Old 03-27-2011, 02:46 PM   #1
Levi_Engle
Drives: 2010 SS Camaro
Hp difference in headers upgrade with/without mid pipe upgrade
How much of a loss in hp will I be taking getting new headers without getting an upgrade in the mid-pipe? (not changing to an x-pipe). Just concerned about the worth of getting headers with or without any upgrade behind the headers... Thanks!
Levi_Engle is offline   Reply With Quote
Old 03-27-2011, 02:56 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
I think you mean cat-back. If you go with long tube headers you'll have no choice but to change your mid-pipe.
There are plenty of people that run the stock cat-back with LT headers. There will be very little to no HP difference in the OEM cat-back vs aftermarket.
Build Journal
Old 03-27-2011, 03:01 PM   #3
mikeSS
mikeSS's Avatar
Drives: 2015 c7
like what caverman said you need to upgrade the mid pipe. by upgrading the factory " cat back" you should gain like 10HP with a good tune.
Old 03-27-2011, 03:13 PM   #4
Levi_Engle
Yeah I meant to the cat lol k cuz I got Magnaflow from the axle-back. Just wanted to make sure it was worth getting headers and cat-back, is that the same as headers and hi- flow cats? Or that's just to the cat converter??
Old 03-27-2011, 03:21 PM   #5
Levi_Engle
I'm confused because looking at the ARH it shows long tube SHORT system with cats... I thought short system meant not adding the cats into the purchase..?
Old 03-27-2011, 03:23 PM   #6
mikeSS
mikeSS's Avatar
Drives: 2015 c7
can you link the page?
Old 03-27-2011, 03:31 PM   #7
Levi_Engle
http://www.LMPerformance.com/c/7/119.html
Old 03-27-2011, 03:35 PM   #8
Levi_Engle
And here's the item: http://www.LMPerformance.com/56673/119.html
Old 03-27-2011, 03:41 PM   #9
mikeSS
mikeSS's Avatar
Drives: 2015 c7
this system should come with mid pipes. it says it comes with high flow cats which is mid pipes . they said it connects to your x or h pipes. and you need a mid pipe to do that. and the price is 1300 is that sounds like mid pipes are included.
Old 03-27-2011, 03:42 PM   #10
Levi_Engle
Not sure why there's ARH 1 7/8 long tube short system with xpipe and cats AND then ARH 1 7/8 long tube with xpipe and cats...
Old 03-27-2011, 03:44 PM   #11
Levi_Engle
K cuz I see the price difference but what's the difference in the product and hp produced
Old 03-27-2011, 03:46 PM   #12
mikeSS
mikeSS's Avatar
Drives: 2015 c7
here what you want, this will connect to your axle back.
http://www.lgmotorsports.com/catalog...oducts_id=2113
comes with x pipe, mid pipes. in one piece
Old 03-27-2011, 03:47 PM   #13
Levi_Engle
Oh I see! Doesn't show x-pipe lol but what's the hp difference between stock and an x-pipe?
Old 03-27-2011, 03:48 PM   #14
mikeSS
mikeSS's Avatar
Drives: 2015 c7
10HP and sound.
DIY : Install headers on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 70 06-25-2020 07:40 PM
Whats the difference from shorty to long headers FutureCamaroOwner Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 0 04-05-2010 04:56 PM
do headers make enough difference Rockman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 50 01-11-2010 10:43 PM
