View Poll Results: ARE YOU EXPERIENCING S/S M6 TRANSMISSION PROBLEMS
GRINDING 63 65.63%
HARD TO SHIFT 49 51.04%
SOMETHING ELSE explain in post 1 1.04%
Multiple Choice Poll. Voters: 96. You may not vote on this poll
Old 01-20-2011, 03:54 PM   #1
dcoates
dcoates's Avatar
Drives: 2010 CAMARO 2SS/RS
Tremec 6060 2nd gear troubles????
If you have had trouble with your M6 transmission, let's here you.
there are a few threads here on some of the problems.
I would like to hear what you encountered, and at what mileage.
my car is at the dealership getting a new transmission because of 2nd gear grinding, and i mentioned to them the website and all the complaints about the M6.
They have been in contact with GM customer support, and are curious how many are experiencing problems and the nature of the problems.
so lets hear it, and maybe they will read em and do something about it in a TSB.
2010 CAMARO 2SS/RS, M6, Yellow with Rally stripes, Borla factory exhaust....426HP YEE HAAHH...
dcoates is offline   Reply With Quote
Old 01-20-2011, 04:37 PM   #2
ssmike
BL1ZZRD
ssmike's Avatar
Voted! Mostly notchy 2nd and 3rd but also missed shifts at high rpms, like hitting a brick wall. Doesn't happen every time but occassionally. Definatly a syncro type problem. I never had any of the clutch issues like sticking or high pedal engagement like some others had.
The notchy shifting gets better on hot summer days when the trans is warmed up. Also is most noticable at lower and higher rpm's, works the best at around 4,000 rpm shifts. Some days are better than others! Definatly worse when cold!
I had it in 3 times since it was new (8,000 miles as of now) and always "no trouble found, or could not duplicate". I got a call from GM after e-mailing them and it looks like they are going to replace the transmission. Still waiting on call from the dealership that the replacement trans is in, hopefully by next week!
Old 01-20-2011, 04:57 PM   #3
dcoates
dcoates's Avatar
Thats kinda what they did with me.
At first they were going to repair mine, then said it would be 2 months for parts and special tools.
After calling GM they said replace the Trans. and check the clutch and plate. they also checked out bearing and slave.
My car only had 2900 miles and very little hard driving.
They said they knew of the problem and are doing their best to get it solved...Whatever that means?
I will definately report back here after i get her back, and try some spirited shifting.
Old 01-20-2011, 05:32 PM   #4
unix748
unix748's Avatar
Drives: Victory Red 2SS/RS
My 2ss has 2400 miles on it and grinds from 2nd to 3rd occasionally. I took it in and they couldn't "replicate". When I bring her out in the spring I'm taking it back in, it really irritates me. It doesn't happen all the time but enough to be annoying.
"I choose the road less traveled... I can drive faster."
unix748 is offline   Reply With Quote
Old 01-20-2011, 05:34 PM   #5
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
No problems here to date (knock on wood), but that wasn't a choice in your poll.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 01-20-2011, 05:49 PM   #6
dcoates
dcoates's Avatar
No problems with the transmission, excellent!
Old 01-20-2011, 06:00 PM   #7
MiSTER
Drives: 2010 2SS CGM Camaro, 1988 6.6L IROC
My issue is pretty much having to muscle the 1-2 and 2-3 shift at high RPM. Occasional grind with the 1-2 shift.
MiSTER is offline   Reply With Quote
Old 01-21-2011, 03:10 PM   #8
dcoates
dcoates's Avatar
Anyone else having problems?
gotta be more than 7?
Old 01-21-2011, 06:49 PM   #9
pdesanctis
i like to go fast
Drives: 2011 SS
Very hard to shift. I already went to my dealer and received the B.S. response, operating as it should.
My gear's don't grind, but sometimes at the track under High RPM's (5000-6500) it won't go into 3rd gear. Very annoying.
1st & 2nd gear are extremely notchy, which is why I assume it is so hard to shift. Going from 2nd-3rd is notchy some shifts and some times a little bit smoother.
pdesanctis is offline   Reply With Quote
Old 01-24-2011, 05:56 PM   #10
CyberPredator
50 Shades of Prey
Drives: TT/SS
1st to second grind when speed shifting but all the other gears are fine
Futral Motorsports built and tuned
CyberPredator is offline   Reply With Quote
Old 01-24-2011, 07:02 PM   #11
togtaker
togtaker
Drives: 2011 2ss/rs
I had the grinding. GM has a redesigned carbon fibre syncro to fix the problem. It started when the weather got cold, at first only did it when cold, then it started doing it when warmed up, maybe around 5k miles. Mine seems to be fixed now with the new style syncros.
togtaker is offline   Reply With Quote
Old 02-04-2011, 09:50 AM   #12
dcoates
dcoates's Avatar
Got my car back last week, replaced transmission for the 2nd-gear grind thing, better than ever with the shifting.
still notchy, but we live with that don't we?!
Old 02-04-2011, 04:52 PM   #13
Chemical Camaro
Chemical Camaro's Avatar
Drives: 2011 CGM Camaro 2SS/RS
I've posted in another thread about this too. Add me to the list. 7k miles, 1-2 grinding, notchy when accelerating under any condition (hard and soft accels). 1-2 is not notchy when parked and engine running or when the engine is off. It doesn't do it all the time but the cold seems to make the grinding happen more often.
I haven't taken it to the dealer yet. I'm waiting a little while until the problem becomes a little more predictable or until someone confirms a document has been published which outlines the problem. I've had the run around from dealerships before and would rather not waste my breath.
Karl
2011 Camaro 2SS/RS CGM with ground effects package
Ordered 6/8/2010 from Buckalew Chevrolet in Conroe, TX
2500 status: 6/22/2010
3400 status: 6/29/2010
3800 status: 7/20/2010
Delivered: 8/2/2010
"What does a scanner see? Into the head? Down into the heart? Does it see into me, into us? Clearly or darkly? I hope it sees clearly..."
Chemical Camaro is offline   Reply With Quote
Old 02-04-2011, 05:05 PM   #14
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I've had my clutch stick to the floor on hard launches and it seems like I'm constantly grinding going from 1st to 2nd during high rev shifts.
I've been told by the dealer and a GM rep that the clutch issue is "normal". OH WOW MAN!
My SS Camaro's tranny sounds weird in 1st and 2nd gear. RyanSSaddict V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 2 03-07-2011 03:08 PM
Clarification Please! L99 and 1st gear Ace 5th Gen Camaro SS LS LT General Discussions 6 05-22-2009 04:34 AM
Will the A6 start off in 2nd gear like the vette??? TomServo 5th Gen Camaro SS LS LT General Discussions 9 04-10-2009 10:41 AM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 10:44 PM
Does the Tremec 6060 already have problems? linkwpc V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 7 07-30-2008 10:41 AM
