Old 01-21-2011, 08:15 PM   #1
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
Tow Hook (Finally)!
So I had wanted a tow hook for a while, and since the racing/HPDE season is getting near, I decided to make it happen. I talked to Mitch at racecartowhooks.com and put this on there. I decided for a good look and easy install to put it here. I ended up going all out and having it welded up to the bumper bar. Any questions, send 'em, and if you've got something clever for the rear, I'd like to hear about it!. Here's a couple pics of what I did:
LGM G6X3 cam, LGM headers, Vararam intake, throttle body and intake ported by ADM Performance, 477 hp 454 ft-lb tq, tuned by PCMforLess
jamesc1123 is offline   Reply With Quote
Old 01-21-2011, 10:29 PM   #2
adc174
Drives: 2010
very nice man do you have the part # or the length of the hook?
adc174 is offline   Reply With Quote
Old 01-21-2011, 10:35 PM   #3
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
Ok I need one of those for my winch, and to tow the car around
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379
FNSS Racing!
acowherd is offline   Reply With Quote
Old 01-21-2011, 11:15 PM   #4
jamesc1123
jamesc1123's Avatar
I actually called him, because the site doesn't have a "buy" option for the Camaro, so when I ordered it online, I ordered the "L" shaped one for the SN 95 Mustang and in the comments I mentioned that it was for a 2010 Camaro. I'm pretty sure it's 8 inches. Best bet is to call or email him, so he knows exactly who you are, and when the order goes in he knows what car its going on and you get the right kit. He responded to my email within 10 minutes in the middle of the day whenever I sent it.
If you do the other style (flat, not L shaped) it will be really close to one of the horizontal crossbars on the lower grill. If necessary then, you can remedy that by drilling the holes and adding washers or welding a spacer plate.
Old 01-21-2011, 11:50 PM   #5
BrandonB956
BrandonB956's Avatar
Drives: RS (11/15/10)
fine car, and nice mod. what is this used for? Ex: traveling long distances behind a RV or some scenario like that i assume ?
TEAM LLT
Nov.15th 2010 -- Check out my build thread
http://www.camaro5.com/forums/showthread.php?t=116235
BrandonB956 is offline   Reply With Quote
Old 01-22-2011, 12:31 AM   #6
jamesc1123
jamesc1123's Avatar
This is so if you are road racing or doing an HPDE on a road course a tow truck can pull you out of the gravel pit from a safe purpose built towing point rather than hooking up to "something and hoping for the best"
Old 01-22-2011, 12:35 AM   #7
Silver2SSRS6spd
Prefer to be blown!
Silver2SSRS6spd's Avatar
Drives: 2010 Silver/Black 2SS/RS Manual
I like it and have been looking for one of these for a while now. Thanks for posting! Now just need to also find one for the rear.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
Silver2SSRS6spd is offline   Reply With Quote
Old 01-22-2011, 12:41 AM   #8
jamesc1123
jamesc1123's Avatar
One guy pulled out his reverse lamp and ran his through there, but I have a hard enough time seeing out the back with both lamps as it is.
Old 01-22-2011, 03:04 AM   #9
C586
Drives: 2011 Camaro LS
Did you have to cut the front bumper cover at all?? Any more pics from underneath??
C586 is offline   Reply With Quote
Old 01-22-2011, 08:49 AM   #10
jamesc1123
jamesc1123's Avatar
Yes, because I decided to mount it at one of the original bolt holes, I had to cut one of the vertical crossbars on the lower grill. This is just the way I did it. Once you get it all apart, you'll see that there's plenty of options for how to mount it up. I didn't cut or drill the bumper impact bar though, but if you don't cut the grill, you'll have to drill the bumper bar.
Old 05-24-2011, 11:02 PM   #11
Silver2SSRS6spd
Prefer to be blown!
Been lazy, just sent a email to find out which tow hook to order. I will post the type when I get the information.
Old 05-25-2011, 09:47 AM   #12
Silver2SSRS6spd
Prefer to be blown!
Just ordered a front tow hook from Mitch at RaceCArTowHooks.Com. The one to order is now listed as the L shape 8" 2010 Camaro front tow hook. I will post pictures after install.
Old 05-28-2011, 11:38 PM   #13
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Looks great James, thanks for sharing.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-28-2011, 11:52 PM   #14
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Do the same to the rear. Use an L shaped piece that extends down from the rear bumper bar just like the front except low enough to come out through the top of the diffuser. Weld a small steel block into the gap from the bottom of the bumper bar to the topside of the the actual hook bar so it can't bend forward into your bumper. That should work and look nice and clean like the front.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Front Tow Hook? Mayhem 5th Gen Camaro SS LS LT General Discussions 17 10-20-2011 06:34 PM
Tow Hook or Tow Point?? NEED HELP! boro62 5th Gen Camaro SS LS LT General Discussions 0 02-20-2010 10:08 PM
Its Here!!!!!! Finally howsweet 5th Gen Camaro SS LS LT General Discussions 20 06-19-2009 12:59 PM
It's Here...It's finally freakin here!!!!! blkonblk Canada 34 06-13-2009 08:31 AM
Detroit's 3 finally on track, tough critic says TAG UR IT General Automotive + Other Cars Discussion 1 10-14-2007 01:16 PM
