H3LL1ON
Drives: 2010 1LT Camaro Synergy Green Join Date: Jul 2010
Disabling DRL - BCM Function Delete
Has anyone had any luck accomplishng this yet? There was a member here stating it could be done i believe thru programming the bcm chip. Tho it required it be removed from car and mailed to him.
It's Green, really Green!
C5![]() |
I'm pretty sure it's illegal to not have them on, or have the headlights on.
![]() Synergy Green is going to attract a cops attention, having the DRL's disabled might get you a ticket.
H3LL1ON
Oh I will have my dual headlight halos on and the dual foglight halos on. Just don't want the hid headlights detracting from the look during the day.
C5![]() |
i like carz
Drives: 99 Formula,85 Trans Am,04 Monte Join Date: May 2010
its not illegal to not have them , most new cars dont have them . I heard that if you buy a new vehicle before you get it you can ask them to disable it , gm that is and they are supposed to . Im calling bs but someone on one of the monte carlo forums had a paper that stated this .
#5 | |
#6 |
![]() ![]() ![]() Drives: 2010 Camaro Join Date: Aug 2009
Same here in the US. We can only disable them for law enforcement vehicles, & need a letter stating so before getting approval from GM to get a revised bcm calibration to disable them.
#7 |
Heritage Hanger
Drives: 2010 Camaro 2SS/RS, Black. Join Date: May 2009
I just turn on the halos (thus shutting off the DRLs). They look great anytime of day!
Keeping The Spirit Alive! |
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS IOM - A.K.A. DA ;) Join Date: Jan 2009
Like anything controlled by the computer it can be programmed out. However, it is illegal on all newer cars in Ontario to run without them. The Camaro Halos don't put out enough light to act as the DRLs. What you "could" do is have them programed so the manual override shut-off (spring loaded counter-clockwise click on the lights knob) actually shuts them off and leaves them off. Cars destined for some states have this feature. But for areas that require DRLs the spring loaded function to the left is disabled. Someone told me once that doing that required actual re-wiring of the switch. If you go this route you didn't hear it from me. It's still technically illegal in Ontario. But dig around on the various forums. You'll find what you're looking for.
"BBOMG - More than just a car show.... It's an experience!" |
#9 | |
Heritage Hanger
Guess I lucked out in that sense! That, and being able to pick out the spaces in the numbers on the speedo! lol
#10 | |
![]() Drives: 2010 Black 1SS Join Date: Aug 2009
2010 Black 1SS LS3 M6
Power: Kook's 1 7/8" Long Tubes and 3" Exhaust, Injen Full Length CAI, Jannetty Tune Drivetrain: MGW Short Shifter, Street Slayer Twin Clutch, DSS 1 Piece Aluminum Driveshaft, DSS 1000HP Axles, BMR Pro and Delrin Diff Bushings Suspension: BMR Trailing Arms and Bushings, FE6 Swaybar Conversion With Pedders 27mm Front and 32mm Rear ZL1 Swaybars and Links Chassis: Hotchkis Chassis Max Brace, BMR Pro Cradle Bushings Exterior:: Shine by Adam's. ...and plenty more |
#11 | |
Heritage Hanger
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS Join Date: Sep 2009
I hope someone figures this stuff out soon I want to change the whole lighting system to work differently
2010 Summit White Camaro LS / M6 MRT V2.0 ![]() |
#13 |
<< CRAZY BEE >>
Drives: 400HP 2LT/RS Join Date: Apr 2009
I'd like to be able to see someone mod it so that the Day time running lights along with halos can be on in the evening and at night if by choice with the option to have the night lights off. This would be good for well lit areas as the running lights and halos put out enough light to let others know your on coming.
Shaun
CRAZY BEE - IOM 2LT/RS (more) Cosmetic Mods - 24 | Performance Mods - 14 ROTO-FAB CAI - DT HEADERS - CUSTOM 3-INCH PIPE EXHAUST - RES DEL - R-CATS DEL - MAGNAFLOW RES X-PIPE - 91 OCTANE TUNE - FULL ADM KIT - PORTED IM - PORTED TB - PORTED CH - BLACK 3/8 ISOLATOR - TRIFECTA TUNED |
#14 | |
People have been known to be pulled over for less (and not pulled over for more). It is very true - they do have bigger fish to fry. I didn't state that the OP'r "would" be pulled over - I merely stated what the Ontario laws are. See my above comment re: imported Camaros (and other cars). Upon importation all vehicles to be registered to a Canadian address must first pass a vehicle safety inspection administered by the related provincial transportation ministry.
| Push Start button? | CG'sSS | Camaro DIY & HOW-TO instructions & discussions | 158 | 06-06-2012 07:27 PM |
| We need help with Electronics wiring diagrams | 2SSRS@Gen5diy | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 11 | 12-13-2009 05:58 PM |
