![]() Drives: 11 Camaro Vert 2SS/RS 6M Hurst Join Date: Feb 2011
Magnaflow tru-x pipe or resonated x-pipe
I've already done the Magnaflow 16582 comp axle back. I left the h-pipe and the resonators on my ls3 convertible. I love the sound. I also love the decal popping but would like to reduce it just a little. What will either of these do for me. Thanks!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
The resonated will x-pipe will take a little bit of the edge off. It will also slightly muffle the sound...but not alot. The Tru-X will probably increase the sound but you'll hear the decel popping a little more as well.
The resonated x-pipe is what Magnaflow uses on there 2.5" Comp cat's-back system. That's the main reason why I chose it over the Tru-x.
Build Journal ![]() |
I didn't remove the oem resonators like you did. I was curious if another resonator would be overkill. I liked the sound of the YouTube of the ls3 that did the 16582 before and after the x-pipe. I'll have to listen to yours again.
I decided on the tru-x pipe after tons of research on numerous forums and all I can say is .... WOW!!!!!
| Magnaflow resonated X pipe !NEW! (#11386) | rocketman | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 4 | 10-04-2011 07:18 PM |
| when replacing H pipe with resonated x pipe should I remove mufflers? | CamaroC-17 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 2 | 02-21-2011 12:14 AM |
| Magnaflow Delete, then Resonated X Pipe, then X Pipe (with video) | Bumble_Bee | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 22 | 08-05-2010 04:53 PM |
| FOR SALE: MagnaFlow 10790 Tru - X Stainless Steel 2.25" Exhaust Pipe | SirBrad | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 0 | 07-23-2010 11:50 AM |
