Old 01-16-2011, 08:57 AM   #1
advfire
advfire's Avatar
Drives: 2010 SS Black
Richmond 4.10 gears in the rear
Wanted to ask the board, It would appear that about 5 months ago Richmond was having a rash of 4.10 failures with this unit. I too had a failure of this rear but my condition was more recent seeing that I purchased the unit 5 months ago but only found the time to install it last week. My failure was within less then 500 miles of being installed...
Between all the members out there who have either changed to new 4.10 Richmond's with success or with failure. Has there been failures in the last 2 months?
I want to see if I get a replacement set would I suffer the same fate or do you think the issue was corrected by Richmond with newer units.
Please give me your thoughts... Reading all the Blogs I have found 17 cases on the board from different members who state failures, ( myself included ) but they all had there issues around July of 2010, +/- ( same time i bought mine )
2SS- M6 - 849 RWHP, 757 RWTQ - YSI -Supercharger - Comp Cams Stage 3 Blower Cam -54-471-11 - (In-239/624 - Ex 255/624)
MTI - CAI - Meth Injection Systems using 50/50 mix - Kooks 1 7/8" Headers with 3" catted X-Pipe - Kooks muflers to tips - LSR Short Throw Shifter -
NGK TR6 Spark Plugs - 160 degree thermostat - LSR Sway Bars (Front & Rear) - BMR Subframe Connectors bolt-on - DSS - lingenfelter 9" w/ 4.10P - PFADT coilover front/back - BMR Spherical Toe rods / Trailing arms - Posi lock -
advfire is offline   Reply With Quote
Old 01-16-2011, 09:01 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
We had two customers suffer failures back during the time frame you mentioned (July-August) and since then have not heard about any more until yours.
Old 01-16-2011, 09:19 AM   #3
advfire
advfire's Avatar
I'm wondering if the Failure was a certain batch, it would be great to see if there was any install dates of build codes on the Richmond box that we could identify
Old 01-16-2011, 10:51 AM   #4
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2013 Camaro ZL1 M6
With 638 rwhp I'm not surprised it broke. Do these gears break with stock cars also? If so, than Richmond sucks and should stop making them.
1Camaro2SS is offline   Reply With Quote
Old 01-16-2011, 12:33 PM   #5
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
I've had mine on since May and have put almost 11K miles on them since w/ no issues. No drag racing pulls here, but plenty of hard accelleration runs.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 01-16-2011, 12:34 PM   #6
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
It seems there must have been a bad batch of gears with bad steel. Richmond has replaced all the broken gears I have read about or know about. I have one of the first sets I got in a group buy from a seller on this forum, and they are still holding up. I can't stress enough having a experienced installer put them in and a heat cycle break in period. Then change the oil again. With as much power as you have, maybe the 3.73's might be better.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 01-16-2011, 02:27 PM   #7
advfire
advfire's Avatar
During the break in the 4.10 made the car so smooth. The take off was very light compared to the stock 3.45, which with the power I was pushing made it want to jump. I liked how they made the car run and during Friday night run at the track I went from a 126 top MPH in the 1/4 to a 133 top MPH in the 1/4 ( major difference ).
I would like to use the Richmond again and I am starting to think they had a bad run during that time...
I wanted to hear if anyone had installed in the last 4 months after august.
Old 01-16-2011, 05:01 PM   #8
1Camaro2SS
1Camaro2SS's Avatar
i was going to have my chevy dealer install a 3.73 richmond gear in my car but decided to wait for a decent quality gear to come out. who knows, gm may make one soon.
Old 01-16-2011, 05:06 PM   #9
Apex Motorsports
The Richmond 3.73s have not suffered a single failure that I am aware of. I can also set you up with Lingenfelter 3.70s for the same money.
Old 01-16-2011, 05:11 PM   #10
1Camaro2SS
1Camaro2SS's Avatar
Originally Posted by Apex Chase View Post
The Richmond 3.73s have not suffered a single failure that I am aware of. I can also set you up with Lingenfelter 3.70s.
Really? Well that is encouraging, I was under the impression that all richmond gears had issues on the new camaro. I will need to rethink this over. Thanks for the info apex.
Old 01-16-2011, 05:14 PM   #11
Apex Motorsports
No problem. There was a rash of 4.10 failures back during the summer but there have not been any since, until this instance. The 4.10s and 3.73s are designed differently and the 3.73s have had zero issues. Richmond has always been known for the strength of their gears which is part of why people were so dumbfounded.
Old 01-16-2011, 05:44 PM   #12
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
could it just be that there are no reports of 4.10 failures lately because it's winter and not nearly as many people on this forum are driving their cars right now, let alone aggressively driving them.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 01-16-2011, 06:01 PM   #13
Apex Motorsports
The failures all came during a pretty tight time frame and seemed to end prior to the cold weather setting in. Richmond made some changes including their recommendations for installation and since then the failures have not been occurring.
Old 01-16-2011, 08:04 PM   #14
Heliwrench
Heliwrench's Avatar
Drives: 2010 Black 1SS
There was one reported Richmond 3.73 failure but no details were given.. This is the internet...
As for the Lingenfelter 3.70's, they are actually made by AAM, the same company that makes the original gears in the car. Haven't heard of one fail yet but I don't think many are running them as they are a little more costly.
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune
Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings
Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links
Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings
Exterior:: Shine by Adam's.
...and plenty more
Heliwrench is offline   Reply With Quote
Richmond 4.33 Rear End Gears Available At Apex Motorsports!!! Apex Motorsports Transmission / Driveline 84 05-13-2011 03:26 PM
LSR Performance Intake, ATAK Exhaust, 4.10 Gears, and Torq Tune. Good Combo? Gnarlygianni Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 01-06-2011 07:42 AM
WTB Camaro rear diff with 3.45 gears Sol-leks Local Marketplace 6 12-27-2010 04:39 PM
3.45 M6 SS rear gears AG454 Local Marketplace 1 07-10-2010 10:17 AM
