Gunning for Sixth
Drives: '03 ZR2 Blazer Join Date: Sep 2008
AutoTrix 'Window Fix Kit' - Worth the bother?
Now it's above and beyond common knowledge that if you own a 4th gen F body with power windows you're going to have those motors fail.
Multiple times.. Now I've replaced one of my motors once, but also noticed that after the procedure the motor was still a tad slower than the drivers side (due supposedly to the wiring harness design). Doing some reasearch I found out about this little wonder kit/snake oil kit. http://www.autotrix.net/Product-Pass...Fix-Kit_1.aspx Supposedly it modifies the harness with the addition of a relay to produce a 'boost' in voltage to the motor, allowing the motor to run at the proper voltage as opposed to that supplied (with substantial loss) through the factory harness. For 35 bucks plus shipping it seems like a quick fix (they even sell express down kits to add into the fix and even a whole kit with a pair of motors and the express kits). Anyone try this? Worth it? Or is it just snake oil? |
Don't Like it? Suggit.
Thanks for posting! I'm def gonna look into this- my driver window is out right now...
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
Gunning for Sixth
Original motor or a replacement? I was hoping some former 4th gen owners here had heard of it or at least attempted it. I'm seriously going to look into the kit once I do some more research. It's 2nd in line after repairing my rear deck from years of delamination.
#4 | |
![]() Mine's been close to death for like four months now. Sometimes, t won't roll down all the way right when I start her up. Sometimes it will. It just depends on whether or not I actually need it to go down all the way, and Murphy's Law does the rest.
Gone but not forgotten:
1998 Bright Purple Metallic Camaro 2012 Carbon Flash Metallic 2SS Convertible 2016 Summit White 2SS Coupe M6, NPP, & MRC Now Driving: 2016 Torch Red Corvette 2LT, NPP, MRC |
![]() Drives: 1997 Camaro Z28 (sold) Join Date: Jan 2010
GM supplies 12 volts to the drivers side switch. Then comes off the drivers side switch to the passengers switch. So what happens is, when you roll both windows up or down at the same time you are splitting the voltage. Now you have 6 volts trying to run a 10-12 volt motor thus burning them up prematurely. Combined with the heavier windows that spells disaster. So, replace your motor and then try and remember to roll the windows up 1 at a time and this will extend the life of the motor tremendously. You see the same thing with any 2 door GM car. i.e. Grand Prix, Monte Carlo etc. Believe me with both switches there together, it is hard to refrain from doing both at once.
#6 |
![]() Drives: 1996 Camaro RS convertible Join Date: May 2009
heres some more help http://www.fbodyonline.com/forum/f20...dow-fix-23707/
#7 | |
Official Lounge BAMF
My '97 still has the factory motors.... it does go a lot slower with both, so I usually roll both up at different times. I know on mine I can roll them up and down with the ignition off (til the doors open).... but it really bogs down, do you think that could cause it to wear down faster? I try to take it easy on it and rarely do it with the key out.
#8 | |
#9 | |
Gunning for Sixth
There is also no noticeable performance drop in the charging system with the engine on (off everything drags regardless) so I'm pretty sure it's the factory design doing it's thing. |
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS LS3 Join Date: Aug 2010
Yeah, I'll get around to it...
#11 |
I installed and it works great! No snake oil here.
Original design is poor because the passenger window controls pass through the drivers door before going to the passenger door. Voltage drop is real and has been verified over and over. Primary cause of motors going out and running slow. I also added the relay for express down used on the driver door. Now both windows express down on my car.
On the internet - Anything is possible, especially when you don't know what you are talking about.
#12 |
Gunning for Sixth
#13 |
Not hard to do.
I give it a 2 on a scale of 1 to 10. Most time is spent running a dedicated wire directly from the battery to the door. Wiring instructions included are straight forward. At the time Autotrix did not offer the express down option. I did it myself by buying the drivers side express relay and wiring it in. I'm sure their bundled kit would be simpler.
#14 | |
| V8 Camaro Performance Upgrades List | Milk 1027 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 93 | 08-30-2021 05:56 PM |
| ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) | Ultimate Performance | Forced Induction - V8 | 496 | 10-11-2009 01:29 PM |
| 5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! | HID_Guy | Exterior Parts & Accessories | 19 | 09-08-2009 01:07 AM |
| 2010 Camaro Fog/DRL Light 5202 HID kits .... | HID_Guy | Exterior Parts & Accessories | 1 | 09-07-2009 12:19 PM |
