Old 02-13-2011, 05:17 PM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
Should aftermarket wheels be torqued to stock wheel specs?
Just wondering if I should torque my aftermarket wheels to stock specs which is 140ftlbs or if I should stay around 100 ftlbs since its aftermarket?
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 02-13-2011, 06:45 PM   #2
Mr Twisty
Mr Twisty's Avatar
Use the same spec for aftermarket.
That seems high, but...
I guess it is 140
http://www.camaro5.com/forums/showthread.php?t=33139
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 02-15-2011, 09:32 PM   #3
RBD
RBD's Avatar
Drives: 2013 SS/RS Convertible
torque spec. is based on the stud size and thread not the wheel.....
RBD is offline   Reply With Quote
Old 02-15-2011, 11:16 PM   #4
Sean@WSIAZ
Sean@WSIAZ's Avatar
Drives: 2010 Camaro SS
Where exactly did you see 140lbs at? That is extremely high, 100lbs is optimum for that thread. Over tightening can be as dangerous as not tightening enough. I'd be interested to see what said 140lbs....wow!
Sean@WSIAZ is offline   Reply With Quote
Old 02-16-2011, 03:02 AM   #5
OnkelMatze
OnkelMatze's Avatar
Drives: Camaro 2SS/RS LS3 AirForce
it´s in the owners manual page 11-3
OnkelMatze is offline   Reply With Quote
Old 02-16-2011, 07:11 AM   #6
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
I still torque all my lugs to 100 ft-lbs. Even though 140 ft-lbs is written, it does seem excessive. I've never had one work itself loose before, ever, while using a torque wrench.
Fquick.com/NineBall
Old 02-16-2011, 07:34 AM   #7
mistermike
Drives: 2004 GTO
I've never used an air gun or a torque wrench for the lugs on a decent car. Old fashioned criss-cross lug wrench. Never had a lug loosen, never warped a rotor. After 40 years of doing it, you just know how tight it needs to be. I use the German torque spec for wheels.
First North American Twin Screw LSx
2004 GTO Blown H/C LQ9
2008 HHR SS tweaked
2003 CTS with dead hooker in spacious trunk
fquick
mistermike is offline   Reply With Quote
Old 02-16-2011, 08:47 AM   #8
The Stig
knows 2 facts about ducks
The Stig's Avatar
The manual says 140, I torque mine to 140. Don't know where the thread is, but a member told a story of how he was driving his suburban on the highway after rotating tires (didn't torque to spec) and all of a sudden his driver's side front wheel popped off and his rotor hit the pavement. Pretty terrifying story to read. I'm happy being safe than sorry. It doesn't take much extra to go from 100 to 140.
Click to view my build thread
Old 02-16-2011, 08:54 AM   #9
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Also read this TSB.
http://www.camaro5.com/forums/showthread.php?t=73114
I do 140
skuttduck is offline   Reply With Quote
Old 02-16-2011, 07:05 PM   #10
jsharp
jsharp's Avatar
I am currently doing 100 and have been. I too think 140 is not much more. I usually put my air impact on lowest setting and it only takes a 1/4 turn to get 100ftlbs from there. Looks to be some different opinons here so Ill just decide what I want to do.
Old 02-17-2011, 01:05 AM   #11
Brianskeet
Brianskeet
Brianskeet's Avatar
Drives: RJTC 1SS RS L99
Just to be different I am a 110 lb guy.
ARH 1 7/8 coated LT, High flows, Corsa L99 exhaust, Vmax CNC throttle body, Elite Engineering catch can and tunnel brace, C.A.I. Apex Washer relocation and scoop, Janetty Tune, MSD wires, DEI heat shields, RB rotors and pads, Mike the powder coater calipers, pedders lines, Forgestar F14's, Gorilla nutz, MTI spoiler finished by Gary, Gary's Customz Bow Ties, Side Markers and Tails tinted, Bezels matte black, Badges deleted, Windows Tinted, AAC DRL P13W lights, AAC tinted LED reverse lights, AAC LED interior lights, RPI match painted DRL Bezels, Lis plate frame, Lloyds mats
Brianskeet is offline   Reply With Quote
Old 02-17-2011, 01:42 AM   #12
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
I put mine back on at 140 after painting the calipers.
[B]
Old 02-17-2011, 02:36 AM   #13
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
I have custom 3-piece forged aluminum with racing forged aluminum lug nuts and I have mine on at 90 lbs of torque. I do not use an impact wrench; hand tighten them with a torque wrench.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 02-17-2011, 04:46 AM   #14
Brianskeet
Brianskeet
Brianskeet's Avatar
Doc, You are the lightness king! Have you noticed any trouble with your forged aluminum lugs? I did a lot of searching and found that the vast majority of forged aluminum lugs were for smaller lighter cars. I am not sure if I would trust them on our 3800 lb vehicles, but I love the idea of losing unsprung rotational weight. Very interested in you opinion of them since you have camaro experience with them.
Different Wheel Construction Types Explained Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 45 12-21-2017 09:37 PM
20" All-Season Tires for Stock Wheels Abygale Wheels and Tires Talk Sponsored by The Tire Rack 22 11-11-2010 12:21 AM
feeler- 20" stock wheels off my SS (polished) racrx451 Wheels / Tires 4 07-13-2010 01:25 PM
Wheel offset of stock wheels? jc211 Wheels and Tires Talk Sponsored by The Tire Rack 0 03-27-2009 02:54 PM
