Old 02-20-2011, 02:26 PM   #1
marticus24
Drives: 2012 ZL1
Will a cam change the exhaust note?
Question is simple: will a cam change the NOTE of the exhaust? I understand there will be a change to the rhythm/added lope, but will it actually change the tone?
marticus24 is offline   Reply With Quote
Old 02-20-2011, 02:31 PM   #2
Russell James
Russell James's Avatar
Yes. In several ways. Valve timing can increase or decrease the effective compression which changes the sound. An earlier opening exhaust valve event will make it louder as your hearing more of the combustion. A tighter LSA and more overlap will make it louder...
I changed the cams in my Harley that had about 20 deg earlier opening intake valve, and 16 deg earlier opening exhaust valve... and it is much louder now. Due to the increased compression from the intake opening sooner ,and with the exhaust valve opening so early, you really hear the exhaust bark.
The OEs won't use timing like that though because of emissions. They want all the combustion to occur in the chamber by using little overlap and late opening exhaust.
Old 02-20-2011, 02:35 PM   #3
Revo1
Don't Like it? Suggit.
Drives: 2010 2SS/RS
Considerably.
EG:
Old 02-20-2011, 02:41 PM   #4
IROCanSS
Drives: 89 IROC 350
Yep
Old 02-20-2011, 04:52 PM   #5
marticus24
Drives: 2012 ZL1
Thanks guys!
Now - 2nd question... has anybody with a similar setup to mine done a cam and have a vid/audio clip?
I'm running Kooks LTs, catted mids, rotofab cai, and borla s-type cat back...
Old 02-20-2011, 05:19 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
my car got louder with a cam. not just at idle
Old 02-20-2011, 06:26 PM   #7
Kurtisp
Kurtisp's Avatar
Drives: 2010 Camaro 2SS/RS Inferno Orange
Originally Posted by marticus24 View Post
Thanks guys!
I have somewhat the same exhaust setup as you.. Watch the end of the vid in my thread when I close the cutouts, I'll get some more vids after I get it tuned
My mufflers are magnaflow
Kurtisp is offline   Reply With Quote
Old 02-20-2011, 06:35 PM   #8
marticus24
Drives: 2012 ZL1
Please do post another vid after you get tuned, perhaps similar but with cutouts closed. I'm really trying to gauge how things will sound with a cam.
I'm considering Livernois' 2c cam.
Thanks for all the input all, keep it coming
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
Thinking about going 2.5" the entire System mike.nite Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 01-11-2011 04:57 PM
How's the exhaust note?? Spyderseal 5th Gen Camaro SS LS LT General Discussions 33 12-03-2009 05:19 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 04:09 PM
