![]() Drives: 2SS/RS Join Date: Jul 2009
325's with no spacers or fender work
Thats right, I fit a 325 M&H Racemaster DR 325/45/17 with no spacer or special fender work. That is a 28 inch tall tire that has a section width of 12.5 inches according to the website. The Racemasters are wrapped around Bogart bolted D10's. I know the 315 has been tried and known to work but I wanted to really fit the largest tire I could without having to seriously modify my frame or fenders. I had heard rumors of a 325 fitting before but could never track the source or see photos to confirm. It was always a friend of a friend or I know a guy kinda story. So to squash all doubts here are some quick shots.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I am still able to fit my hand between the tire and inner fenderwell. So far I have not encountered any rubbing issue or problems but I have only drivin the car 6" with them on due to the weather.
Quit being a pu$$y
What is the width and offset on the rear wheels?
![]() ![]() Drives: 2012 Challenger SRT8 Auto Join Date: Sep 2009
Is your car lowered at all? It looks like you still have the stock springs in the rear. I have Nitto Invo 315s in the rear and it seems like you have a little more inside clearance with the 325's here but they stick outside the fender a bit more and may contact on the outside if the suspension compresses enough.
"When the people find they can vote themselves money, that will herald the end of the republic." - Benjamin Franklin ![]() LS3 Camshaft Swap Do-It-Yourself Instructions - 2010 LS3 gone but not forgotten!!! |
#4 | |
It is the standard Bogart deminsions. I didnt ask for anything specific. They are 17 by either 10 1/4 or 10 1/2 inches. As far as the backset, I think it is in the 7 1/4 to 7 1/2 range. I could be wrong though.
Quit being a pu$$y
They stick out a little too much for my taste.
#6 |
To each their own....
#7 |
What are you running in the front?
#8 |
Bogart 17/5.5 with M&H 28/4.5/17.
#9 | |
![]() Drives: 2010 RS 2 SS Join Date: Aug 2009
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Charger SRT 392 F8 Green Join Date: Aug 2010
now thats some serious meat back there. Looks great!
#11 | |
Thanks in advance. |
#12 |
i went with springs & sway bars . it was 1" ft 1" 1/4 rear at install , but thy settled more over time . from the floor to the top of the wheel well now measures ft. 28" rear 29" . as far as traction go's , 654 rwhp & 16-19 psi in the rear tires , 3200 stall i have no issue at all . little to no spining off the line . the car transfers great . if you have a ls3 m6 thats a whole nother beast , maybe some ls3 guys can chime in with more info.
hope this helps .
#13 |
That's awesome, thanks for the input. I would love to see more shots of that thing if you don't mind sharing. It sounds like the ride height is perfect. I am a M6 ls3, but it sounds as if I can get away with using springs and sways until the budget allows for full adjustable coil overs. Do you mind saying which company you went with as it seems you have had great results. And if the tires are holding for your 650+ hp, they should hold for me just fine.
Thanks again. |
#14 |
![]() Drives: camaro Join Date: Feb 2010
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| This site is like crack. You know you're addicted to Camaro5 when... | GameOver620 | 5th Gen Camaro SS LS LT General Discussions | 463 | 01-03-2011 03:28 PM |
| PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 12:00 PM |
| *WORST DEALER WORK EVER!!!*look at what they did to my baby* | 2SSmeCamaro | 5th Gen Camaro SS LS LT General Discussions | 105 | 06-15-2010 03:25 PM |
| If the El Camaro makes it to production.... | Silverado | General Automotive + Other Cars Discussion | 8 | 02-21-2008 11:17 AM |
