03-01-2011, 01:19 PM | #1 |
Drives: 2023 ZLE Join Date: Jun 2009
Kooks LT - Coated or Not?
Getting ready to purchase a set of Kooks and was wondering what you all that have them think. Is the coating worth the extra money?
03-01-2011, 01:21 PM | #2 |
Drives: 2015 c7 Join Date: Nov 2009
not worth it.
03-01-2011, 01:23 PM | #3 |
03-01-2011, 01:36 PM | #4 |
Drives: 10 2SS/RS Black, 99 Daktota Join Date: Apr 2010
Its a constant item of debate weather its worth it to coat. I did a fair amount of looking myself found that there is very little performance benefit to doing this. Yes, it will keep the temperature under your hood down, there-by reducing your IAT. Yes, it will keep the heat in the exhaust, which ups the exhaust gas temperature and therefor as I understand it, will increase the speed of the exhaust flow, again, only by a very small amount. What it came down to for me, was i want these headers to last me the life of the car, that's why i was decided to go Kooks in the first place and not a mild steel or Chinese knock off. So I figure if I am going to keep them on my car for a long long time, a few hundred dollars up front to coat them and keep them looking great will average out to a pretty small amount of $ over the life of the header. The coating will not really help the headers last longer, but it will help them look good longer and in the end that was enough for me to justify the extra dough.
YMMV.
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
03-01-2011, 01:37 PM | #5 |
i would rather put that 200+ towards a different mod. i rarely pop my hood open to look at the engine and even to show a friend. if i had the shiny supercharger, then maybe i would want to get the coated headers.
03-01-2011, 01:46 PM | #6 |
THAT BOOST TURNS HEADS
Yup +1
SoCal HT5 ENOUGH SAID
03-01-2011, 01:52 PM | #7 |
Drives: '69 SS Convertible Join Date: May 2009
I did it for the cosmetic looks of it. Mine will be nice and shiney for years to come. I show my car as well as take it to the track. For me it's worth the $200 for cosmetics of it all. Actually it's worth $275 because that's what I had to pay to get mine coated after the fact.
IMO if you can afford it and you are remotely even thinking about it then spend the money. You don't want to be kicking yourself later and then have to deal with pulling them off and paying extra money to have them blasted and then coated. If looks are no big deal then don't spend the money.
Build Journal |
03-01-2011, 02:02 PM | #8 |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
http://www.camaro5.com/forums/showthread.php?t=127215
theres your answer.... it may not be an issue up north. I wanted to keep the IAT down because of the Florida heat and to keep my CAI from already sucking in warm air here... 139 dollars on maryland speed..
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
03-01-2011, 03:10 PM | #9 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
I'd get them coated. I have uncoated now, and when I open the hood after a drive it is blazing hot under there. I'll probably be taking them off and getting them coated soon.
03-01-2011, 03:13 PM | #10 | |
03-01-2011, 03:18 PM | #11 |
Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
Absolutely get them coated. For the 150.00 it is well worth it for the heat and the cosmetics.
03-01-2011, 03:33 PM | #12 | |
Drives: 2010 2SS/RS IBM / Silver Stripes Join Date: Mar 2010
Russ, If you don't mind, where would you send your headers to be coated? Do you know of a business in Michigan that does this type of work? Just wondering, all I've heard of is the "Jet Hot", which I guess is fine, but would like something closer. M |
03-01-2011, 03:55 PM | #13 | |
v It bites.
Point in case OP...if you want them done, have them done now at time of purchase by some vender here on Camaro5.com Otherwise you will have to personally locate a shop and ship them away....
2011 2SS/RS
03-02-2011, 11:00 AM | #14 | |
Similar Threads | ||||
Official 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 3652 | 08-17-2023 02:50 PM |
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
Manual vs Auto GTAHVIT vs PQ... The video wars. | 76z28 | 5th Gen Camaro SS LS LT General Discussions | 443 | 08-26-2010 12:26 PM |
Kooks LT + Borla Touring = Loud | SS Drifter | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 07-07-2010 10:35 PM |
9/11 Never Forget | Curt@BMCPerformance | Off-topic Discussions | 29 | 09-11-2009 12:04 PM |
