Old 03-10-2011, 10:08 AM   #1
joes407
joes407's Avatar
Drives: 2014 ZL1m6 red hot #569
a/c issues anyone have this?
anyone getting a whining noise inside the car from their a/c on a manual 2 SS? the noise sounds like the noise youd hear from a bad plug wire when it whines through the radio. took it to the dealer and they said it was the compressor and they replaced it. the whine is still there. it stops when i shut the a/c button off or i shut off the fan. this is a new noise and the wifes automatic doesnt do it. they said compressor because it stops when a/c button is off. at this point they are saying its normal on camaros due to the design of the a/c. my concern is im 4000k miles from warranty ending and i dont need a/c issues in summertime florida after my warranty ends.
joes407 is offline   Reply With Quote
Old 03-10-2011, 10:52 AM   #2
joes407
joes407's Avatar
anyone?
Old 03-10-2011, 10:55 AM   #3
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Doesn't do it on my 1SS. However; I am getting the blower motor chirping at low speeds that I've read about on other threads..Will be bringing mine to the dealer soon for that. Otherwise, mine's been a good SS.
nancygrl is offline   Reply With Quote
Old 03-10-2011, 01:22 PM   #4
bradshaw
bradshaw's Avatar
Drives: 2010 LS3 2SS M6
Mine doesn`t make any whining noises either, that does not sound normal to me, mine is very quiet and cools very well.
bradshaw is offline   Reply With Quote
Old 03-10-2011, 01:33 PM   #5
texcraig
texcraig's Avatar
Drives: 2011 2LT RS White/Orng Strip
All is good with mine. Have not heard any of this.
texcraig is offline   Reply With Quote
Old 03-10-2011, 02:51 PM   #6
flyby
Drives: 2010 Silver SS
No problem with mine. 6000 miles all is good.
flyby is offline   Reply With Quote
Old 03-10-2011, 02:56 PM   #7
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
a lot of folks have a tick/chirp sound at lower speeds on the blower motor; including me. Maybe it is this you are hearing?
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 03-10-2011, 06:28 PM   #8
Grandeos
Automotive Designer
Grandeos's Avatar
Drives: 2011 Camaro 2SS/RS (LS3)
Mine does it, and it drives me INSANE. It is not a chirping like others have complained about... Rather, it sounds like a noisy computer fan... When you hear plastic rubbing against plastic. Problem is, I keep getting told that it is normal, when in actuality, I think nobody else can hear it. It is incredibly frustrating. I am about to go to the dealer and sit in every Camaro on the lot and see if those do it as well.
2011 Camaro 2SS/RS LS3 (SIM/BLK)
Grandeos is offline   Reply With Quote
Old 03-10-2011, 06:55 PM   #9
steven32708
Drives: 2010 2SS/RS IOM LS3 Camaro
mine did so i took it in and got it fixed at the dealer under warranty.
steven32708 is offline   Reply With Quote
Old 03-10-2011, 06:59 PM   #10
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Mine is going in to have the compressor replaced Tuesday, same problem and it leaked residue everywhere. Antifreeze I guess?
DarkneSS is offline   Reply With Quote
Old 03-10-2011, 07:31 PM   #11
buzzy56
buzzy56
buzzy56's Avatar
Drives: 2ss summit white L99
me too
Me too -automatic w/ everything shut of inside the car with engine running you hear this low low grade whine like electrical feedback in my opinion.If you rev he engine it goes up in volume but it is such a low pitched whine that with any other things on such as heater, radio window open it is barely audible.Bugs you though for sure.
OLD SCHOOL / NEW SCHOOL COOL
buzzy56 is offline   Reply With Quote
Old 03-10-2011, 07:39 PM   #12
GreenMonster
Its all about the U
GreenMonster's Avatar
Drives: 2010 SGM
no issues here, go to the dealership theyll figure it out
GreenMonster is offline   Reply With Quote
Old 03-10-2011, 08:16 PM   #13
inrandy
Randy
inrandy's Avatar
Drives: 2016 2SS Red Hot A8 Magride
I had a noisy belt, after looking under the hood the belt was riding up the side of the crankshaft pully. This Saturday they are going to replace the AC compressor and belt as they siad the bearings were bad on the AC. When I turn on the AC the belt noise does not change so this is probably not your problem. Just thought I should post about AC problems.
Randy
2016 2SS, A8, Magnetic Ride, Performance exhaust.
Randy
inrandy is offline   Reply With Quote
Old 03-10-2011, 08:52 PM   #14
Synyster
Synyster's Avatar
Drives: 2006 F150 Lariat
No whining noise, but mine doesn't blow cold air. It's not the freon either. Dealership is ordering parts, going in next week.
Synyster is offline   Reply With Quote
TPMS issues - finally a response! Nine Ball Wheels and Tires Talk Sponsored by The Tire Rack 157 04-17-2015 03:27 PM
Where is the A/C supposed to drain on the ground? 2010 Bumblebee 5th Gen Camaro SS LS LT General Discussions 34 04-23-2014 08:50 PM
GM doesn't care about my clutch issues O2BQIK Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 200 07-05-2012 02:23 AM
Camaro 2010 Issues Tim's.2010.Camaro.SS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 57 06-04-2010 10:27 AM
