Old 02-07-2011, 05:52 PM   #1
MClarenF1
Drives: 2011 CGM 2SS/RS A6
When should be my 1st oil change? another ? also
okay so i came home today and i have 888 miles on my brand new camaro.. when shud my first oil change be?
also.. when i had to pull out of a parking lot with traffic continously coming from both sides.. i had to push my car a bit hard, not FULL throttle.. mayb almost 1/2 but when i made it to the lane and started driving normally.. the car started making a little whine when driving.. so at a red light i shut off the car and restarted it and it went away..
it also whined today in the morning so i restarted it and it went away.. whats causing this? im worried cus its a brand new 2011 camaro ss and it shudnt do this!
MClarenF1 is offline   Reply With Quote
Old 02-07-2011, 05:58 PM   #2
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
The whine is not normal. If it is doing it, take it to the dealer while it is doing the whine, do not restart the car.
Also, you'll get differing opinions about when to get your first oil change. But the car comes with an oil life monitor. You will technically be fine changing your oil when your car tells you to.
People will also tell you that there are metal shavings in your oil when you first get the car and to switch out the oil after 1000 miles or so, but it's up to you.
cab2g is offline   Reply With Quote
Old 02-07-2011, 05:59 PM   #3
The Stig
knows 2 facts about ducks
The Stig's Avatar
I changed mine at 9 miles. You'd be amazed how much gunk and metal was in the oil. Shavings left and right. The rear diff fluid needs to be changed at 1,500 too btw. Thats in the owners manual. Oil is a split topic. Some people say every 3,000 but some say go by the oil monitoring system.
Click to view my build thread
Old 02-07-2011, 05:59 PM   #4
MClarenF1
why shudnt i restart the car? and ok i'll take it to the dealer, i really hope this isnt a major problem...
Old 02-07-2011, 06:03 PM   #5
hamr56
hamr56's Avatar
Drives: 11 2SS/RS, 56 Chevy Bel Air 2DR HT
All restarting the car is doing is masking what may be a bigger problem. The early morning whine may just be because it was cold. But with your other situation going on I would defintely get it checked out just to be safe.
hamr56 is offline   Reply With Quote
Old 02-07-2011, 06:30 PM   #6
rdblan2
Drives: 2SS RS
Did my first oil change at 1500 miles. Service adviser, service manager and the tech looked at me like that was the dumbest thing they'd ever heard of. All said it was a waste of a free oil change, but I did it anyway.
ymmv.
rdblan2 is offline   Reply With Quote
Old 02-07-2011, 06:47 PM   #7
MaRoFreK
MaRoFreK's Avatar
Drives: IOM 1SS w/factory Hurst
Got my first one changed at 3000 miles. But when I had my Silverado I ran it till it told me to change it.
"Success is following the pattern of life one enjoys most."
Stainless works Catback with Flowmaster Single Chamber Mufflers, Vararam, Factory Hurst, SLP SS emblems, SLP Skip Shift
MaRoFreK is offline   Reply With Quote
Old 02-07-2011, 09:02 PM   #8
LS3CAM
TheBeerMan
LS3CAM's Avatar
Drives: 2010 RS/2SS Camaro LS3 CGM Sunroof
Did my first oil change a few weeks ago. A little before 8000 miles. The oil life monitor was at 24%. Bought 8 qts. Mobile 1 and an AC Delco PF 48 filter from Wal-Mart for about $50. The dealer that I bought the car from wanted $100. They probably would have dented or scratched something in the process anyway. I do all my own oil and filter changes, I know they are done right. BTW: oil was not quite 1 qt. low at the time
LS3CAM is offline   Reply With Quote
Old 02-07-2011, 09:30 PM   #9
IBM/2SS/RS/LS3
NorCal Camaro➎ Member
IBM/2SS/RS/LS3's Avatar
Drives: Bowties ONLY!!
also did mine at 1500 and rear diff too
IBM/2SS/RS/LS3 is offline   Reply With Quote
Old 02-07-2011, 09:43 PM   #10
blackknight
Camaro Lover
Drives: 2014 GMC Sierra 5.3L
first oil change for me was around 1000 miles. i did the rear diff around 1500.
No Camaro right now. But I'll be back in one in a few years.
blackknight is offline   Reply With Quote
Old 02-07-2011, 10:09 PM   #11
Blown355
Blown355's Avatar
Drives: 2017 ZL1 A10
Rear diff fluid change a 1500 miles. That's the first time I've heard that. Guess I know what I'll be doing this weekend!
2017 ZL1
A10
Redhot with stripe
Blown355 is offline   Reply With Quote
Old 02-07-2011, 10:36 PM   #12
oldfriend
Drives: Fiat 500 E
2SS
ymmv.
AND THEY HAVE A REASON FOR IT , READ THE BOOK !
Old 02-09-2011, 05:56 AM   #13
barbm
LTTL HULK
barbm's Avatar
Drives: 2010 Synergy Camaro
Send a message via AIM to barbm
Hello. FYI If you have a 3.6, make sure you do not go by the oil life monitoring system. My husbands partner at A G Auto has over 20 yrs G.M. training & they found with the 3.6 if you stay on top of it every 5,000 Km. you souldn't have any issues. With the 3.6 if the oil gets sludgy or thickens it will cause the timing chain tensioners to stiffen up & eventually stretch & break the chains. If anyones heard anything different , let us know.
Thanks Barb
barbm is offline   Reply With Quote
Old 02-09-2011, 12:13 PM   #14
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Follow the factory oil life indicator. It knows best.
If you would sleep better at night with your first oil change at 1500 miles or 3000 miles or whatever then DO IT. After that you can follow the oil life indicator. That is what I have been doing.
-Mark.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
1st Oil Change and 15mm! hamidar05 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 3 10-19-2009 07:13 AM
Where are you going for your 1st oil change? Yellow2010 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 26 09-04-2009 12:25 AM
