Old 03-16-2011, 02:01 PM   #1
Buick1959
Buick1959's Avatar
Drives: '11 SS RS LS3 IOM conv
L99 active fuel management system
The L99 engine has an active fuel management system that drops the used cylinders from 8 to 4 under light loads. Are there any concerns out there over this AFM system? I am not a fan and plan to order an LS3 6 speed to avoid it. Would like to hear thoughts from others...
Buick1959 is offline   Reply With Quote
Old 03-16-2011, 02:13 PM   #2
SLEDMASTER
SLEDMASTER's Avatar
Drives: 2011 corvette coupe
Get the ls3 no afm. I got rid of my car because of AFM. You can buy a programer and turn it off along with your power tran warranty.
SLEDMASTER is offline   Reply With Quote
Old 03-16-2011, 02:21 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
There have been several threads about sticky AFM lifters, and some people don't like the sound of the switches between 8 and 4.
I have found that as the engine breaks in, these symptoms reduce, and the A6 transmission is a pleasure to drive after 40 years of shifting cars and trucks.
But, when I was younger, driving an auto by choice was out of the question, so do what you like!
Rock-It Man is offline   Reply With Quote
Old 03-16-2011, 02:23 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Why are you worried about it? There are no adverse affects of AFM as it's encorporated into many other GM vehicles.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 03-16-2011, 05:32 PM   #5
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
You can turn off AFM with a tune. But if your planning on an LS3 M6, you don't have to worry about it.
But if you would rather have an automatic, then you'll want to read up on AFM/DOD. Most of us love our automatics. The L99 A6 hauls axx with just a few basic mods. So if you do want an automatic don't let the AFM/DOD scare you away.
Old 03-16-2011, 05:48 PM   #6
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
I had it tuned out very early on. No problems here! I love my L99.
Old 03-16-2011, 07:38 PM   #7
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
first thing many l99 and truck owners do is have the afm/dod turned off,, most with no noticeable loss in fuel mileage,,
Old 03-16-2011, 07:40 PM   #8
+1
Old 03-16-2011, 07:56 PM   #9
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
+1 I love my L99. It is very potent and has more than enough to hang tough. One of my first mods was the CAI Inc induction and at WOT It just sounds like an angry machine begging to chew up asphalt.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 03-16-2011, 09:57 PM   #10
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
had it tuned...i bought a v8, not a part time v4. the difference is very dramatic.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 03-16-2011, 10:09 PM   #11
CruiseControl
CruiseControl's Avatar
Drives: 2010 Camaro 2SS/RS L99
No problems and no tunes for me. I enjoy sipping a little less fuel on highway cruises. I also enjoy my warranty.
CruiseControl is offline   Reply With Quote
Old 03-16-2011, 10:30 PM   #12
kmcd
1,425 hp / supercharged
kmcd's Avatar
Drives: (2020 2SS/M6) (2025 GMC Yukon)
You can turn off the AFM by simply changing the parameters on the stock tune if you want. I've talked to three different service managers who say this will not void your power train warranty. They know people don't like it, and the only reason it's there is so the car won't be subject to the gas guzzler tax. It's easy to do with a hand-held tuner, and your mileage won't suffer unless you plan to only drive on a perfectly flat surface without accelerating. That's how they validate the EPA mileage rating, but that's not how people drive in the real world.
kmcd is offline   Reply With Quote
Old 03-16-2011, 10:45 PM   #13
1Camaro2SS
1Camaro2SS's Avatar
Drives: 2013 Camaro ZL1 M6
+1
+2
1Camaro2SS is offline   Reply With Quote
Old 03-17-2011, 12:00 AM   #14
shortstop4
shortstop4's Avatar
Drives: '13 Summit White ZL1 M6
will tune out at 100,001 miles
Cold Air Inductions Intake
shortstop4 is offline   Reply With Quote
Check engine light on Boricua Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-28-2010 02:12 AM
Active Fuel Management israfel77 Europe 3 03-09-2010 08:20 AM
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 02:45 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
Active Fuel Management? MJA03 5th Gen Camaro SS LS LT General Discussions 41 01-09-2008 03:25 PM
