2G1FB1EV3A9121989
Removing cluster gauge pod
I just installed my new cluster gauge pod that I got from The Carbon Fiber Specialists and thought maybe someone else would like to know how to remove it to put the new one in. First you need to have a screw driver or something to pry the tabs on the frame.The left and right have the same clips so I just took pictures of the right side already taken off. You can see where you have to add a little pressure to undo the clips.
![]() Here is the back to get an idea of where you need to concentrate on where to pry. ![]() Once you have the cluster gauge pod loose there is still a hard plastic and rubber piece that is attached to the top cover of the steering wheel. Here is the piece still attached to the pod. ![]() The bottom soft rubber part is what you will have to pry loose from the steering wheel cover but it comes out real easy just be patient and take your time. Here is what it is attached to. Once you get the soft rubber tabs pulled away from the steering wheel cover you can pull it out. Now you need to get the hard plastic off the cluster gauge pod. I took pliers and squeezed the clips and slide if off the pod. ![]() Which you will end up with this:: To install the new one is pretty much just putting it back together. here is the finished product. ![]() ![]() ![]() Please be kind this is my first DIY so I hope it does not confuse anyone. Last edited by dragom; 01-18-2011 at 08:30 PM. |
![]() Drives: 2009 Dodge "Cuda", 2010 Camaro Join Date: Nov 2010
Looks good, more pic's of the finished results please.
Drives: 2SS Join Date: Jun 2011
thanks
![]() Drives: Camaro SS Custom Join Date: Dec 2011
This was a great help as I intend to do the same with my SS. Thanks
![]() Drives: 2011 Synergy green 2LT RS Join Date: Aug 2012
how did you do the 2 tone?
| gauge cluster help??? | Camaro10LT | 5th Gen Camaro SS LS LT General Discussions | 4 | 12-27-2010 03:08 PM |
| Custom Painted Inferno Orange 4-Pack Gauge Cluster For Sale | Not Paid 4 | Interior Parts & Accessories | 21 | 11-09-2010 03:56 PM |
