Old 02-15-2011, 06:24 AM   #1
SilentSoul308
Drives: 2010 Camaro SS
Can someone explain an Underdrive pulley?
Like the subject line says. Can someone explain what an Underdrive pulley does and what the pros and cons are please?
SilentSoul308 is offline   Reply With Quote
Old 02-15-2011, 06:37 AM   #2
Smart Line
Drives: 2011 Blue1SSRS 623RWHP, 02 vette
Pros less HP stolen by static pull.
Con you Ac and alternator will turn slower.
slight more hp for slight less AMP form your alternator and A/C pump.
hope you understand that.
Smart Line is offline   Reply With Quote
Old 02-15-2011, 08:20 AM   #3
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
The under drive pulley never sounded that exciting to me for that reason. All your belt driven accessories will run more poorly. The mod may be cheap, but it has too many negatives for me to really want to use it. But, I'm not knocking anybody who uses one. A strong AC just happens to be a priority of mine!
cab2g is offline   Reply With Quote
Old 02-15-2011, 12:17 PM   #4
IamJacksCamaro
IamJacksCamaro's Avatar
Drives: Camaro LS M6, Fiero, Ford F100
It can free up some horsepower, but not a good idea on a daily driver, in my opinion.
IamJacksCamaro is offline   Reply With Quote
Old 02-15-2011, 06:40 PM   #5
Saltyflats
Drives: 2011 Camaro SS LS3 6 speed.
Years ago I had a 73 SS with all the fixings. Every single time I would hammer it she would throw a belt. I'm not a fan of aftermarket pulleys
Saltyflats is offline   Reply With Quote
Old 02-16-2011, 11:20 AM   #6
Jon@Texas-Speed
Drives: 01 SS Camaro / 07 Silverado
Thousands of guys run these on LS cars with no problem. Yes it turns the accessories slower and probably not ideal if you are running a big stereo system or other accessories driven by the alternator. However, most guys are doing with with camshaft installs where the idle is already higher thus the accessories aren't really driven that much slower. It frees up another 7-8 hp for about $200. Not a bad gain for the money. I have yet to see a car that actually has a problem due to having a UD pulley on it.
Jon
Jon@Texas-Speed is offline   Reply With Quote
Old 02-17-2011, 08:52 AM   #7
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
I did the 25% reduction pulley after a cam exchange. It makes sense how you would gain HP, but the amount is questionable. In 9 years, Ive never had a problem with it, but my electrical system is stock except for 1100x driving lamps.
You have to remove the stock pulley when your doing a cam exchange, so the labor is none.
If I would do it again, I doubt Id spend the money in that direction for the gains, but I do think there are gains.
Phil
Tampa Tuning is offline   Reply With Quote
Old 05-03-2011, 11:39 PM   #8
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
so when doing a cam change, this is highly recommended? about to get a cam and trying to decide if this is worth it....
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 05-04-2011, 01:54 AM   #9
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Not highly recomended but if you're wanting to do it, this would be the perfect time since the stock one is already off. That is why TT said that labor would be ZERO.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-04-2011, 01:37 PM   #10
camarohead
camarohead's Avatar
Will I be able to feel the extra hp by seat of the pants...
Old 05-04-2011, 01:50 PM   #11
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
No, not from the pulley alone.
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 05-04-2011, 04:04 PM   #12
Jon@Texas-Speed
It's a good time to do it along with a cam swap because the pulley is already off the car. I would definitely do it if I were doing a cam swap. $200 for 8 RWHP isn't bad either.
Jon
Old 05-04-2011, 11:21 PM   #13
camarohead
camarohead's Avatar
When talking about reliability, is it an upgrade or something you could have problems with over the stock pulley?
Old 05-05-2011, 06:50 PM   #14
Jon@Texas-Speed
I have never seen an issue caused by an underdrive pulley other than a charge issue. If you did need it, you could run the overdrive alternator pulley and I don't see how it could hurt anything at all.
Jon
TVS2300 & 1900 Pulley Info & Size ... 8aStang Forced Induction - V8 18 04-03-2018 04:38 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 09:25 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 41 03-17-2012 11:22 AM
Underdrive pulley 10-HP gain. rex113 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 01-05-2010 07:25 PM
Texas Speed & Performance 2010 Camaro SS Underdrive Pulley Kit Jason 98 TA V8 Bolt-Ons & Tunes 1 05-20-2009 11:40 AM
