03-16-2011, 05:42 PM | #1 |
Drives: BLACK 1SS Join Date: Apr 2010
HEAD/CAM L99 450 RWHP DRAG RADIAL TIME
What times are you guys running in the 1/8th and 1/4 mile? L99 with head and cam 450 rwhp and 315 wide 18" drag radials. On a side note race weight is 3800 lbs with me in the car.
COLD AIR INDUCTIONS CAI JBA HIGH FLOW CATS
EDELBROCK X-PIPE MUFFLER DELETE |
03-16-2011, 06:13 PM | #2 |
Drives: 2010 IOM SS Join Date: Aug 2009
I'm going to take a wild guess and say 11.5 give or take a .10. At 375 RWHP I was able to do a 12.2 in the 1/4. That was on drag radials
03-16-2011, 06:44 PM | #3 |
Drives: 2010 Camaro 2SS Join Date: Aug 2009
Depends on the DA. I would say 11.50-60 easy. It depends on what converter you are running.
03-16-2011, 10:23 PM | #4 |
Im looking at the LIVERNOIS 2C blower cam......what size stall should I get? I was under the impression that the stock converter would be fine.
03-16-2011, 11:18 PM | #5 |
If you are going with a blower the stock converter is fine for mid to low 11's. If you buy a converter go with a 2400-2600.
03-17-2011, 08:35 AM | #6 |
How much HP/TQ do you think the stock torque converter can hold?
03-17-2011, 09:23 AM | #7 |
Banned
Drives: 2003 Cobra Convertible Join Date: Feb 2009
what did you do to shed 350lbs? w/ 450rwhp and 3800lbs you should be trapping 120mph. ET w drag radials would range between 11.8-11.0 depending on driver. are you gonna be on stock gearing and axles?
03-17-2011, 09:32 AM | #8 | |
CamaroFans.com
http://www.camaro5.com/forums/showthread.php?t=130523 I'll be hitting the track on Sat w/ 18" DR's so should have some numbers to share then |
03-17-2011, 11:19 AM | #9 |
NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
I am getting the 2c cam installed as we speak with Precision Vigilante 2400 TC as recommended by Livernois. You can fun that cam without aftermarket TC but it will have some surge.
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
03-17-2011, 04:02 PM | #10 | |
3780-154=3626lbs and I weigh around 175 lbs so that's how I did it
03-17-2011, 04:06 PM | #11 | |
03-17-2011, 05:21 PM | #12 |
Drives: ZL1 Camaro Join Date: Feb 2009
expect to shave an additional .3-.5 off the 1/4 mile with a converter....
Similar Threads | ||||
Jannetty L99 Street Brawler Package 501 RWHP 512 RWTQ | JANNETTYRACING | Forced Induction - V8 | 47 | 05-19-2010 06:59 PM |
First time to drag race, any tips? | BaylorCamaro | Dragstrip and Launch Techniques Discussion | 4 | 12-18-2009 11:29 PM |
Jannetty Racing Unopened L99 Makes 545 RWHP 553 RWTQ | JANNETTYRACING | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 12-12-2009 10:13 PM |
Should my L99 be showing more RWHP? | tony_c | Tuning / Diagnostics -- engine and transmission | 24 | 09-28-2009 08:47 AM |
