01-22-2011, 08:54 PM | #1 |
Drives: 2011 2SS Join Date: Jan 2011
L99 tranny flaring after tune
I’ve had my SCT tune loaded on my 2011SS for about 5 months now. Although I do have a custom dyno tune, the tune I use all the time is basically the stock shift points with the AFM delete. All was fine up to a few days ago. I always drive in “M” mode without using tap shift. While merging onto the highway I would say between 4th and 5th gear my RPM’s shot way up and I was going nowhere fast! I panicked and through it into “D” and it caught the gear. I’ve put on at least 40 miles since then and it has not duplicated. From the research I’ve done this is common after tunes for the L99’s. But I don’t see how flaring (aka) slipping can be common. Is my tranny shot after 6K miles??
01-22-2011, 09:07 PM | #2 |
mine does it once when cold going into third gear then its fine after that.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s. |
01-22-2011, 11:27 PM | #3 | |
01-23-2011, 09:42 AM | #4 |
Drives: 2011 CGM 2SS/RS L99 Join Date: Jan 2011
When I had a full exhaust and tune done on my car I asked about the shift flare problem I read about and was told that one of the problems with tuning the A6 is you dont want to take the torque management completely off.(I know that some tuners will take the torque mangement completley out) My car shifts firm when you are just driving normally but at wot the shift is a little bit softer. Supposedly this is one of the ways you can avoid shift flare.
01-23-2011, 10:41 AM | #5 |
I'm going to load my strip tune and see if it happens again. TM is almost completely removed and will screech the tires from first to second. Not very comfortable shifting for driving around town but I'm curious if the tranny will flare again.
01-23-2011, 11:46 AM | #6 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
it almost sounds like when you go to full throttle, its shifting to a lower gear then expected, finishing that gear, and going to the next gear.
Im curious to hear how much if any knock your getting when you are cruising then go full throttle |
Similar Threads | ||||
Watched a 2011 5.0 GT at the track. | JJ#48Racing | Chevy Camaro vs... | 143 | 07-21-2010 06:56 PM |
Camaro SS vs. Nissan GTR | SamSS | Chevy Camaro vs... | 59 | 05-16-2010 03:43 PM |
Would like to do a compilation of L99 Header, CAI & Tune dynographs | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 41 | 01-08-2010 02:34 PM |
L99 Dynograph ARH Longtubes, ADM Race Intake & Tune by Carolina Automasters | GMRULZ | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 10-30-2009 10:32 AM |
ECS Stock L99 gets a tune....(Video inside) | East Coast Supercharging | Tuning / Diagnostics -- engine and transmission | 10 | 10-06-2009 09:15 PM |
