www.gkiser.com
Drives: 2010 2SS/RS, Auto, Summit White. R Join Date: Apr 2010
Cat back vs axle back from gmpp. What's the diff?
What's the difference between cat converter back vs axle back? Does gmpp offer both?
Roto-fab CAI, GMPP exhaust with tips, Pistol Grip shifter with paddle switches, 'Chevrolet' aluminum kick plates, Aluminum Bow Ties, ClearBra front bumper/facia + side views + gills + behind door handles. SS floormats. www.gkiser.com |
I believe GMPP only offers the axle-back. And as the names imply, the axle-back is only that section of exhaust starting at the rear axle out to the exhaust tips. The cat-back starts immediately behind the catalytic converts and goes all the way to the tips. Usually, the cat-back systems will have some sort of X-pipe or H-pipe in the system. Hope this helps.
www.gkiser.com
Helps, thanks. Where, physically, are the cats located? Right out of the manifolds?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 c7 Join Date: Nov 2009
yes if you were to look under the car it would be very clear what the cats look like and are located. if i was you i would go with a cat back. they sound better then just axle backs
www.gkiser.com
Guess the cat backs remove a bit more headloss. Makes sense. Thanks guys.
#6 |
![]() Drives: 2010 Camaro 2SS Silver Join Date: Feb 2011
I heard catback replaces the whole exhaust, makes your car breath better, and I also heard the stock exhuast weighs around 50 pounds.
#7 |
#8 |
This would be further on down the line but I eventually want to buy BBK longtube headers and sometime after that a cat back exhaust system. Would I need to buy the BBK cat backs to have them fit or would any same size exhaust bolt on? Assume I have zero knowledge, because I do.
Thanks.
El gato. Mods: Eagle eye headlights, 18" Axis Sport graphite, Roto-Fab cold air intake, Vmax ported TB, 3/8" Vmax Black-Ice, RX single valve catch can, RX breather, Pedders inserts, Trifecta tune, BBK LTH 304 SS.
art/ärt/Noun. Definition: 5th generation Camaro. |
| For sale GMPP axle back v8 ( cheap) | mikeSS | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 0 | 01-12-2011 08:20 PM |
| GMPP Axle Back | crabapple | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 2 | 12-26-2010 02:02 PM |
| HTP Cat & Axle Back Exhaust Sale | VegasSilverbird | USA - Southwest | 0 | 05-10-2010 01:40 PM |
| Does an axle back have the same problems as a cat back? | G.E. | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 09-15-2009 04:31 PM |
| question on install: GMPP cat back exhaust | detroitboy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 04-04-2009 01:52 PM |
