Old 03-06-2011, 12:29 AM   #1
Busy_Boi
SoCal C5 Family Member
Busy_Boi's Avatar
Drives: RJT 2010 camaro 2SS
Send a message via Yahoo to Busy_Boi
418 Stroker Built @ 2Edge Performance
3 weeks ago I put my 2010 Camaro in the shop at 2Edge Performance in Costa Mesa, Ca for a 418 stroker built. I want to build a more reliable motor for my supercharger so I decide to forge my internal. When I had the car towed to the shop I thought I only had a bad lifter because of the tapping noise in the motor. But after the engine was taken apart they found out that I had two pistons that was badly damage so I felt a little lucky I was planning this built. I had got some input from a member here that already had this built and I would like to thank Larry/2010 SS RS for his advice and the guys at 2Edge Performance Chris Johnson and Rick Andrade/ URR2slo. Here is an article that Chris sent to me that will help some people to understand the LS3 motor a little better http://www.chevyhardcore.com/tech-st...rviving-boost/. Here are some pics as of now of the built.
418 Stroker L99/LS3 Built
RotoFab Intake
Lingenfelter L99 Conversion to GM LS3 kit
Callies 4" crank, 6.125 Compstar rods
CP Racing Pistons 4080 -13.8 pistons
JRE Fuel Upgrade
JRE Blower Cam (Smooth Idle)
Edelbrock E-Force Supercharger 2.75 pulley
CNC Ported Heads
Vmax TB
Kooks 1 7/8 Headers
DynoMax Mufflers 3' pipes
LME Dual Fuel Pump
Injector Dynamics 850cc
Yank 3000 Torque Converter
ATI Super Damper 2% Underdrive
CSF Custom Radiator
DSS One Piece DriveShaft
DSS 1400hp Axles
BMR Toe Rods and Trail Arms
3.45 rear end gears
6L80E / 6L90E PATC Build http://www.transmissioncenter.net/6l...arts_6l90e.htm
Busy_Boi is offline   Reply With Quote
Old 03-06-2011, 01:12 AM   #2
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Nice build ya got goin there....Larry's and mine were built side by side, your gonna love it.
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 03-06-2011, 01:36 AM   #3
Busy_Boi
Busy_Boi's Avatar
Thanks Teddy I got the JRE smooth idle cam. And I cant wait to feel that slap u in the face torque. I forgot to add that my car is an L99 being converted to an LS3.
Old 03-06-2011, 06:44 AM   #4
2010 SS RS
2010 SS RS's Avatar
Drives: 2010 2SS/RS IBM Black Polished
I cant wait to hear what you think after its done...You are going to freak out for sure when you feel the torque change..lol
Congrats and thanks for all the conversations. Team Edelbrock rolls on! Larry
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
2010 SS RS is offline   Reply With Quote
Old 03-06-2011, 11:19 AM   #5
Busy_Boi
Busy_Boi's Avatar
Old 03-06-2011, 11:36 AM   #6
Nice
Old 03-06-2011, 11:53 AM   #7
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
Are you using your block or did you order a short block?
MODS:
Old 03-06-2011, 01:02 PM   #8
Busy_Boi
Busy_Boi's Avatar
I am using my block it has been machine for the piston.
Old 03-06-2011, 02:22 PM   #9
NEGXXIS
NEGXXIS's Avatar
Drives: 2019 Camaro SS A10
Very nice
I am in the middle of almost the exact same build up. good luck with your project.
2020 Range Rover Sport HSE P525 Supercharged 5.0 - Firenze Red - 9012 wheels
SOLD 2019 Camaro SS -Wrapped in Matte Magnectic Black - Anderson Carbon Hood and Rear Spoiler – Ikon front spoiler – OEM ZL1 Side Rockers - ZL1 Addons Diffuser - BMR 1.0” Lowering Springs - MRR 228 Wheels 20x10 and 20x11
RIP 2016 Camaro SS https://www.camaro6.com/forums/showthread.php?t=565453
SOLD 2010 Camaro SS Featured in GM High Tech Performance and Camaro Now Magazines - http://www.superchevy.com/features/g...of-perfection/
NEGXXIS is offline   Reply With Quote
Old 03-06-2011, 03:14 PM   #10
Busy_Boi
Busy_Boi's Avatar
Originally Posted by EZ SPEED View Post
Very nice
Thanks hope yours goes well too.
Old 03-06-2011, 04:00 PM   #11
10aSSee D
10aSSee D's Avatar
What price range is a 418 build like this going for I might be going this route as well?
MODS:
Old 03-06-2011, 05:00 PM   #12
Busy_Boi
Busy_Boi's Avatar
Well between parts and labor you could spend alittle bit over $10,000.
Old 03-06-2011, 05:07 PM   #13
10aSSee D
10aSSee D's Avatar
Ouch that hurts the wallet, but it's what I was expecting.
MODS:
Old 03-06-2011, 05:18 PM   #14
Busy_Boi
Busy_Boi's Avatar
TUNERZ STORE|Holiday SALE on HAWK HPS/HP+/Ceramic Performance Brake Pads|FREE S&H Tunerz_Store Suspension / Chassis / Brakes 3 11-27-2010 12:22 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Dragstrip and Launch Techniques Discussion 3 07-30-2010 12:05 PM
4th Annual GM Performance Parts LSX Shootout!! nmcajeff Off-topic Discussions 0 07-28-2010 08:28 AM
Pick Your Song for Delivery Day joepitt 5th Gen Camaro SS LS LT General Discussions 179 09-22-2009 07:39 PM
