Old 02-03-2011, 04:15 PM   #1
843metalhead
Drives: 2011 ss camaro
Tuner Vendors please respond
.2011 SS Camaro LS3.
basically, i want to keep my warranty
I don't want headers
I've only installed SLP LMI axleback (rear muffler delete)
I want a little bit more sound and power so I'm looking into HF cats and CAI.
I also want to get rid of the decel popping sound, very badly.
Is there a tune that you have that can tune just these things but can also un tune it back to stock without leaving any trails if needing to take it to the shop if something goes wrong or just needs a service.
Last edited by 843metalhead; 02-03-2011 at 04:16 PM. Reason: adding LS3 for clarification
843metalhead is offline   Reply With Quote
Old 02-03-2011, 04:29 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
I hate to be Cold but if you don't want to jeopardize your warranty Don't Touch your Car, Ut, I guess we are too late
You can't Fool GM if you tune it they will Know, and you can't get what you want unless you tune it.
Now with that out of the way, It is your car you should make it the way you want it.
There are Thousands of Modifications you can do that are completely safe to do and won't hurt your car, Do you Research before you lay down your hard earned cash.
We have NEVER heard of someone getting they're Warranty Void just for having a tune but I guess that could change at any time.
If your going to do High flow cats you might as well do Long Tube headers Same Risk, your messing with emissions equipment.
I Thoroughly Test all products on the market and can help make the decision process easy for you.
Feel free to contact me if you have any questions.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-03-2011, 05:06 PM   #3
843metalhead
Ted.
why do I keep hearing word about this tune that can just being untuned?
and i'm not too in to headers bc of the price and if I do headers and hf cats on top of the LMI it's going to be "pull me over" loud and i don't want it too too loud like that. then again i've never heard that setup in person and have never heard that setup in normal driving rpm's in person either so idk. but I just got my taxes back so it's mainly about the second part more than the money.
Old 02-03-2011, 08:42 PM   #4
JANNETTYRACING
The SCT X3 I sell and use to tune 100s of cars allows you to program a performance tune and return to stock any time you like but GM can See that the computer has been reflashed and how many times, there is a tracking software to check this if the dealer wants to look or has a reason to.
Headers and High flow cats do not make your car louder than just high flow cats.
You should seek out parts that are of high quality and give the best performance per dollar.
Ted.
Old 02-04-2011, 06:11 AM   #5
843metalhead
Ted.
so your sayin if I just do HF cats it will be just as loud as putting on LT headers and HF cats? cuz really that's all I want to do anyways and i won't need a tune. it's bolt on, so if anything i can just bolt on the stock cats right back up. correct me if I'm wrong.
I just always thought HF and LT is louder than just HF.
Old 02-04-2011, 07:12 AM   #6
ssmike
BL1ZZRD
ssmike's Avatar
Yea, what Ted said is true! The high flow cats will give you that extra flow volume both for performance and sound! The stock cats are THE biggest flow resistance in the exhaust! Adding LT's won't do much for additional sound but will add some more performance! Downside of LT's is that you will eventually get a cel light due to O2 sensors are in a different place relative to the engine. A tune will eliminate the cel and maximize performance but will void the powertrain warranty! I have Solo high flow cats and cat back exhaust and it's quite loud and no tune required! I added some high flow resonators to quiet it down a bit and I think it's perfect now! So if you don't want to worry about voiding warranty but want more sound and performance, the high flow cats will be the way to go! IMO!
Old 02-04-2011, 07:33 AM   #7
JANNETTYRACING
Correct, same Noise level, but High flow Cats will need a tune also, some times you can get away with spacers on the O2s but it is not a fool proof solution.
Ted.
Old 02-07-2012, 05:23 PM   #8
Mike E
Drives: 2011 camaro v6 con . IMO,
Tune
Can you get a new or used onboard comp. Install a good tune?
And switch back if theirs a warraty issue.
Mike E is offline   Reply With Quote
Old 02-07-2012, 05:39 PM   #9
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Nope, not like the good ol days.
VIN and odometer is tied to the ECM, I believe.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-07-2012, 06:23 PM   #10
Steck
Drives: 2006 twin turbo Corvette Z06
I'm a little bothered at how cavalier some people are about warranty fraud. Off topic, I know.
Steck is offline   Reply With Quote
Old 02-08-2012, 09:02 PM   #11
BNRacing
Drives: 2018 Camaro SS 1LE, 2019 Camaro 2.0
Unless this car is different then most other GMs, it keeps the odometer and VIN info on the BCM, not the ECM. And this thread is exactly why we engineered Transparency Mode on our tunes
Shows only stock calibrations have been flashed. So yeah the flash count is higher but only stock tunes were flashed as far as GM is concerned. (with a tech2 anyway, they can still tell if they send your ECM to GM, which almost never happens)
BNRacing is offline   Reply With Quote
Old 02-08-2012, 09:46 PM   #12
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
+1
tramtwo is offline   Reply With Quote
Old 02-08-2012, 10:47 PM   #13
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Correct me if I'm wrong, but if GM accesses the computer, and sees the count, they also have the number of times they have been in it as well... via the VIN....therefore even if it only shows stock tunes, they would know something is up...???
Old 02-09-2012, 07:05 AM   #14
JANNETTYRACING
Sorry GM is Not That Dumb, if the computer was flashed more times then they have on record your Toast.
Ted.
Need help with SCT X3 tuner... Fiftydriver Tuning / Diagnostics -- engine and transmission 3 07-12-2010 06:54 PM
SCT Tuner question JustaCamaro Tuning / Diagnostics -- engine and transmission 3 02-28-2010 06:32 PM
TUNER GALLERIA Chicago Car Show @ Donald E Stephens Convention Center! CarNutzCustomz USA - Great Lakes 0 01-23-2010 11:40 PM
TUNER GALLERIA | Houston, TX | Nov. 26-29 CarNutzCustomz USA - Texas 3 12-07-2009 03:07 PM
ATTENTION ALL VENDORS (VENDOR RULES) TAG UR IT Sponsors Classifieds Marketplace 0 09-12-2009 04:39 PM
