![]() Drives: 2010 Camaro 2SS Join Date: Jun 2010
20x10 on all 4 corners
I was wanting to know if I bought a set of 20x10 rims and put them on all 4 corners of my car, will I have any problem with rubbing? I remember reading that the stock rear tires fit on the front and don't cause any problems, I was wondering if one inch wider would be too much.
Thank you, Brandon |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
Brandon, it depends on the offset too, not just the width. The 10s can fit up front (barely) but you'd still need a perfect offset and still run the narrower 275 tire on them. Otherwise, they poke out. I'd recommend sticking with a 20x9 or 20x9.5 front wheel, there is no need for 20x10 just to run a narrow tire on it.
For the rears, we can fit a 20x11 wheel with a 315 wide tire, no problem. Tony
Fquick.com/NineBall
Well I was wanting to get away from the staggered pattern...and I wanted to run at least a 10" wide tire on the rear. But if that's the case I would need to probably just do 20x10 on the rear and 20x9 on the front or 20x9 all around. With the same offset as the factory rears.
| PEDDERS SUCCESSFULLY FITS 305s ON ALL 4 CORNERS! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 467 | 06-11-2013 10:45 PM |
| >>> 20x8.5, 20x10 MHT GAME CHROME- SIMILAR TO STOCK - Starting @ $1276 SHIPPED! | BestWheelDeals | Wheels / Tires | 22 | 05-31-2011 02:12 PM |
| >>> TIS M18 MATTE BLK 20X8.5, 20X10 W/TIRES FROM $1795... PERFECT FOR CUSTOMIZING! | BestWheelDeals | Wheels / Tires | 11 | 02-22-2011 07:36 PM |
| Paint peeling at corners of bumpers | FirstCamaro2k10 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 26 | 06-22-2010 05:26 PM |
