Old 02-14-2011, 02:23 PM   #1
f5journal
Senior Camaro Fanatic
f5journal's Avatar
Drives: 2011 SS/RS manual - White
Tune, gears, warrantee, all that stuff again...but
Let's not rehash all the warrantee stuff, but I thought I might approach this from a different angle So Ted...help me here
My main subject is gears. And I would be the guy wanting to protect my warrantee as much as possible. It seems to me gears and a CAI may be the best way to go for us on the fence and not wanting to tune an otherwise stock Camaro to get that extra 15hp and some more fun in the drivability...So....4:10's in a SS M6 and add a CAI
My questions are:
What happens with the factory torque management settings when you install new gears...do they continue to defeat you? Or do you get multiplied torque...how does this interact with the new gears
Do you have to flash the ECU to fix the speedometer?
It seems like I could simply tell the dealer what I've done and lose only the warrantee on the rear end. And if there is tweeking to be done for the speedometer, let them do it
f5journal is offline   Reply With Quote
Old 02-14-2011, 02:48 PM   #2
Brian@Phastek
Brian@Phastek's Avatar
Drives: 2010 Camaro 2SS/RS
I believe the dealer can do it with the MDi. Best to talk to them and see. Otherwise yes, you'd have to program the PCM and the TCM if an auto
Brian@Phastek is offline   Reply With Quote
Old 02-24-2011, 01:24 PM   #3
f5journal
f5journal's Avatar
Bump...I still have not got an answer. Hep me pls
Manual transmission What happens with the factory torque management settings when you install new gears...do they continue to defeat you? Or do you get multiplied torque...how does this interact with the new gears
Old 02-24-2011, 10:21 PM   #4
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
dealer can not do any programming or adjusting other than the latest factory file
Old 02-24-2011, 10:34 PM   #5
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
if you dont reduce torque management with a computer program, it will stay attached and remain active. Although you may defeat your CAGs with high enough gears and wouldnt have to tune them out.
you can install a procharger, bolts ons, heads and cam, but you'll still have TQMT unless you remap your system
Tampa Tuning is offline   Reply With Quote
Old 02-25-2011, 10:59 AM   #6
JANNETTYRACING
JANNETTYRACING's Avatar
My questions are:
1) Nothing unless we change it in the tune, but it may not work if the speedo is out of calibration.
2) Yes,Change the Gears you have to tune to correct the speedo and for the 4 wheel ABS to work right.
3) I don't think the Dealer can change the speedo cal.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-25-2011, 11:13 AM   #7
f5journal
f5journal's Avatar
Thanks Ted..I get it. So in short, gears are not a solution to "get around tuning your car"
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 11:01 PM
Standard vs Automatic Racing HarrisraTx Dragstrip and Launch Techniques Discussion 74 10-29-2010 10:26 PM
Undetectable Tunes - What You Should Know kelley@vectormotorsports V8 Bolt-Ons & Tunes 159 09-18-2009 03:18 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
