Old 03-16-2011, 11:26 PM   #1
camaro2k10
Drives: 2010 2SS Camaro IBM W/ Black RS
1 3/4" or 1 7/8" Headers???
Did a search on this subject but no results came back i know that the norm. is 1 7/8 however I've found several 1 3/4 that seem serviceable and have similar gains and was actually interested in borla headers until i found that they are 1 3/4 and it put question in my mind so I was wondering what you guys' opinion of headers were...keep in mind the only mods my car has planned for it are:
Already have Borla atak cat back system
Plan to have:
Headers
Vararam cold air intake
Texas speed performance vvt cam kit
So any recommendations on a size of header? not so much stuck on brand as much as the age old question does size really matter in this situation lol
camaro2k10 is offline   Reply With Quote
Old 03-17-2011, 12:49 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Buy what you like the best and will fit in your budget but the norm is 1 7/8" as you already know.
http://www.camaro5.com/forums/showth...ht=header+test
Build Journal
Old 03-17-2011, 01:45 AM   #3
Phase V
Summer
Phase V's Avatar
Drives: 2010 2SS/RS IOM w/ Black Stripes
Send a message via AIM to Phase V Send a message via Yahoo to Phase V Send a message via Skype™ to Phase V
I agree with caverman. And I'm not doing much more mods than you but I got 1 7/8 in case there ever comes a time for more.
CAI intake, Rotofab W/W Reservoir, Hurst Shifter, Skip-Shift Eliminator
AAC lighting, Kooks LT headers w/ high flow cats and Borla ATAK cat-back
Restoring or need parts for a Chevy. Look no further than Don's East Coast Restorations
Phase V is offline   Reply With Quote
Old 03-17-2011, 02:07 AM   #4
103FrazzL
103FrazzL's Avatar
Drives: 2010 Camaro 2SS RS M6
I love my 1 7/8 ARH Long tube headers The performance the sound and the power are all there. I wouldn't recommend anything else except the the kooks 1 7/8 long tubes lol. 1 7/8 ALL THE WAY!! unless u have a blower the 2'' ALL the way!!!! good luck
2010 Camaro 2 SS RS CGM
ADM Street Cold air intake, SLP Loud Mouth II, ARH 1 7/8 Long Tube Headers w/high flow cats, Hurst Short Throw shifter, Skip shift eliminator, LED licence plate Lights
103FrazzL is offline   Reply With Quote
Old 03-17-2011, 02:11 AM   #5
103FrazzL
103FrazzL's Avatar
BTW if u look at my mods they are nothing crazy but the 1 7/8 are perfect for what I'm looking for and should suite u well.
Old 03-17-2011, 02:45 AM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Tampa Corvette tuner. Tampa Camaro Tuner. Tampa GTO Firebird TransAm Truck tuner
1 7/8 Long tube Headers
The LS3/L99 heads flow great.
Tampa Tuning is offline   Reply With Quote
Old 03-17-2011, 06:12 AM   #7
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I recommend 1 7/8. Here is some info from our blog.
Choosing The Right Headers
Added Nov 10, 2010, Under: General Automotive
Choosing headers can be a daunting task. With all the different manufacturers, short tube versus long tube, and then there are all the different diameters to consider! Geez. In this post I will try to arm you with as much information as I can to help you decide on the best option for you and your ride.
Short Tube (ST) versus Long Tube (LT)
The general rule when it comes to primary length is that longer primaries will create more low end power and shorter primaries will create more top end power. However, with the larger displacement engines powering the new generation of modern muscle cars (particularly the Camaro and Challenger) it seems that short tube headers are providing minimal performance gains. Because the cost/benefit ratio is so low with the short tube headers I recommend sticking to the long tube headers and will focus on those for the remainder of this post.
Which Manufacturer Should I Go With?
The good news here is that this is hard to get wrong. Ask around on the forums and you will hear some of the same brand names over and over again, I prefer Stainless Works. From a performance stand point all of them are pretty close, no one has a secret that makes one brand produce substantially better results than any of the others. It’s mostly a question of quality and again most of them are pretty close in this area as well, but there are a couple of things to pay close attention to.
Pay attention to what they are made of. Stainless steel (particularly 304) is what you will want to look for. 304 stainless steel will not rust or discolor from exposure to the atmosphere like the cheaper 400 series stainless steel. Unlike aluminized steel, it will not rust from the inside out due to the corrosive fluids produced during combustion. 304 can discolor slightly from getting extremely hot or if you spill engine oil on them but another attribute is that it isn’t permanent.
Pay attention to how they are made. CNC mandrel bending is the best manufacturing method for producing exhaust systems and headers that flow and fit well. When this process is used in conjunction with the 304 stainless steel it allows for the use of a thinner wall tubing that will weigh less than other headers. Those weight savings will be lost, however, if you opt for the ceramic coating some manufacturer promote. With stainless steel the coating isn’t needed for corrosion resistance purposes (ceramic coating is often pushed because the manufacture is using inferior metal) and I have never seen any performance improvement even in back to back runs on the dyno.
What Primary Diameter Should I Go With?
This is the area that seems to cause the most confusion but it is fairly straight forward. Header manufacturers usually offer two or three options when is comes to primary diameters for a specific vehicle. For example, for the new 5th generation Camaro SS most manufacturers are offering 1 3/4 inch, 1 7/8 inch, and 2 inch primaries. Here are the results of some recent back-to-back testing on an otherwise stock SS:
Stock: 372 RWHP 376 RWTQ
1 3/4 headers with high flow cats: 401 RWHP 404 RWTQ
1 7/8 headers with high flow cats: 408 RWHP 409 RWTQ
2 headers with high flow cats: 413 RWHP 410 RWTQ
As you can see, simply switching from the restrictive stock manifolds to 1 3/4 long tube headers is worth approximately 30 RWHP and 30 RWTQ on a bone stock Camaro SS. The larger the primary diameter gets the more air the headers will flow and the further up the RPM range the power band is moved. The impact of the larger primary diameters is magnified the more powerful the engine is, especially when you introduce forced induction. This means that generally the more power you make or the more race oriented your application is the bigger primary diameter you need, the closer to stock or the more street oriented the smaller primary diameter you need.
In the specific example of the 2010+ Camaro SS, we have found that the 1 7/8 long tube headers are the best all around header for the typical bolt on modified car that is driven regularly and occasionally taken to the track. They offer a tremendous improvement over stock with room to grow as owners modify their car further. The 2 inch headers offer very similar numbers to the 1 7/8 headers up to 5000 RPM where the 2 inch headers pull ahead. They are ideal for those running forced induction or for race applications.
Conclusion
Selecting headers does require some technical knowledge, but it isn’t the voodoo some make it out to be. Hopefully, the information above will put you on the right track but any competent retailer or performance shop specializing in your vehicle should be able to provide further advice.
Old 03-17-2011, 10:04 AM   #8
Jason 98 TA
Drives: Camaro
Hang tight for just a little bit, we're finishing up a 304 stainless 1 7/8" long tube option that I think will put a smile on everyone at camaro5's face!!
Jason 98 TA is offline   Reply With Quote
Old 03-17-2011, 10:52 AM   #9
Mark Myles
Mark Myles's Avatar
Drives: 2010 2SS/RS IBM / Silver Stripes
M
Mark Myles is offline   Reply With Quote
Old 03-17-2011, 05:07 PM   #10
camaro2k10
Im with you get the popcorn ready i like the way this guy is talking starting to sound like almost everything i orders comming from tsp got an estimated time that you guys are going to be finished I'll probably be starting up on my mods sometimes next month actually
Old 03-17-2011, 05:28 PM   #11
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
2"
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 03-17-2011, 06:05 PM   #12
Blueclyde
Drives: 2023 ZLE
Have you considered stepped headers, 1 3/4" to 1 7/8"? Kooks makes a set.
Blueclyde is offline   Reply With Quote
Old 03-17-2011, 06:29 PM   #13
Apex Motorsports
As does Stainless Works. You will pick up 8-10 more rwhp over a standard straight tube header but they don't come cheap. Unless you are a racer or doing a max effort build it probably isn't worth it.
Old 03-17-2011, 06:48 PM   #14
Blueclyde
Drives: 2023 ZLE
They are worth the couple hundred extra dollars in my opinion but I get that some people have a budget. If you can afford th extra they are worth it.
2" Headers Vs 1 7/8" Headers...Your Opinions PLEASE!!!!! Mr. Brownstone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 06-18-2023 10:30 PM
WTS: JBA 1 7/8" headers with 3" catted mid-pipes ($1100, Can bring to the fest) Mindz V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 14 02-10-2011 03:03 PM
Modern Muscle Exhaust and Intake Special modern-muscle V8 Bolt-Ons & Tunes 1 01-20-2010 07:46 PM
Doug Thorley headers and axle-back ROCKS! SPANKT U Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 01-07-2010 11:36 AM
