![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2LT/RS/GFX/M6 Join Date: Jan 2010
Rear Bumper Alignment
Alright, had to take off the bumper in order to get the gfx bezels out. After I finished doing my work I put the bumper back on but the spacing seems to be millimeters off. I noticed it specifically on each side in the lower part of the bumper where the side marker light is. Anyone here remove their bumper and get it back on with the factory spacing?
Got the wife over naging about once you take it off it will never be the same. I am on a mission to prove this woman wrong!!!! I am guessing I missed one of the fasteners? The spacing problem seems to be on both sides evenly. Ill post pis here shortly. ![]()
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
NEcamaro5
I've had mine off and didnt look. Now I have to go and check mine. I did notice that when I put mine back on I took extra care to make thowe tabs to line up. I had to do the drivers side twice.
Last edited by chevy 3; 02-28-2011 at 06:12 PM. Reason: Didn't finish hit wrong button |
Well when I took it out I tried to make sure I snapped everything in correctly. The seam just seems to be off a little. There are no obvious bumps in the bumper like if I had missed a fastner.
Blowin the doors off!
Drives: A 2013 SS RS 6M SR Join Date: Apr 2010
Sometimes they just never go back in EXACTLY like they came off.. sucks..
2G1FS1EWXD9163847 |
dammit noooo!
#6 |
Doc
Make sure the screw is tight in the fender well and I think there were clips in that area too. Mine lined up fine, no issues here.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
#7 | |
There's the thing. I had to loosen that screw a considerable amount when I originally put it back on because it would make that tip of the bumper that's nearest to the wheel poke out. It just doesn't look lined up like it did. I may try to loosen the other two torx screws in the wheel well tonight, pry off the bumper on the sides and see if I can get it back. I just hate to keep pulling off the bumper.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
Loosen everything up and try to realign it. Alternate rt/lt corners when you tighten it up. Take your time and don't go more than 2 turns per screw.
#9 | |
Doc
#10 |
NEcamaro5
That screw on the end needs to be lined up better. If the edge sticks out then it's def off a little. Just take your time and use a light too make shore they'd line up good.
#11 |
US Navy Vet
Drives: 2011 2LT/RS, 65 Mustang GT Fastback Join Date: Oct 2009
When I was putting in my rear LED side markers and popped out the sides of each bumper I initially had the same problem with getting the lip to line back up again. What I found was that the inner liner was not going over a part on the bumper that is nearest the lip. Once I corrected that it lined up again. Something to check anyway.
2011 - 2LT/RS - RY, A6, Gray Interior - Team LLT:
3rd Camaro on this forum to have a Mylink installed. Installation by GEN5DIY, Heritage Grill, Lloyds Premium Ebony Camaro RS floor mats, Empire Billet Camaro Black sill plates, AAC: LED footwell & interior lighting, Rear Courtesy Lights, LED side markers/turn signals, Plasma P13W DRl bulbs, Formula 1 Pinnacle Series tint, Roto-Fab Yellow CAI & Fuse cover, Technostalgia Afterburner LED taillights, EmblemPros custom V6 hydrocoated carbon fiber/RY engine cover, Pfadt Sport sway bars, Ofer's Backup Camera, and full Brembo brake conversion. ![]() |
#12 |
![]() Drives: 93 Transam, 2SS ABM White Rally Join Date: Jul 2009
gOOD INPUT GEARHEADPETER
#13 |
US Navy Vet
Thanks as I figure will all of us doing mods on our cars one of us has had to see the problem.
#14 |
Yes thanks for the input! I plan on trying to realign it tonight and see what I get.
| FS: Rear bumper cover, GM car cover, CAMARO badging | SuperSport17 | Local Marketplace | 2 | 05-20-2014 08:31 AM |
| WTB: Stock Rear Bumper Assembly 1SS | jaymd17 | Exterior Parts & Accessories | 1 | 01-08-2011 05:31 PM |
| reverse led install: help with rear bumper | Captain McFunk | Cosmetics and Lighting Modification Discussions | 3 | 12-26-2010 02:57 PM |
| Rear Bumper Damage | shankomatic | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 3 | 07-27-2010 04:58 PM |
| Rear Bumper (?) Removal | l008com | Camaro DIY & HOW-TO instructions & discussions | 0 | 02-09-2010 07:23 AM |
