Old 01-21-2011, 07:17 PM   #1
jtzako
Drives: 2010 IBM Camaro SS
Cant get a replacement bulb socketed ???
I'm finding I have a ridiculous problem.. I cannot, for some reason, get a replacement bulb to seat into the passenger side head lamp.
The replacement bulb went in OK on the driver side but it wont twist to lock when I get it notched on the passenger side.
Has anyone else run into this? I can put the stock bulb back in and it goes in and twists to lock without a fuss.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 01-21-2011, 07:22 PM   #2
Alfieboy
Madman
Drives: 2017 1SS
dunno..try swapping bulbs from ds to ps?
Alfieboy is offline   Reply With Quote
Old 01-21-2011, 07:36 PM   #3
jtzako
Finally got it.. I noticed the replacement bulb has a gray rubber ring at the base, and the stock bulb did not.. so I got a mirror so I could see the spot where the bulb goes in and I saw a red rubber ring there.. I pulled that off and the bulb went right in. I guess that extra gasket made it too thick to seat properly. Oddly enough I went back and checked the driver side and the red ring was still there even though the new bulb seated fine.
Old 01-21-2011, 07:46 PM   #4
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Thumbs up You'll dig it. Do it!
It's easy. Just stick it in the hole and SCREW. I always get great results. It's hella fun, too!
Ivas is offline   Reply With Quote
Old 01-21-2011, 09:21 PM   #5
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
same thing happened to me i was there for like 30 mins and some how it finally went in.
(sounds so wrong)
cyberLS is offline   Reply With Quote
Old 01-21-2011, 09:29 PM   #6
the Kolektor
Patiently waiting....
the Kolektor's Avatar
Drives: 2007 Jeep Wrangler Sahara
(sounds so wrong)
Hopefully you don't have that problem too often.
You Know......Sometimes you just can't fix stupid!!!!
the Kolektor is offline   Reply With Quote
Old 01-22-2011, 03:02 PM   #7
Ivas
el Ruco
Talking Dude! Wass up with you?
(sounds so wrong)
What happened? Did ya' fall asleep before you made your entrance?
DIY - 2010-2011 Camaro D1S HID bulb replacement instructions and photos GearHeadPeter Cosmetics and Lighting Modification Discussions 56 02-26-2021 08:16 AM
HID bulb replacement... 2010IBMSS Cosmetics and Lighting Modification Discussions 19 02-08-2011 08:00 AM
daytime running lamps HID bulb replacement topgun1 Cosmetics and Lighting Modification Discussions 5 03-13-2010 11:59 PM
K&N 2010 Replacement Air Filter GmPartsDirect.com V8 Bolt-Ons & Tunes 2 03-09-2010 05:53 AM
Halogen Headlight Bulb Replacement 8ty8 ls1 Cosmetics and Lighting Modification Discussions 1 11-15-2009 12:13 PM
