Old 03-03-2011, 03:18 AM   #1
snakekiller
Drives: f150
2012 Boss 302 track test
Vehicle: 2012 Ford Mustang Boss 302 Laguna Seca
Odometer: 2,489
Date: 3/1/11
Driver: Mike Monticello/Chris Walton
Price: $47,990
Specifications:
Drive Type: Rear-wheel drive
Transmission Type: Six-speed manual
Engine Type: V8
Displacement (cc/cu-in): 4,951/302
Redline (rpm): 7,500
Horsepower (hp @ rpm): 444 @ 7,500
Torque (lb-ft @ rpm): 380 @ 4,500
Brake Type (front): 14.0-inch one-piece ventilated cast-iron discs with four-piston fixed calipers
Brake Type (rear): 11.8-inch one-piece ventilated cast-iron discs with single-piston sliding calipers
Steering System: Electric-assist rack-and-pinion power steering with three driver-selectable modes (Comfort, Normal, Sport)
Suspension Type (front): Independent MacPherson struts, coil springs, adjustable five-mode variable dampers, stabilizer bar
Suspension Type (rear): Solid axle, coil springs, adjustable five-mode variable dampers, stabilizer bar
Tire Size (front): 255/40ZR19 Z
Tire Size (rear): 285/35ZR19 Z
Tire Brand: Pirelli
Tire Model: P Zero Corsa
Tire Type: Summer
Wheel Size 19-by-9 inches front -- 19-by-10 inches rear
Wheel Material (front/rear): Aluminum
As Tested Curb Weight (lb): 3,620
Test Results:
Acceleration
0 - 30 (sec): 1.9
0 - 45 (sec): 3.3
0 - 60 (sec): 4.6
0 - 75 (sec): 6.4
1/4 Mile (sec @ mph): 12.7 @ 112.9
0 - 60 with 1-ft Rollout (sec): 4.3
Braking
30 - 0 (ft): 26
60 - 0 (ft): 105
Handling
Slalom (mph): 70.4
Skid Pad Lateral Acceleration (g): 0.99
Sound
Db @ Idle: 54.9 (standard key), 58.8 (TracKey)
Db @ Full Throttle: 84.8 (both keys)
Db @ 70 mph Cruise: 69.7 (standard key), 70.1 (TracKey)
Link:http://blogs.insideline.com/straight...guna-seca.html
snakekiller is offline   Reply With Quote
Old 03-03-2011, 05:26 AM   #2
a_Username
a_Username's Avatar
Drives: 2010 2SS Camaro
Besides the handling, that was a... disappointing read. Maybe this is an example of terrible driving? Meh, only more car rags will tell.
a_Username is offline   Reply With Quote
Old 03-03-2011, 07:21 AM   #3
SSmoked
SSmoked's Avatar
Drives: '12 Camaro ZL1 #1255
^^ i have to agree. maby this is car is better on the track than it is on paper.
i mean the camaro ss, is just a little bit slower in alot of those test. and a nice set of coilovers will make the ss run with the boss 302. the ss is 20 hp down and 200pounds heavier than the boss that is practicly using r-comp tires...
Camaro ss via inside line. the ss is also 10k cheaper.
Drivetrain
Drive type Rear-wheel drive
Engine type V8
Displacement (cc/cu-in) 6,162 cc (376 cu-in)
Block/head material Aluminum/aluminum
Valvetrain Overhead valve
Compression ratio (x:1) 10.7
Redline (rpm) 6,600
Horsepower (hp @ rpm) 426 @ 5,900
Torque (lb-ft @ rpm) 420 @ 4,600
Transmission type 6-speed manual
Track Test Results
0-45 mph (sec.) 3.4
0-60 mph (sec.) 5
0-60 with 1 foot of rollout (sec.) 4.7
0-75 mph (sec.) 6.7
1/4-mile (sec. @ mph) 13.0 @ 110.9
Braking, 30-0 mph (ft.) 27
60-0 mph (ft.) 109
Slalom, 6 x 100 ft. (mph) 68.6
Skid pad, 200-ft. diameter (lateral g) 0.88
Dimensions & Capacities
Curb weight, mfr. claim (lbs.) 3849
Curb weight, as tested (lbs.) 3857
SSmoked is offline   Reply With Quote
Old 03-03-2011, 09:03 AM   #4
Sawyer
Sawyer's Avatar
Drives: '13 5.0
Sawyer is offline   Reply With Quote
Old 03-03-2011, 09:58 AM   #5
THE EVIL TW1N
Banned
Drives: 2003 Cobra Convertible
im not sure what the point is of having the redline right at peak power for the boss. Im sure a tune will do wonders for these. Thats most likely why the stock numbers are what they are despite it putting down over 45rwhp more than an LS3 Camaro SS.
THE EVIL TW1N is offline   Reply With Quote
Old 03-03-2011, 12:26 PM   #6
Stew
Drives: 92 Luminadead/01 Dakota/97 F150 4x4
Oh boy, get ready for all the posts proclaiming the Boss is overpriced.......
Stew is offline   Reply With Quote
Old 03-03-2011, 12:36 PM   #7
truth411
Drives: 2022 SS 1LE
Finally someone agrees with me. push the redline back to 8k - 8.2k and a tune would do wonders.
truth411 is offline   Reply With Quote
Old 03-03-2011, 01:13 PM   #8
Mr Twisty
Mr Twisty's Avatar
.......... despite it putting down over 45rwhp more than an LS3 Camaro SS.
try again
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
Old 03-03-2011, 01:45 PM   #9
THE EVIL TW1N
Banned
try again
ok, 46rwhp if you want to be specific.
Old 03-03-2011, 02:49 PM   #10
rez333
Drives: 2013 ZL1
I'm surprise this car is so heavy. The Ford Racing models are quite close to 3000lbs. What's the point of removing the rear seats if it's still so heavy?
rez333 is offline   Reply With Quote
Old 03-03-2011, 03:04 PM   #11
cab2g
love. my. car.
cab2g's Avatar
Drives: 2011 2SS/RS
hey, any car that rotates the camshaft to give a more aggressive growl with a key is ok in my book! That being said, any car that I can't afford is too expensive. So that also means that the Chevrolet Suburban 4wd edition is too expensive too All cars should cost under 30k starting so I can afford them!
cab2g is offline   Reply With Quote
Old 03-03-2011, 03:24 PM   #12
nester7929
Rice Harvester
nester7929's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Sounds like a crappy driver. People are getting those times from stock 5.0's.
nester7929 is offline   Reply With Quote
Old 03-03-2011, 04:00 PM   #13
Sax1031
Drives: 2000 Mustang GT
my guess would be they needed the driver mod
evan smith is who I want to see drive the thing.
Sax1031 is offline   Reply With Quote
Old 03-03-2011, 08:13 PM   #14
Mr Twisty
Mr Twisty's Avatar
We'll get specific when the cars ship and hit the dyno's.... Mustang's are usually spec'd on the high side by, ohh, 20% ?
Thing needs torque, that's for sure
... oh wait, it's a 302... nevermind
lib·er·ty
/ˈlibərdē/
noun
1.
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 12:30 PM
2012 Boss 302 burnout snakekiller General Automotive + Other Cars Discussion 45 02-27-2011 02:46 PM
2012 BOSS 302S model specs.... assasinator General Automotive + Other Cars Discussion 15 12-06-2010 09:21 PM
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 05:20 PM
Car and Driver Drives the ZR-1 at GM's MCR test track drummerstevey General Automotive + Other Cars Discussion 13 09-02-2008 06:22 PM
