Old 03-29-2011, 07:55 AM   #1
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
GM "hot" cam and 3 bolt cam sprocket
Does anyone know the difference between these 2 - GM 3 - bolt cam gears ??
3 bolt camshaft timing gear: GM Part# 12586481 - 4X camshaft gear
3 bolt camshaft timing gear: GM Part# 12576407 - 1X camshaft gear
Also, has anyone run the GM LS Hot cam p/n 88958733 ?? In the GM performance parts catalog GM claims a 12% hp and torque increase over the stock LS3 cam.
TIA.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 03-29-2011, 09:43 AM   #2
Jason 98 TA
Drives: Camaro
The 2010 car uses a 4x gear. You might want to talk to sponsors on camshaft options, you can do ALOT better than the hot cam without a doubt. We have camshafts that add 80 flywheel horsepower to a 2010 LS3 car!
Jason 98 TA is offline   Reply With Quote
Old 03-29-2011, 09:59 AM   #3
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
i agree with jason. get a different cam. Texas Speed as some really good cams. ive used there cams over the years and realy like them.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 03-29-2011, 12:29 PM   #4
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
9 HP for the Hotcam
http://www.hotrod.com/techarticles/e...ons/index.html
... actually 9 HP for the hotcam and a GMPP head job (397 before and 406 after).
but .....
then there was the battle of the bumpsticks... http://www.gmhightechperformance.com...son/index.html
where it has the hotcam making 40 HP alone... go figure... granted these were numbers at the crank, but still 2 very different stories.
either way, there are alot of cams out there that make good power.... but I guess the low end torque of the hotcam looks hard to beat. I have been looking for a while but still haven't seen where anyone with a gen 5 Camaro who was running it. I decided on the Lunati grind used in both articles, just waiting for it to arrive
I think you will need the first cam gear that you mentioned (12586481)... "12586481" resulted in alot of hits via the C5 seach function, but the second one came up empty.
Also, there is an ongoing LS9 tensioner (stock in the LS3) vs. LS2 dampener debate too... when changing from the single bolt to the 3 bolt cam gear.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 04-02-2011, 07:04 PM   #5
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
Originally Posted by Stash View Post
Dealer installed LS3 Hot Cam. Tuned on a chassis Dyno by Walls Rod & Customs to 509 rear wheel Hp. Brian Wall told me he could have tuned it to 530 rear wheel Hp. but I would have been in the unsafe zone. With 509 rear wheel Hp. the engine is still in the safe zone. Wall is one of very few tuners out there that GM licence him to right his on programs.The Dyno sheet proofs that. The power of this car, well is awesome. All the electronics in this car still function normally On-Star still monitors the emissions on the engine & I still have full engine warranty less exhaust system.
That dyno is broken if it is saying a GM hot cam is making over 500 wheel. LOL
Ovenmitt is offline   Reply With Quote
Old 04-02-2011, 09:43 PM   #6
Ovenmitt
You can look at the shape of the horsepower curve and tell that the dyno is broken. A GM hotcam will peak around 5300-5500 rpm in an LS3. Bogus dyno.
Old 04-02-2011, 10:03 PM   #7
Ovenmitt
Maybe you should talk to Wall you think you seem to now it all
You sir, simply don't have a clue. Obviously, neither does the tuner. I wouldn't let someone like that tune my tricycle, much less my car.
Old 04-02-2011, 10:17 PM   #8
Ovenmitt
Like I say Wall is one of the few tuners out there that can wright his Owen programs licence's by GM
Just.... no. Please stop. You're making my IQ drop and my brain hurt.
Old 04-03-2011, 01:57 AM   #9
GbrilliantQ
Ąʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
I see those 797's being built everyday. I test the 777 and 795's mostly. So when you drive em, I was the one that flashed its computers and made sure it wouldn't fail in the first 12 hrs...
Yeah its offtopic, but yeah I work at the only place that builds the largest truck in the world.
GbrilliantQ is offline   Reply With Quote
Old 04-03-2011, 04:21 AM   #10
Ovenmitt
Oh By the way I am A Licenced Heavy Duty Diesel Equipment Mechanic I work on 3600-6000 Hp Diesel Engines & the worlds largest mining Equipment in Fort McMurray AB.The Dyno Sheet that I have posted is legit on the LS3 Hot Cam that is installed in my car.So all of you after market motor heads can whip in tears because you guys cant face the facts. Like I have been trying to tell you it all depends on how tuns it. You can't just trow a LS3 Hot Cam in your engine And have some Joe blow say that he can tune it for you on wheel Dyno.You have to do your research. That's like me telling you to tune up a C 175 V20 Cat diesel engine with a common rial fuel system that has 29,000 psi fuel pressure in the common rail, the engine is rated at 6000 Hp. but is detuned to 4000 Hp.now set the fuel injectors & adjust the valves, you probably would not now where to start. I rest my case
Clueless.
Old 04-03-2011, 05:00 AM   #11
Ovenmitt
Your just a young punk that thinks you know it all. YOU have lots to learn punk.
I'll bet your "500 rwhp" GM hotcam car runs 13s all day long.
Old 04-03-2011, 06:05 AM   #12
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
I've seen some dumb op's before but this guy takes the cake. There are more then just one "hot cam" and none of them will make anything close to over 500 rwhp. I don't care if GOD tunes it!
Irnwkrkev is offline   Reply With Quote
Old 04-03-2011, 11:09 AM   #13
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
Dealer installed LS3 Hot Cam. Tuned on a chassis Dyno by Walls Rod & Customs to 509 rear wheel Hp. Brian Wall told me he could have tuned it to 530 rear wheel Hp. but I would have been in the unsafe zone. With 509 rear wheel Hp. the engine is still in the safe zone. Wall is one of very few tuners out there that GM licence him to wright his on programs.The Dyno sheet proofs that. The power of this car, well is awesome. All the electronics in this car still function normally On-Star still monitors the emissions on the engine & I still have full engine warranty less exhaust system.
BlaSSt Off is offline   Reply With Quote
Old 04-03-2011, 11:15 AM   #14
BlaSSt Off
BlaSSt Off's Avatar
Drives: 2SS/RS
It's not the OP that takes the cake. It's Stash that has the super magic most awsomest cam tuner in the whole world that takes the cake. The OP was just asking about the GM "hot cams".
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 12:42 PM
I Know... another VVT cam thread but I could use some advice. bigsquirrel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 03-25-2011 04:27 PM
Shop help please...toe arms cam bolt measurement robsls3 Suspension / Brakes / Chassis 2 03-17-2011 01:16 PM
Camshaft Basics Milk 1027 Wiki 1 12-09-2009 01:00 AM
L99 TVS 1900 + Cam Dyno #'s ARE IN pharmd Forced Induction - V8 35 09-07-2009 05:36 AM
