![]() Drives: 2011 CGM Camaro SS/RS Join Date: Dec 2010
I am ordering my 2011 Camaro 2SS/RS (CGM/Blk Stripe) this week, I was debating between the auto and manual but am going with the manual. I was reading in one thread about manual owners having clutch problems. Can some of you (especially the 2010/2011 owners) give me some input in regards to your experience with the manual.
![]() Drives: Camaro 2SS/RS and 2001 Ford F250 Join Date: Oct 2009
The clutch on these cars are definitely a weak link. Had the pedal stick to the floor twice then got a new clutch under warranty. The next week had the same thing happen again. Talked to GM again but they brushed me off. The engagement point on mine also seems to jump around alot. It started out lower and now it is way up high towards the top of the pedal travel. Not trying to scare you off of buying the manual but it is a junk of a clutch. Love the car but I have it in my mind when she burns up I am going to put a much better aftermarket clutch in.
9691 & 97586
Drives: 2010 SS, 1999 SS, 1993 Z28 Join Date: Mar 2009
I've had mine stick and it was under more aggressive driving.... normal everyday driving hasn't given any issues.
Sent from my EVO 4G
#4 | |
I bleed green
Is the clutch supposed to have automatic adjustment? The engagement point moving higher sounds like normal wear to me. (at least its normal in my semi. bout once a year i have to climb under it and adjust it) |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Ive tuned both. Im a manual guy for last 32 years, but I like the way the A6s respond to tuning. I tune out a lot of the issues that guys complain about on this forum. IE, shift firmness, shift speed, sloppy long shifting, cylinder drop causing the confusion in which gear the transmission should be in, lack of kick down power when you jump on it. Once those issues are tuned out, I really like the automatic performance.
Without the tune, Id got with the stick. |
#6 |
It's that guy
I've driven the M6 since September, I haven't had any issues, but then again i haven't done any "aggressive driving" just zooming around the streets around slow people and occassionally unleashing the best to merge on the highway.
We mortals are but shadows and dust.
#7 |
Thanks everyone, appreciate the input.
#8 |
![]() ![]() Drives: Silver SS/RS, Man 6 Join Date: Apr 2009
ADM Perf added a return spring on my clutch pedal under the dash. Not any return issues with spirited driving. Also, I added the ADM/LPE dual disc ZR-1 clutch, flywheel, and actuator. You got to pay to play as they say. One stat that surprised me is that about 25% of the fifth generation Camaro's are Man 6 and the rest are A6's.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers, GM 3.91 Rear Gears |
#9 |
![]() Drives: 2011 Camaro SS Join Date: Apr 2011
2011 ss, my clutch went to floor and never came back, and fluid was dripping onto the exhaust. whats up
#10 |
Blown Cool Breeze
Drives: 2011 Black on Black 2SS M6 Join Date: Jul 2010
Time to take it in for warranty work.
As far as "whats up" search around here and you see how to deal with the clutch issues and how to prevent....
Had a 2010 IBM 2SS M6 Enjoy life.Think of all the women on the Titanic who passed up dessert. |
#11 | |||||
![]() Drives: 2010 Camaro Join Date: Jun 2010
I like standard but I have had too many issues with GM ignoring my complains about the m6 malfunctioning. I have spent 11 months to get it fixed no help from GM..
Let me put it to you this way. I had my car in for them to fix it.. And you can see the result in my first video.. I am sick and tire of GM ignoring me when I tell them that the car has issues. Look at my posts I have issues since june of last year.. Still no fix. ![]() ![]() ![]() ![]() : mad0260:![]() ![]() I hope my videos will help you to make your decesion,,, |
#12 |
![]() Drives: 2016 2SS, Yellowjacket, A8 Join Date: Oct 2009
I have had my Camaro since Dec. 09 and no clutch issues with aggressive acceleration. Maybe I was lucky, as not all LS3's have experienced clutch problems.
GeorgeM |
#13 |
![]() Drives: 2010 camaro ss Join Date: Mar 2011
I have not had any problems with mine as well. But I believe in preventive maintenance, so I am going to repair or replace these issues before they happen. The list and $ needed is climbing.
#14 |
xbox: this is tedious
piticu667
Have you shown those videos to your dealership? I know the V6 Transmission has serious problems, this is really something GM should address.
Big Carrot's Changes - It's a work in progress ![]() |
| Tags |
| clutch problems |
| I want a new clutch, you too????? Sign here | tjbusa | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 370 | 08-10-2013 04:27 AM |
| Is there a TSB for the clutch sticking? | Heelhook22 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 10 | 11-03-2010 09:21 AM |
| Clutch issues. Anybody else seen this before? | H & E | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 47 | 05-21-2010 03:38 PM |
| Odd clutch and shifting issue for me. | armysig | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 02-22-2010 12:36 PM |
| Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid | Embalmer | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 09-11-2009 10:52 AM |
