![]() Drives: 2011 Camaro SS 2SS/RS Join Date: Aug 2010
Technical question, Stock throttle body size?
Does anyone know what size the stock Throttle body is on the LS3? I am thinking 90mm But not 100% certain on that, Can anyone shed some firm advice on this?
Thanks All; Scottie
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
The LS2/3 are 90mm.
Exactally what I was thinking... I appreciate the info
![]() Drives: 2011 Camaro 2SS Convertible Auto Join Date: Jul 2020
is that the same for the L99?
![]() Drives: 2010 Chevy Camaro 2SS W/RS package Join Date: Apr 2020
So if I was to get a 92mm would the stock computer compensate for the extra 2mm?
#6 |
![]() ![]() ![]() Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
i wouldn't waste the money on 2mm.
what other mods have you done that necessitate a larger throttle body? |
#7 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Stock throttle bodies are capable of 1500+ hp. No reason to change it
#8 |
![]() ![]() Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
#9 |
![]() Drives: Silver 2014 Camaro 2SS Join Date: Dec 2018
I’ve debated a larger TB myself. But if stock TBs work perfectly fine for 1500hp, why is there a marker for aftermarket? Does aftermarket really have any added performance over stock?
2014 Silver 2SS L99 with Roto-Fab CAI, Kooks LT Headers, Kooks Cat-less 3” exhaust, TS Stage 3.2 VVT CAM, Circle D 3200 Stall, E85 Kit, FIC 850cc injectors and Elite Engineering Catch Can. Dynoed at 478rwhp.
#10 | |
$ to hp ratio may leave you wanting to spend that money in other places first.
#11 |
693RWHP w/o nitrous
Drives: '12 Camaro SS, Whipple 10.93@128mph Join Date: May 2022
I have a 2013 L99 that I have a 3.0L Whipple I just put on a couple months ago and was thinking about putting a 103mm on. Any educated opinions??
#12 | |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
#13 | |
| L99 Auto 2nd Gear Question | ChevyMuscle | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 14 | 02-02-2011 07:21 PM |
| ADM Performance Ported Throttle Body = 6rwhp + 6rwtq | Number_9 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 31 | 05-25-2010 07:11 PM |
| Throttle Body Porting | lxporting | V8 Bolt-Ons & Tunes | 133 | 05-10-2010 12:23 AM |
| Ported throttle body sale | matt d. | V8 Bolt-Ons & Tunes | 3 | 11-24-2009 12:11 AM |
