![]() Drives: 2011 Synergy Green LS Join Date: Feb 2011
I just bought my 2011 Camaro LS Synergy green and all ready have the bug to personalize it. My question is, can u take the brakes off of a new Camaro SS and bolt them directly onto my LS? I do realize I will have to upgrade my rims as well because my car came with the black steel rally wheels. I have found a set of front breaks all ready for a hell of a price, just looking now to find the rear set, but before I spend 5 or 6 hundred dollars I want to know if it is possible and how hard it is to do if it is possible.
Any help or suggestions would be appreciated.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Mazda6, 2011 Mustang 5.0 Join Date: Mar 2010
You'd probably need the SS wheels too. I've heard the LS wheels don't have enough clearance.
2022 1SS 1LE (Arrived 4/29/22)
"The car is the closest thing we will ever create to something that is alive." |
![]() ![]() Drives: 2011 2SS/RS SGM Join Date: May 2010
yep, you need the SS wheels, your ls wheels wont clear the brembos
---2011 synergy green 2SS/RS---
09/27/2010 - (3800) 10/01/2010 - (4200) 10/09/2010 - (4800) Vehicle on final destination route 10/19/2010 - (5000) delivered to dealer 11/19/2010 - (6000) delivered to customer |
I am going to get new rims. Haven't decided if I am going to go with a stock looking set of black 20" SS wheels or go up to a custom set of 22"s. I just don't want to spend a ton of money on rims if I have to keep the ugly calipers that are on my 18"s.
![]() Drives: 2010 Camaro LS Join Date: Feb 2011
Depends on cost
I would go for 20." You would have to think of long term cost. When you have to replace the rubber on the 20" is a lot cheaper than tires for a 22" rim.
#6 |
knows 2 facts about ducks
You need the SS rotors as well.
#7 |
BOD 5/28/09 #13485
Drives: 2010 Camaro 2LT RS Join Date: Jan 2009
What you will need.
Front and rear calipers. Front and rear rotors. Front and rear brake lines. I recomend a SS Master cylender. You might as well flush out the brake system with high temp brake fluid wile you are at it. Tires and rims you already know.
#8 |
I've done this. You need lines, rotors, calipers (w/ hardware), pads, and brake fluid. You can either use the OEM fluid, or upgrade.
I used R1 concepts rotors, Pedders lines, Hawk ceramic pads, and Super Blue DOT4 brake fluid. It's not a direct bolt on in the back. You have to trim the dust shield to allow the bigger rotor. You'll see what I mean with the wheel off. Check this thread
[B]
| Camaro Product Manager - interview | Moose | 5th Gen Camaro SS LS LT General Discussions | 11 | 04-04-2012 07:10 PM |
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 01:25 PM |
| Modern Camaro Performance - Lowest Prices Anywhere! | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 11-03-2010 11:50 AM |
| GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 08:33 PM |
| Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 06:33 PM |
