![]() Drives: 2019 1SS 1LE Join Date: Feb 2011
Automatic vs Manual - lifetime, repair costs
Hi guys,
I'd like to buy 1LT RS Camaro in few months, but still I have a dilemma. Car will be used quite often (20 000 miles per year) with rougher usage sometimes. I am thinking about one with manual transmission, but if the repair costs (clutch change etc.) could be too high, maybe I will change my mind to automatic. So questions are: - What lifetime can have automatic transmission compared with manual in same conditions of use? - What are usual repair costs diferences between manual/automatic? thx, Toni |
Alot of difference.
Clutch every 2 years depending on how you drive it. That can run you about $500-$1k if you cant do it youself. Cant speak for a Gen5 automatic but my Gen4 TA it was just a transfilter every and trans fluid change every year. $50 tops on that. |
Allergic to stupid.
Drives: 2015 ZL1 #957 M6 AGM & 1990 Z24 Join Date: Aug 2010
What are you doing to go through a clutch in 2 years? I still have the original clutch in my 1990 Z24 and I put some abuse on it early on.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 c7 Join Date: Nov 2009
![]() Drives: 2012 2SS/RS M6 AGM Join Date: Jan 2011
Today's automatics are very reliable, but so are today's clutches.
We've been driving various manual transmission vehicles over the last 30 years and have NEVER replaced a clutch since 1979. Our current MT vehicles have 92k and 131k miles. If you plan to drive in heavy traffic a lot, you'll want to consider the automatic. Another factor to consider is the clutch may not be completely covered under warranty (wear-out item), but the entire AT will be. The automatic will require a fluid & filter change every 50k miles. The manual will need a clutch fluid flush every 50k, or so. |
#6 | |
if i was planing on putting 20k a year and doing allot of city driving, i would go with auto.
#7 |
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS ) Join Date: Nov 2009
Replacing a clutch on the Camaro is not overly difficult, you can do it yourself with a minimum of hassle. On the other hand, automatic transmissions are a real monster to repair; I personally swore off ever doin' that sticky fluid, tiny springs, minuscule float bearing rebuilding work in 1974 on a Mercury...
#8 |
![]() Drives: Y2000 Olds Intrigue Join Date: Feb 2011
The repair cost today on an automatic has become very cringe-worthy. The old 3 gear automatics up through the 1970s were not a big deal, you could pick up a rebuild for $500 or so. The electronic transmissions of today are much more intricate and you're looking a fat four figure $ to replace one.
As far as I'm concerned a properly maintained transmission should last the life of the car! I've had several cars now at 150,000 to 250,000 miles and none of them needed a rebuild. Keep the fluid clean and don't drag race, or tow something heavy. |
#9 |
As I said it depends how you drive. I have replaced clutches in car from people burning them up every 2 years.
#10 | |
Banned
Drives: 2003 Cobra Convertible Join Date: Feb 2009
My stock clutch on the cobra went over 80,000 mi at over 500 hp. And the only reason I replaced it was due to the throwout bearing going out. A stock clutch should be able to go over 100,000 miles easily, more like 150,000. And even then, it's not that expensive. Auto's can go 200,000+ mi. too, but I have also seen modern auto's crap out at as early as 40,000 mi. |
#11 |
![]() Drives: Camaro LS M6, Fiero, Ford F100 Join Date: May 2010
In 25 years of driving, I've only replaced 2 clutches on 2 out of the 9 cars I've owned... not too bad.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Manual transmissions tend to require more repairs than automatics. This is according to my mechanic who works on LSX vehicles everyday for a living.
#13 | |
I do drive 20k plus a year and you'll be in pure hell without an auto. You'll also be in pure hell driving a Camaro that much with compromised sight lines, get a compact.....
#14 |
![]() Drives: 2010 Synergy Green Camaro Join Date: Jun 2010
A Camaro with a manual trans will cost 995.00 less than an automatic.That is extra Mod Money
| Tags |
| automatic, diferences, manual, repair costs, transmission |
| Acronyms? | KEEP RT | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 20 | 03-11-2011 08:57 PM |
| And Another Car Crash... | GTAHVIT | Off-topic Discussions | 73 | 01-12-2009 11:43 AM |
| looking for 2nd gen repair manual? | [KRPT]ECP | 1st & 2nd Generation Camaros | 4 | 02-27-2008 05:02 PM |
