![]() ![]() ![]() Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
*EDITED* TPMS install onto TSW Nurburgrings - NO PROBLEM
Sorry for hitting the panic button, folks.
Seems my tire guy was too shy about pulling hard on the OEM TPMS stems cause he was afraid to break the brass rod that the TPMS attaches to. After a quick call to Alex of Speed Depot, we sorted it all out. Dismantled the valve stem from the TPMS and pulled it through no problem. Got one of the R888 315R35/20 on the 20x10 (with a little bit of elbow grease, so I'm told). My local tire shop is having problems installing the TPMS onto these TSW Nurburgrings 20" rims. They tell me that the TPMS are not fitting into the TSW's valve stem hole easily and that they are afraid to pull too hard and break the TPMS. The TPMS are OEMs from Patrick at GM Parts House. They say that the rim is too thick at the valve stem hole (?) and the sensors are getting bunched up and bent as they pull them through. They've tried vasaline and still can't get the TPMS through the TSW valve stem hole. From reviewing the forums over the past hour, it appears that I need TPMS adapters, but which ones??
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM Last edited by Avalnch; 03-12-2011 at 07:34 PM. |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
oooh good info to know before I order them next week... bump and subscribed.
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
You figure with all these wheels that have been sold, there would be lots of info or a definitive answer to this! For example for this wheel, use this TPMS adapter. How hard can it be??
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
#4 | |
The wait is over!
Seems that a lot of guys have these wheels, hopefully they will all post up with the adapters/solutions that they used.
Ordered - 4/17/2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
Does this installer not have a typical pulling tool? You cannot install rubber stems in most wheels without one.
http://cgi.ebay.com/ebaymotors/HD-Ch...mZ110510847892 Tony
Fquick.com/NineBall
#6 | |
#7 |
love. my. car.
Have you seen this thread? http://www.camaro5.com/forums/showthread.php?t=131797
This guy took a lot of pics of possible orientations. He had 2 valve stem holes on his wheels, so maybe your TPMS can be mounted internally with a loop adapter?
#8 |
OP has the Nurburgring wheels. Those have traditional valve stem holes, just like the factory wheels do. No need for adapters. Rubber stems must be pulled through the hole, they cannot be pushed through the hole.
Fquick.com/NineBall
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I have the Nurburgrings and our local tire shop had no issues putting sensors on them. But I got aftermarket sensors from Alex at Speed Depot. I kept the stock sensors with my stock wheels and sold them that way.
#10 |
I talked to Alex today at the Speed Depot and he told said that the OEM sensors will fit into the Nurburgrings, but you do have to muscle them in.
My shop guy just did not want to chance breaking the valve stem cause he noticed that he had to pull a lot harder than a regular stem. I think the brass rod that attaches the TPMS is giving him grief and his concern was breaking "something" if he pulled too hard. I've instructed the shop to disassemble the TPMS from the stem and pull it through. I'll keep you posted on how things go. Thanks for everyone's input. Tom
#11 |
![]() Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
I thouhgt the TPMS was suppose to attach to the stem after you install the stem by itself. Ive taken mine on and off twice (each rim) with a $0.98 install tool.
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
#12 |
jr, what tool did you use to remove the rubber stem? I use a razor blade and just cut them off and put new rubber stems in.
Fquick.com/NineBall
#13 |
![]() ![]() ![]() ![]() Drives: 2010 Camaro SS 2SS Join Date: Mar 2010
Installed the factory sensors on the TSW no problem at all...
![]() Not sure what your guy is talking about...
| DIY Hurst Short Throw Shifter Install - Pix and Video | TAG UR IT | Camaro DIY & HOW-TO instructions & discussions | 121 | 02-26-2015 11:08 AM |
| 22" TSW DONINGTON WHEEL/TIRE PACKAGES! STARTING @ $2380!! | BestWheelDeals | Wheels / Tires | 62 | 10-05-2011 07:06 PM |
| TSW Nurburgrings with 555r- 305/35/20 pics | SGOS252382 | Wheels and Tires Talk Sponsored by The Tire Rack | 21 | 09-10-2010 05:35 PM |
| Nurburgrings with 305s? | SGOS252382 | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 07-21-2010 02:12 PM |
