Old 03-06-2011, 04:41 PM   #1
RJTC11SS
RJTC11SS's Avatar
Drives: 2019 ZL1 A10
Brake Caliper "wheels"
Has anyone noticed that the 2011 SS has 4 little "wheels" attached to the brake assembly on the front wheels? My uncle's 2010 doesn't have them, but mine does. Any thoughts on what they're there for?
RJTC11SS is offline   Reply With Quote
Old 03-06-2011, 04:44 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
We refer to them as "roller skates" They where placed on the calipers to dampen some high frequency sounds from the brembos. Early builds have weights later builds have the "skates".
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 03-06-2011, 05:06 PM   #3
04Ram2500Hemi
Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS
And from my personal experience- the "Skates" don't work. But in theory, like he said it was to make the Brembo's quieter.
04Ram2500Hemi is offline   Reply With Quote
Old 03-06-2011, 05:11 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Ever watch ultimate factories? Check out the episode on Porsche. As the 911's come across the assembly line, check out the "skates" on their Brembo's as well.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-06-2011, 05:23 PM   #5
Cam2011
Drives: 2011 Camaro 2SS/RS
Love that show.
Cam2011 is offline   Reply With Quote
Old 03-06-2011, 05:32 PM   #6
RJTC11SS
RJTC11SS's Avatar
I hope every diehard Camaro owner has a copy of Ultimate Factories: Camaro... I bought mine, it may only be just shy of an hour, but totally worth having.
Old 03-07-2011, 02:23 AM   #7
dragon22
Drives: 2010 Camaro 2SS/RS SIM
These weights are actually on the pads, not the calipers. You can get rid of them by changing the pads over to aftermarket or ceramic. I have a set of pads that I will be using for the winter when I get my 18" wheel and snow tire combo.
But, if you replace the pads, you could end up with a brake squeal...so they say.
dragon22 is offline   Reply With Quote
Old 03-07-2011, 10:03 AM   #8
JusticePete
Drives: Camaro Justice
Water is wet. The Sky is blue. High performance brake pads dust and squeal.
The function of the roller skates is to add mass to the caliper assembly and reduce noise. The same was true of the stick on wheel weights prior to the roller skates. You can search other brand forums that use high performance Brembo brakes and you will find similar stories of owners that do not like the squeal.
We have tested more cars than I can remember with OE brakes on a road course. Some of them fail in less than two laps. The brakes on an SS did remarkably well in our base car testing. We think GM struck an excellant balance between performance, dust and quiet.
Old 03-08-2011, 08:19 AM   #9
woodside783
Casey Woodside
woodside783's Avatar
Drives: a very fun car
i am getting 18's, looking for a pad to replace the front rollor skates.
woodside783 is offline   Reply With Quote
Old 03-08-2011, 08:38 AM   #10
JusticePete
18s means road course, or autocross as a rule. They do not make street pads, but they make great track pads. Colbalt Friction XR1 front and XR3 rear are the perfect pads for track use with OE SS calipers. IMO
Old 02-14-2016, 11:03 PM   #11
Motorboy8769
Drives: 2015 2ss
I know this is an old thread but has anyone ever just cut these off? Any issues with doing that?
Motorboy8769 is offline   Reply With Quote
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 09:54 PM
Unbeatable Prices on BC / Eibach / Hawk / Hotchkis / MTI / Racing Brake / SLP / More maperformance Suspension / Chassis / Brakes 10 10-04-2010 02:36 PM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 12:08 PM
Stoptech Big Brake Kits | 6 Piston Calipers ~ Now Available! Circuit Motorsports Suspension / Chassis / Brakes 5 10-07-2009 12:27 PM
