Old 03-28-2011, 01:25 AM   #1
Cambull11
Cambull11's Avatar
Drives: 2011 Black 2SS/RS M6
DIY Oil Change
So this is going to be my first time changing my oil in my '11 SS/RS LS3.
What is the best oil i can get?
What is the best filter i can get?
Cambull11 is offline   Reply With Quote
Old 03-28-2011, 08:41 AM   #2
SSMOKINHOT
obseSSed
SSMOKINHOT's Avatar
Drives: 2010 Camaro 2SS/RS
Originally Posted by jpizzle007 View Post
search my friend. there are threads that already cover this.
Proud to be COTW 12/19/11
My build thread -----> http://www.camaro5.com/forums/showthread.php?t=140034
SSMOKINHOT is offline   Reply With Quote
Old 03-28-2011, 10:43 PM   #3
Cambull11
Cambull11's Avatar
I'm sure there are but i just want a quick answer.
Old 03-28-2011, 10:44 PM   #4
Capthowdy
Capthowdy's Avatar
Drives: 2010 2SS RS IOM
Send a message via Yahoo to Capthowdy
can of worms my friend....I use RP in EVRYthing....
THE "MENACE"
Capthowdy is offline   Reply With Quote
Old 03-28-2011, 11:26 PM   #5
Cbrenthus
Drives: 2011 VR 1SS
Mobil 1 regular, not extended performance
Napa gold oil filter
Don't know your prior oil changing experience, but a good tip is to wear disposable latex gloves. Not only do they help keep your hands clean, but they help prevent burns in that if you get some hot oil on your hand, you can take the glove off quickly
Cbrenthus is offline   Reply With Quote
Old 03-29-2011, 05:10 PM   #6
Cambull11
Cambull11's Avatar
Thanks, cbrent. I don't have time to search so I appreciate the reply
Old 03-29-2011, 10:29 PM   #7
Cbrenthus
Drives: 2011 VR 1SS
No problem, I know what a pain searching these threads can be. I also added a magnet drain plug from advance auto parts with my first change. I'm pretty OCD with my vehicles, and alot of people will argue the different brands of oil, but I've always used mobil 1 exclusively, and it's the factory fill, so why mess with it
Oh, and 5w30 is the weight to use.
Old 03-29-2011, 11:43 PM   #8
Cambull11
Cambull11's Avatar
ok sweet, whats the magnet drain plug for? Im only 22 and not this is a big step up from my Chrysler crossfire i had.
Old 03-30-2011, 03:19 AM   #9
Cbrenthus
Drives: 2011 VR 1SS
The magnet drain plug collects metal shavings as they pass by in the oil pan. It's not something you absolutely need, but every little bit helps.
What exactly is your oil changing experience? If little, here are some more tips:
Too loose is better than too tight! You are better off leaking some oil than stripping something. For the oil filters, I crank them by hand only, using a clean latex glove which gives me added grip. Sometimes a need a wrench to get them off, though, but rarely. For the drainplug, snug is the best term I can come up with. After the bolt gets tight, I put my hand over the center of the ratchet, not the end of the handle, this gives less torque, and I tighten the bolt that way. Remember, you can always tighten it more if it leaks, but you can't tighten it less if it strips!
Make sure to put some oil on the oil filter gasket
Make sure the oil filter gasket comes off with the old filter.
Go get some rhino ramps 8000lbs. I've been changing my own oil for 15 years with jacks and stands, and only tried the ramps with this car. Wow, that is sooo much easier and I wish somone would have told me years ago!
Once again, let me know what experiance you have changing oil and I'll see what other tips I can think of!
Old 04-04-2011, 12:17 AM   #10
KidCaMaRo48
Drives: 2010 V6/RS summit white
Hey guys.. question I just got my 2010 camaro 1LT RS summit white in june 2010 it's now apr 4 I just got 3,800 miles on it and still haven't changed the oil should I do it now or can I wait until 4k or 4500 miles???
KidCaMaRo48 is offline   Reply With Quote
Old 04-04-2011, 01:43 AM   #11
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Here we go again....
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 04-04-2011, 07:22 AM   #12
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 04-04-2011, 09:46 AM   #13
Cincy10SSRS
Cincy10SSRS's Avatar
Drives: 2010 2SS RS M6
Slightly off topic but how do you "document" changing your oil yourself as far as trying to comply with all warranty requirements?
Cincy10SSRS is offline   Reply With Quote
Old 04-04-2011, 10:08 AM   #14
y2k king
y2k king's Avatar
dates, mileage and fluids receipts. after all these years, i've never needed em.
10/28/2010 got it
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
Car "waking up" after oil change..is this due to the fuse pull? CamaroFemme 5th Gen Camaro SS LS LT General Discussions 6 10-05-2009 04:44 PM
