Old 01-23-2011, 06:51 PM   #1
twnorman
twnorman's Avatar
Drives: 2010 Camaro 1SS - RS package
Check Engine Light
My check engine light just came on after 4500 miles.
I have an AirAid air intake kit. I noticed that the clamp had loosened on the coupler that connects to the throttle body and the hose was pulled out of the throttle body. I reconnected, and have driven it about 10 miles, but the light has not gone out. I assume this is the reason the light came on.
Any thoughts on whether the check engine light will soon go out, or is this something that I need to have the dealer reset? Anything else to be concerned about?
Thanks,
Tom
twnorman is offline   Reply With Quote
Old 01-23-2011, 06:57 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
If that was your problem then the light should go away after a little while. Though if you have a scanner I would check with that just to be safe.
Click to view my build thread
Old 01-23-2011, 07:23 PM   #3
twnorman
twnorman's Avatar
Thanks for the quick response. I just went out to put a few miles on it and the light went out before I got to the end of the driveway.
Old 01-23-2011, 07:32 PM   #4
The Stig
The Stig's Avatar
Good to hear. Glad it all worked out
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 04:44 PM
Engine Misfire when cold, Check Engine Light TooCool5 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 19 08-28-2013 01:07 PM
Check Engine Light... Missionboi Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 01-08-2011 01:02 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 10:56 PM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 01:45 PM
