Old 03-10-2011, 06:16 PM   #1
Bill 1ss/rs m6
Bill 1ss/rs m6's Avatar
Drives: 2015 1SS/RS M6
Question about ******** t harness install
I got it today. My good friend is giving me a 12 inch sub with enclosure and an amp to power it. My question is will all I Need is power cable to battery and ground cable. Good to go?
Bill 1ss/rs m6 is offline   Reply With Quote
Old 03-10-2011, 07:06 PM   #2
Shredder
Shredder's Avatar
Drives: 2011 RJT 2LT
Send a message via AIM to Shredder
Depending on the amp you are using you might need a ground loop isolator. You also need a RCA cable to go from the harness to your sub amp.
Shredder
Shredder is offline   Reply With Quote
Old 03-10-2011, 10:22 PM   #3
Bill 1ss/rs m6
what is a ground loop isolator and how would i know if i needed one?
Old 03-11-2011, 09:16 AM   #4
Hicompression
Rumbly Bumble Bee
Hicompression's Avatar
Drives: 2010 2SS Camaro
You will know if you need a ground loop isolator (GLI) if your amp goes into protect mode after hooking up the RCA's. I had to use a GLI on mine. Fixed the problem and very easy to install.
The need for a GLI is caused by too much DC current in the factory lines. Some amps don't like it.
2010 RALLY YELLOW 2SS 6M
-OBX Longtubes FTW!
Hicompression is offline   Reply With Quote
Old 03-11-2011, 10:11 AM   #5
Bill 1ss/rs m6
Great info. Thanks. It's nice to be prepared as I will be installing tomorrow!!
Old 03-13-2011, 10:50 AM   #6
Bill 1ss/rs m6
Installed my diamond 12 inch sub in a sealed enclosure. Powered by a profile 1000 watt amp! It is just ridiculous!! (In a good way, of course) Easy as pie install thanks to the ******** T harness. I'll post some pics later.
Pfadt lowering springs - after install question omegaman Suspension / Brakes / Chassis 5 01-01-2011 08:51 PM
Supercharger install question KeeBee Forced Induction - V8 9 11-16-2010 10:10 PM
Another ******** install Fraxum Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 5 09-30-2010 08:03 PM
******** Enclosure + Harness Review #1597 cur Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 6 07-07-2010 10:51 PM
******** 12" box & amp. rack Install! with pics!! turbo222 Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 10 06-29-2010 10:51 PM
