wear on the system by ensuring that the steering column movement stops before it reaches its mechanical end of travel in any direction. The soft stops are initially programmed at the factory. The stop positions may be reprogrammed, which is necessary any time the seat control module is replaced, as described in the following procedure.
Telescoping Soft Stop Programming Procedure
1] Turn ignition to ON, leaving the engine off.
2] To set the telescoping in soft stop, press the telescoping COLUMN IN switch at least eight times or until the column moves.
3] Press the telescoping COLUMN IN switch and hold the switch until the column travels all the way in, and continue to hold the switch about a second after motion stops at the mechanical end of travel. The soft stop for the column in position is now set. The seat control module automatically goes back to the normal mode of operation.
4] Repeat steps 2 and 3, using the COLUMN OUT switch, to set the column out position soft stop
Old 01-28-2009, 11:47 AM   #10
FenwickHockey65
Yup. My '07 Chevy Malibu LS has it.
Old 01-28-2009, 01:32 PM   #11
kalel
kalel's Avatar
Drives: 2018 2SS 1LE
I am thrilled about having this feature. I can't find a comfortable position in most cars without a telescoping steering wheel. In fact I wouldn't have ordered this car without it.
kalel is offline   Reply With Quote
Old 01-28-2009, 03:07 PM   #12
fastball
Banned
Drives: 2017 Camaro 2SS 6MT
The steering column on the Camaro will be a mechanical, manually operated lever only, it will not be power operated, and there will not be an option for power operated column.
For those who are unfamiliar with tilt/telescopic steering columns, GM has (finally, after all these years) adopted the Japanese and European model of free moving rake and scope. Most if not all of you are familiar with the old GM "tilt wheel" that had 6 pre-set notches that you had to choose, and no scope (although Cadillacs did have a telescopic wheel in the 1980's untill they had to start putting airbags in, then their old telescopic wheel design was impossible to incorporate to a wheel with an airbag fitted hub).
The benefits of a free moving rake and scope is that you can have the wheel and column adjust to any driver of any stature. Unlike the old Cadillac telescopic feature, the entire column scopes in and out, moving with it the ignition hole and all the column mounted controls and functions.
Japanese and European manufacturers have been using this design since the 70's, and it's one of the reasons they always got high marks for interior ergonomics.
GM is using it more and more in the last few years, and will fit all of their cars with it now. It's a very good design.
fastball is offline   Reply With Quote
Old 01-28-2009, 04:48 PM   #13
camaro5's Avatar
Drives: X-15 Velocipede
Nice site c_c. Never saw it before.
There you go, manual.
I spent a lot of money on a Corvette to get the 3LT package to include the telescoping wheel.
Difference between OK driving position, and PERFECT driving position.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 01-28-2009, 05:33 PM   #14
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
You are welcome!
Steering Feel stovt001 5th Gen Camaro SS LS LT General Discussions 15 01-25-2009 04:14 PM
Telescoping steering colunm? kanys 5th Gen Camaro SS LS LT General Discussions 11 09-27-2008 08:57 PM
Help installing a wood type steering wheel MontyMax 1st & 2nd Generation Camaros 0 07-19-2008 02:18 PM
Power Steering - hydraulic or electronic steering? balonywolf 5th Gen Camaro SS LS LT General Discussions 20 02-29-2008 12:01 AM
Steering Wheel Radio Controls Bart 5th Gen Camaro SS LS LT General Discussions 19 02-28-2007 01:46 PM
