03-08-2011, 08:09 PM | #1 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Rx Catch Can sucking sound
OK guys with catch cans, I installed an Rx catch can a couple weeks ago. Today I had the hood open and noticed a sucking sound from the side where the catch can is. Is this normal? Kinda sounds like a vacuum leak. I check both hoses and they're attached OK. Thanks!
03-08-2011, 10:17 PM | #2 |
Drives: 2010 2SS/RS CGM Join Date: Apr 2010
If I'm imagining the same "sucking sound" that you are, then yes, it's okay.
I thought I had a loose bearing, so I took it into RX and was told it was actually a noise the catch can was making, which shows its doing.. Something (working correctly). If you squeeze shut one of the hoses for a second, it should stop the noise until you release. I'm sure SC1250 can explain it more in-depth, but the sound is normal.
Engine/Appearance: 530 RWHP Whipple supercharger, Full JBA Exhaust, Ported TB, Cold Air Inductions & ADM Scoop /Complete new paint, 20" Forgestar F14s, Sinister hood, SLP Spoiler, AAC Halos, P13W Fogs |
03-09-2011, 12:12 AM | #3 |
The Noob
Drives: 2006 QSM GTO Join Date: Nov 2010
Could the valve on the bottom be open? Or perhaps one of the fittings it leaking on the can , not the hose?
03-09-2011, 06:56 AM | #4 |
BL1ZZRD
Is the valve shut when it is full clockwise (looking from underneath) as a screw would be, or full counterclockwise?
03-09-2011, 07:07 AM | #5 |
n116
Drives: 2010 2SS YELLOW TRANSFORMER AUTO Join Date: Mar 2010
Most pitcock drains open and let what ever run out when you turn it clock-wise. When you turn it counter clock-wise it will seal and let nothing drain. I am expecting my rx can any day.
03-09-2011, 07:09 AM | #6 |
BL1ZZRD
In that case mine is wide open. Maybe that's why it's so loud?
03-09-2011, 08:25 AM | #7 |
Drives: 2010 Camaro LS M6 Inferno Orange Join Date: May 2010
SC2150's install instructions state a slight buzz or rattle while running is normal.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers Find me on Facebook: http://www.facebook.com/gahammerle |
03-09-2011, 08:28 AM | #8 |
Drives: 2SS/RS Join Date: Sep 2008
03-09-2011, 08:40 AM | #9 |
BL1ZZRD
Yea I think mine is all the way in which is prob causing the sucking sound. I'll check it tonight after work! Thanks for your help!
03-09-2011, 07:49 PM | #10 |
Drives: 2011 Blue1SSRS 623RWHP, 02 vette Join Date: Aug 2010
sorry guys catch a can......somthing making a sucking sound..in a camaro...
with my car gone to the shop you all are killing me.lol P.S. will have RX can when it returns.
2002 Vette (stock)
Team LS-3 |
03-10-2011, 07:37 AM | #11 |
BL1ZZRD
Update: I started the car last night and let it warm up for a couple minutes. The sucking sound was gone. I checked my spicket and it was turned all the way in (open). So I turned it all the way out (closed). So, I don't know what was causing the sucking sound. Only difference is the night I heard the sound was after driving for an hour. It was raining last night so I didn't want to take it out to get up to temp.
Similar Threads | ||||
Loud "clunk" sound when turning. | Kakashi | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 12-14-2018 10:10 PM |
Elite Engineering PCV Oil Catch Cans | Instock | Best Prices with Free Shipping! | JDP Motorsports | V8 Bolt-Ons & Tunes | 137 | 08-13-2014 03:06 PM |
Mike Norris Motorsports Billet PCV Oil Catch Can Availability | Mike Norris | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 12-04-2011 07:41 AM |
Elite Engineering Catch Cans Now Available At APEX Motorsports! Multiple Colors! | Apex Motorsports | V8 Bolt-Ons & Tunes | 136 | 06-30-2011 05:24 AM |
2SS exhaust Vs Mustang GT sound... | Drago77 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 02-01-2011 02:47 PM |
