Old 02-21-2011, 04:12 PM   #1
TooCool5
TooCool5's Avatar
(updated with pics)How many Charging volts does your V6 run.
Car runs great, but as I go through the DIC menu and check the volts, I am always running 15.3 - 14.8. Even after a 1/2 hr drive.
On the older cars that would be considered high and an overcharge situation.
Just wondering if that's normal and what everyone else is seeing?
Probably just spinning my wheels.
I plan to put my digital ohm meter on the terminals under the hood next time I start it up to see if the gauge is flaky.
Old 02-21-2011, 04:21 PM   #2
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
My radar detector shows me the voltage and I am on 14.1 - 14.3
skuttduck is offline   Reply With Quote
Old 02-21-2011, 04:33 PM   #3
TooCool5
TooCool5's Avatar
OK, so does the radar detector agree with your DIC dash readout?
Old 02-21-2011, 04:35 PM   #4
skuttduck
skuttduck's Avatar
I've never done that on the DIC before. I'll be more than happy to look at it on my 4 mile drive home.
Old 02-21-2011, 04:46 PM   #5
TooCool5
TooCool5's Avatar
Thanks, do you ever see 15 volts on the detector?
Old 02-21-2011, 05:30 PM   #6
skuttduck
skuttduck's Avatar
I couldn't find it on the DIC. Is yours a 2011?
Was it on the HUD?
Anyhow I never see 15 on the radar detector. 14.1 to 14.3 is where it runs at while driving.
Sent from my DROID2 using Tapatalk
Old 02-21-2011, 05:32 PM   #7
TooCool5
TooCool5's Avatar
Was it on the HUD?
It is in the second menu screen, you have to press the button on the turn signal stick facing you, then scroll through the screen. (The tire pressures are here also).(
Old 02-22-2011, 09:19 PM   #8
skuttduck
skuttduck's Avatar
I still couldn't find the damn thing in the DIC.
BTW, I had voltage of 14.8 14.9 on the drive home today.
On the longer drive out to a guys house I was running about 13.8.
It handled admirably on the snow with the Pirelli scorpion ice and snow tires. I also got to try it out on pure ice. Lets say that with a slight incline and pure ice the car goes nowhere. I had to backup and get momentum.
Old 02-24-2011, 11:00 AM   #9
TooCool5
TooCool5's Avatar
On the DIC all you do is press the Menu button on the turn signal stick, then use the outer roll switch to scroll through the second menu.
OK I made some readings before taking the car on a long drive yesterday.
12.1 volts standby voltage (car off).
14.7 volts upon starting the car then it slowly creeps up to almost 15.4 volts.
15.3 steady volts while making 3 different trips 30 - 40 mins. each.
15.0 volts after driving the car all day multiple places almost 2 hrs total.
Car volts always ran high about 14.7 volts since new but not this high. Maybe I got a bad battery from the factory.
My voltmeter agrees with the dash readout.
I wonder if I got a bad battery and the BCM is constantly trying to charge it.
Anyone with a 2010 Camaro that can give me what their voltage readings are?
Old 02-24-2011, 03:18 PM   #10
skuttduck
skuttduck's Avatar
I kid you not, my second menu with the tire pressure does not have the battery voltage. Your fuel economy is better than mine. Mine is mostly city but I have been getting average of 20.8 and it went down from 21.1 from around Christmas.
Old 02-24-2011, 08:04 PM   #11
skuttduck
skuttduck's Avatar
Where the Battery Voltage is based on the line at the bottom, mine says Engine coolant, and gives the temp.
I've tried pressing set/clear to see if it would change and it doesn't.
Old 02-25-2011, 01:41 AM   #12
Hephaestus1
Hephaestus1's Avatar
Drives: 2010 2LT/RS A6
I am thinking the confusion may be a 1LS versus 2LT thing. I don't have voltage on my DIC either, but I suspect that is because the RS has the 4-pack guages. If I can believe that the guage is linear (which it clearly ain't), mine always hovers at or slightly below 15V (the 3rd white mark). The guage markings are 9 [red], white, 12 [white], white, 19 [red]. I should be able to whip out the DMM in the next day or so...
I know that in the colder winters, my TA would start charging pretty high, and eventually back down with driving to around 14-ish.
Hephaestus1 is offline   Reply With Quote
Old 02-25-2011, 01:56 AM   #13
C586
Drives: 2011 Camaro LS
Mine is always around 15 as well. Never settles below 14.8. I was going to make a thread asking about it tomorow as I have never seen voltage this high on any car unless something was wrong.
C586 is offline   Reply With Quote
Old 02-25-2011, 06:54 AM   #14
garcmol
garcmol's Avatar
OP, mine reads the same range 14.8 - 15.3
I wish I had that gas mileage! Mine always hovers around 20.5. M6
V6 Gas Questions Markal Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 25 06-28-2010 03:49 PM
V6 Cami VS V6 Genesis..LOL MillerTime Chevy Camaro vs... 226 06-09-2010 10:00 AM
2011 mustang v6 vs 2010-11 camaro v6 mr_desmo Chevy Camaro vs... 347 04-24-2010 06:23 PM
Solo Performance V6 Mach-XL (Manual) and Mach-XLT (Auto) Exhaust Kits GOINGSOLO2 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 12-03-2009 02:59 PM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
