Old 01-26-2011, 02:10 PM   #1
neogenix
Drives: 2011 Camaro 2SS - Black
Send a message via AIM to neogenix Send a message via MSN to neogenix Send a message via Yahoo to neogenix Send a message via Skype™ to neogenix
Breaking-In an Engine...What'm I missing?
I'm due to get my new C5 in a few days, and I've been reading up on the ''proper'' way to break in an engine. Unfortunately I've seen a ton of stuff aimed at both breaking it hard ala (http://www.mototuneusa.com/break_in_secrets.htm) or breaking it in softly... So anyone have any info here for my first 1k miles? What's the best POA?
Before anyone asks, i did a bunch of searching, and nothing seemed to pop up, or pop out around this topic... although I'm getting old, and may have missed something.
neogenix is offline   Reply With Quote
Old 01-26-2011, 02:13 PM   #2
Cali_Camaro_SS
Cali_Camaro_SS's Avatar
Drives: 2010 Camaro 1SS (BLACK)
your gonna hear a lot of opinions, so its really up to you.
I got mine and drove it maybe like 300 miles like a standard car, then let loose and drove it like i was being chased by cops
so what ever you do, enjoy it!!
Cali_Camaro_SS is offline   Reply With Quote
Old 01-26-2011, 02:15 PM   #3
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Break-In instructions are in the owners manual! That should be easiest for everyone.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 01-26-2011, 02:22 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I think break-in is over-rated.
I've seen it done every way possible, from drive it like you stole it from day one, to drive it like your driving Miss Daisy the way GM prefers.
Hasn't made any difference either way. Just get it, and enjoy it.
Old 01-26-2011, 02:25 PM   #5
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
Some folks say this is the best way, but again this is only an opinion.
There is a lot more info in the Mechanical Maintenance: Break-in / Oil & Fluids / Servicing section.
Whatever you decide as long as you are comfortable with it then you are right with yourself.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 01-26-2011, 02:32 PM   #6
friskyshouse
friskyshouse's Avatar
Drives: 2010 ABM 1LT RS
Some of GM's best kept secrets can be found in the Owners manual.
friskyshouse is offline   Reply With Quote
Old 01-26-2011, 02:33 PM   #7
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
Enjoying the car is the perfect break in.
Old 01-26-2011, 02:35 PM   #8
shawn18
OWTATIME
shawn18's Avatar
Drives: 1969 CaRaMo
Drove the hell out of mine since day one. I dont run the you know what out of it but I do enjoy it , if you know what I mean. I just dont put alot of stock in break in , just drive normal , change your oil and enjoy!!
shawn18 is offline   Reply With Quote
Old 01-26-2011, 02:37 PM   #9
LYCAN
Tattooed K9
LYCAN's Avatar
Drives: E63AMG
Just go easy on it for the first couple hundred miles and don't read too much into all of the hype around this. There are tons of opinions on this and people will clammor for days debating it. Just drive the thing normal for the first couple hundred miles and don't do any super hard acceleration for a while.
Here is what I do for break in:
1) Smooth on the brakes so they seat properly.
2) Drive normally with no hard acceleration.
3) Shift smoothly through all of the gears.
4) Fill with good 93 octane gas.
5) Vary the RPMs
Regards,
John
'11 2SS Black/Black M6
Prior Project Cars: 96 WS6, 96 Steeda Cobra, 93/74/99/01ZO6 Vettes, Supra Turbo, and BMW M3.
LYCAN is offline   Reply With Quote
Old 01-26-2011, 02:38 PM   #10
CamaroMiami
Drives: 2010 Camaro 2SS LS3, 92 Camaro RS
I did this (LS3 style (M6)): The Darin method
http://www.camaro5.com/forums/showth...ighlight=break
I need new rear tires and my front tires looks new.
CamaroMiami is offline   Reply With Quote
Old 01-26-2011, 02:39 PM   #11
mikeSS
mikeSS's Avatar
Drives: 2015 c7
I think brake-in is over-rated.
the way they make engines these days it will be fine. drive it normal. don't baby it around
Old 01-26-2011, 02:45 PM   #12
MaRoFreK
MaRoFreK's Avatar
Drives: IOM 1SS w/factory Hurst
Its Under warranty
"Success is following the pattern of life one enjoys most."
Stainless works Catback with Flowmaster Single Chamber Mufflers, Vararam, Factory Hurst, SLP SS emblems, SLP Skip Shift
MaRoFreK is offline   Reply With Quote
Old 01-26-2011, 02:47 PM   #13
Johnnyma45
Former Camaro Owner
Johnnyma45's Avatar
Drives: 2011 Dodge Charger R/T
I've read all the various threads too, and one of the few things the different methods have in common is to vary the RPMs. Do that, and drive however you want, you'll be fine. I just drove normally, and still do.
6/9/10-3/30/11. RIP ROXY... :(
Johnnyma45 is offline   Reply With Quote
Old 01-26-2011, 02:52 PM   #14
Black5thgen
Drives: 2007 C6
C5's have been out since 97, why would you need to break the engine in?
Black5thgen is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Master list of in stock/inbound Camaros @ Rockmont Frank in MD Dealer Camaros for Sale 19 03-10-2010 06:17 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 08:37 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
