SLP Loudmouth and rev limiter question
Hubby just installed my SLP Loudmouth axle back exhaust today and it sounds great but I have a question. I hate the rev limiter. Is there a way to get rid of this? On a side note, Kenny said it was a lot easier to install than he thought it would be. And I must admit although I love it and it sounds great, it still isn't close to the sound of my Firehawk with SLP Cat back Loudmouth. I think the rev limiter makes the Camaro too quiet.
JulzSS
Proud Navy Wife and Mom 2011 Camaro SS 2014 Silverado LTZ |
"First There"
Drives: 2010 camaro 2ss Join Date: Feb 2011
if you are talking about the one at idle you can use hp tuners and set it that way but any other tuner just raises the redline
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Rev limiter?
I think you're talking about something else. The Rev limiter shouldn't have any effect on your exhaust. The rev limter is to protect your engine from over revving. |
What I mean is, it wont rev over about 4000 rpms and I don't like it. We were giving it gas to hear the full effect of the exhaust and it cut back when it reached 4000 rpms.
JulzSS
![]() Drives: 2011 Camaro SS Join Date: Aug 2010
My car revs up to 5500 and mine is still stock 2011 camaro ss
#6 | |
![]() I did read something like this in a different thread though. |
#7 |
![]() Drives: 2021 ZL1 1LE Join Date: Aug 2010
I have SLP loudmouth and that doesn't occur.
You have launch control on????? That's what happens when it is on. Worse case get a tuner and that will fix it. |
#8 |
Is launch control on the traction control button? If so, traction control was on, like it normally is but it wasn't set to stability competitive mode.
JulzSS
#9 |
Yes it is the same button.
Hold it down for about 7 seconds until both lights appear on your dash on your RPM gauge. Now cut it loose!!!!!! |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Auto trans?
#11 |
![]() ![]() ![]() Drives: 2010 Camaro 2SS L99 SIM Join Date: Feb 2010
Auto transmissions rev from 4000-4500. Mine stays in that range all the time. Manuals can go 5000-5500.. Sometimes almost 6000. I almost took mine to 5000 today but it only went to 4700 ha.. Damn embarrassing rev limiter :(
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 c7 Join Date: Nov 2009
yes, the auto has a rev limit in park. i can rev my manual to 6000RPM in neutral, i think even red line.
#13 |
#14 |
The rpms are limited to 4000ish in the auto trans/L99 in park or neutral. They don't want anyone dropping it into gear at 6000 rpm. Doesn't matter the T/C A/H mode.
| Rock and Rumble (Part 1, Rumble) SLP (Long tubes/Powerflow x Pipe/Powerflow axle back | PatrickfromMD | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 09-12-2009 05:22 PM |
| SLP Loudmouth I Exhaust (vid as requested) | Red Hot SS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 07-02-2009 08:58 PM |
