02-15-2011, 08:42 AM | #1 |
Drives: 1LT/RS, VR, GFX Join Date: Mar 2009
How often to balance wheels?
Hi all,
I'm just wondering how often I need to have my wheels balanced. I have a set of summer tires on rims and a set of winter tires on wheels, should I reblanace them every time I change them? Thanks! |
02-15-2011, 08:51 AM | #2 |
No, once a set of tires/wheels has been balanced once, they should be good. That is until you remove the tires from the wheels again. Or unless some of the weights have fallen off.
02-15-2011, 09:06 AM | #3 |
Drives: 2010 2SS IOM L99 Join Date: Jan 2010
+1
02-15-2011, 03:26 PM | #4 |
Good to know, thanks.
What would be a typical indicator that I need re-balancing? Vibration? Noise? Something else? |
02-15-2011, 03:33 PM | #5 |
02-15-2011, 05:56 PM | #6 |
cool, thanks!
02-15-2011, 08:09 PM | #7 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
Tires will go out of balance. You can flat spot them on braking or accel...or just plain wear. Rebalance as needed and some tires are bad from the get go and a good tire shop will replace if a balancing issue is there.
I am lucky as we have a shop here that high speed balances the tires on the car/truck with a strobe. It balances the tire, wheel and rotors etc...if needed they can true the tires to fix flat spots etc...like driving on glass if you can find such a shop that knows what they are doing...must mark the wheel/tires when you take them off for work so to put them back on the same stud/location as balanced. Next best balance I have found is the road force at DC tire. |
02-15-2011, 11:36 PM | #8 |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
on all my pickups I have used equal to balance my tires - they never go out of balance. (the stuff semi trucks use to balance their tires)
but on the Camaro, I would imagine stick-on weights once with new tires and rebalance if its ever needed.
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
02-16-2011, 08:16 AM | #9 |
THanks for the input guys!
Similar Threads | ||||
SA CHEVY's fund my wheels thread... | SA CHEVY | Local Marketplace | 139 | 07-26-2011 02:14 PM |
Factory Reproductions 22" Replica wheels | Blacky | Vendor and Seller review / feedback / experiences | 56 | 02-18-2011 03:37 PM |
Psycho Mike Buys A Caddy And Gets Savini SV-32s Wheels | Savini | Off-topic Discussions | 1 | 01-12-2011 11:13 AM |
VIP Forged Wheels For Sale | EVS Motors Inc. | Wheels / Tires | 45 | 01-19-2010 05:13 PM |
Wheels! Your Camaro needs forged wheels. | Nine Ball | Wheels / Tires | 42 | 12-21-2009 10:51 AM |
