Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Chevy Camaro vs...
Old 01-21-2011, 02:45 PM   #1
kickasswelch69
Future Underwater Welder
kickasswelch69's Avatar
Drives: 1991 Mazda B2200
Question 2011 Camaro SS Vs 1969 Camaro Zl1 STOCK
OK. Ive been wondering how both of these camaros would fare against each other. The 1969 Camaro ZL1 puts out 550 horses stock. The 2011 puts out 426.
Specs for 1969 ZL1
The 1969 Chevrolet Camaro ZL1Specifications
Wheelbase, inches: 108.1
Weight, lbs: 3,300
Number built: 69
Base price: $7,200
Standard Engine
Type: ohv V-8
Displacement, cid: 427
Fuel system: 1 x 4bbl.
Compression ratio: 12.0:1
Horsepower @ rpm: 430 @ 5200
Torque @ rpm: 450 @ 4400
Representative Performance
0-60 mph, sec: 5.3
1/4 mile, sec. @ mph: 13.16 @ 110
Specs for 2011 Camaro
SS 2SS Standard Engine
Gas V8 Displacement (liters/ cu in.)
6.2L/376 Transmission
6 Manual Horsepower @ RPM
426 @ 5900 Torque @ RPM
420 @ 4600
Me, i think a stock ZL1 would trump a 2011 Camaro anyday of the week...
COPO9560!!
So let the Lords light in us all shine bright like a fire, and do His will for others. For this is what He did for Us.
My future mods: http://www.camaro5.com/forums/showthread.php?t=271793
kickasswelch69 is offline   Reply With Quote
Old 01-21-2011, 05:12 PM   #2
Stewcam
Stewcam's Avatar
Drives: 2010 Camaro SS/RS
if the zl1 has stock tires the SS would probably beat it by a tenth or so based on the results I have seen. With slicks on the zl1, the SS is toast.
Yellow SS/RS
LMR Twisted Slayer 650 RWHP, ARH Headers, Hi-flow cats, Carbon/Organic Twin Disc/Pfadt/BMR/Hurst Shifter/D2forged VS1's
Stewcam is offline   Reply With Quote
Old 01-21-2011, 09:04 PM   #3
assasinator
1 n the head,2 n da chest
assasinator's Avatar
Drives: 2002 cadillac deville
that ZL1 with sae net ratings is 375hp. sae gross is 430.
with headers, aggressive timing, and non-emission compliance its a beast(550hp). do the same thing(bolt ons) to a LS3 and you get nearly the same results IMO.
2011GT E85, Kooks 1-7/8", 3" offroad X, 2-7/8" overaxles, Roush mufflers, CobraJet intake, SCJ monoblade throttle body, drew 4.5" CAI, Boss302S exhaust valve springs, Baby CobraJet exhaust cams. 3.73 gears, lightweight 300A. 455rwhp @7800/410rwtq SAE 5000lb roller dynojet
assasinator is offline   Reply With Quote
Old 01-22-2011, 04:03 PM   #4
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Just looking at the numbers in the first post should tell you somethings not right. If it truly had 430 (let alone 550) and weighed 3300 lbs, it shouldn't be a low 13 second car. But 375, with an extra couple hundred pounds, with skinny little tires and all the other short comings of a car from back then, sure.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 01-25-2011, 11:36 AM   #5
kickasswelch69
Well what about drag radials?
Chevrolet was hoping to get the ZL1 Camaros into the lower class in the National Hot Rod Association (NHRA) and the International Hot Rod Association (IHRA) drag racing, because they knew results at the track was results in the showroom. Chevy under rated the horsepower at 425, but both sanctioning bodies quickly saw through chevrolets facade and re-classed the ZL1 engine into the appropriate class. Word spread fast, the stock ZL1's were churning out nearly 550 horsepower on the dyno.
http://www.classicchevrolets.com/cop...amaro-zl1.html
COPO9560!!
Old 01-26-2011, 01:55 AM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
No, they weren't. Unless you have a very loose definition of the term 'stock' (which was fairly common back then). If you swap heads, the engine still stock. And if you pull off every accessory, the engine is still stock. If you swap the exhaust manifolds for headers (and remove the rest of the exhaust), the engine is still stock. If you retune the carb, the engine is still stock. If you remove the air filter, the engine is still stock. There were other things done too but none of it would be considered to be 'stock' today, but rather 'light mods'. If you were able to go back in time and pull a brand new 427 out of a ZL1 and ran it with the current SAE testing protocols it would have a very hard time cracking the 400 hp mark. I recall hearing that when they switched from gross to net hp ratings (which did away with a lot of the old shenanigans), those engines were making about 375 hp net and the protocols have changed a little since then, but it would still be somewhere around 375 in bone stock condition.
Old 01-26-2011, 01:42 PM   #7
LYCAN
Tattooed K9
LYCAN's Avatar
Drives: E63AMG
Are you talking about a real world race or a "spec sheet" race? My vote would not be on a real 41 year old car. Even my 79 TA is maybe 3/4 of what it used to be.
Regards,
John
'11 2SS Black/Black M6
Prior Project Cars: 96 WS6, 96 Steeda Cobra, 93/74/99/01ZO6 Vettes, Supra Turbo, and BMW M3.
LYCAN is offline   Reply With Quote
Old 01-27-2011, 02:37 PM   #8
kickasswelch69
im talking about a real race.
COPO9560!!
Old 01-27-2011, 04:11 PM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
The 2011 SS will win by default. Nobody in their right mind will race with a stock 1969 ZL1. And even if they did have a stock ZL1, after 40+ years it most certainly won't be running like it did when it was new.
Old 01-27-2011, 04:13 PM   #10
kickasswelch69
your probably right. but what if the engine wasnt original? What about a chevy crate 427?
COPO9560!!
Old 01-27-2011, 08:11 PM   #11
assasinator
bone stock-as delivered to a dealer untouched the 2011 SS would SMOKE a zl1.
im talking 50 state legal smog. which includes EGR, thermactor smog air pump for 69. even the deadly 429 SCJ had all of that stock.
chevrolet part numbers:
Smog pump build date 352-8
Smog pump diverter valve #29297
Smog pump pulley #3932458DA
Smog system hose #3940937 used original and mint
Smog pump hose #3909940 used original and mint
Smog check valves 5361992 x 2 restored and replated
Smog tubes are mint original used with no damage
Smog pump hose clamps are all original and dated 1/69
note the tri power with required smog pump.
note the thermactor manifolds on the exhaust manifold of this 69 nova.
legend is greater than reality for 60 muscle cars compared to today.
IMO the glory days of musclecars was long before the markV bigblock. back when as-delivered power was REAL.
425 hp 409/427 W motors, and 427 ford side oilers. 12 second cars for their day. in very heavy cars. 1962-1965.
Old 01-27-2011, 08:25 PM   #12
assasinator
Sortino also uncovered what was said to be a "one-of-one" dual four-barrel aluminum intake manifold for a Mark II engine from a guy in Michigan. After reviewing cylinder head flow data, Sortino decided to increase the camshaft's profile in order to take advantage of port flow capability. The legendary Junior Johnson (also a member of Super Chevy's Hall of Fame) was said to have "guesstimated" that a stock four-barrel Mk II 427 was capable of 600 horsepower. Sortino's twin, a 750 cfm AFB version with a little more camshaft, dyno'd in at 660 horsepower.
Craigg Clack, here in clarksville is a long time friend of mine. his 62-63 biscaynes have adorned the covers of hotrod and popular hotrodding. he does my machine work for my turbo stuff.
Old 01-27-2011, 10:12 PM   #13
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
http://musclecarfacts.net/1969-camaro.html
The ZL1 didn't do bad in the magazine tests back in the day. I never read the articles but the numbers posted don't look bad. Those were posted on old-school rubber.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 01-28-2011, 03:09 AM   #14
porcupinekiller
porcupinekiller's Avatar
Drives: 2010 GT500
Don't forget the ZL1 won't even run on todays overpriced, crap pump gas. It's pretty tough to get 104
+ octane leaded fuel at the pumps these days. Lol
The performance of todays cars is pretty impressive when you consider this overpriced crap fuel we have these days. If you ran them today stock to stock my money would be on the 2011 SS.
porcupinekiller is offline   Reply With Quote
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 09:35 PM
*/ *\ * FREE SHIPPING ON ALL 2011 CAMARO'S - PREFERRED PRICING FOR EVERYONE * / * \ * CamaroScotty Dealer Camaros for Sale 1 11-06-2010 11:27 PM
Modern Camaro Performance - Lowest Prices Anywhere! PartsTaxi.com Sponsor Announcements / Giveaways / Contests 0 11-03-2010 11:50 AM
