![]() Drives: Camaro 1ss manual 6.2L V8 Join Date: Nov 2010
trouble / error codes
a check engin light just came up in my car i'm worried what are they for
P0851 AND P219B can some one please help my with them ![]() ![]() thanks |
1,425 hp / supercharged
Drives: (2020 2SS/M6) (2025 GMC Yukon) Join Date: Oct 2009
P0851 - Park/Neutral Switch Input Circuit Low
P219B
Stand by - I did find this:
Cylinder (Air-Fuel Ratio) Imbalance DTC P219A / P219B = Bank 1 AFR Imbalance / Bank 2 AFR Imbalance. ECM monitors the Difference in A/F Ratio between each Cylinder on Bank1 / on Bank 2. This means that air fuel ratio on one bank compared to the other is not equal. The first thing to do is to reset the code and see if it returns because these are often false alarms. Read more: Chevy Questions - Chevrolet Camaro SS 2010 camaro L99 auto. P219B Code what - JustAnswer http://www.justanswer.com/chevy/4b4o...#ixzz1HUyrgSEH I hope this helps.
thanks
but what should i do with the first one what does it mean ?? i dono about it !!!! |
#6 |
I'm not sure, but I think because that switch is shorted to ground, you can actually engage the starter while your car is in gear. You could test it, but you want to make sure there's nothing around your car before bumping the key to the start position.
Or you could just take it to the dealer. That's probably the better option if it's under warranty.
#7 |
Then again, it could be the parking brake switch. Does the parking brake light come on when you have it engaged?
#8 |
![]() ![]() Drives: 2014 Camaro SS Join Date: Sep 2013
What if the air fuel code returns? My car is doing this now. I erased the code and it came back. Seems to be a bank 1 code.
#9 |
![]() Drives: 2013 zl1 stock. Join Date: Sep 2016
I'm having the same problem p219a and p219b came on my zl1 after I installed upper pulley, tb, injectors, CAI AND a tune. Idk what's causing it to do that my tuner couldn't figure it out.
#10 |
![]() Drives: 05/07 Chevy's Join Date: Aug 2009
He's a .pdf for the codes.
| trouble with factory ground effects | mag | Camaro Convertible Forum | 4 | 03-17-2011 04:34 PM |
| Are the V-6 Camaros with Auto. Trannys. trouble free ? | wbyman | 5th Gen Camaro SS LS LT General Discussions | 23 | 01-23-2011 10:52 PM |
| What Trouble Code is this? | Jeanius | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 04-11-2010 10:54 AM |
| Trouble taking key out on NEW 2010!!! | scajc | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 12 | 07-20-2009 11:11 AM |
| Big Trouble in Japan | Captain Awesome | General Automotive + Other Cars Discussion | 3 | 01-01-2009 09:44 PM |
