Old 04-02-2011, 06:24 PM   #1
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Rear Coilover Install Question???
I'm in the middle of installing my Pfadt Coilovers, and the rears are giving me some trouble. The Pfadt instructions say to simply "Press the factory OEM rubber bushing out" of the rear upper strut mount plates. Well, that's much easier said than done. Can anyone who has installed these Coilovers give me some advice on this? Is there any way to do this without taking them to a shop with a hydraulic press? Any help would be greatly appreciated.
blazzin1 is offline   Reply With Quote
Old 04-02-2011, 06:42 PM   #2
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Because of the shape of the bushings (trapezoidal) they are very difficult to get out with conventional means. I used a sawzall and cut from the inside of the ferrule outward. Once in sections it comes out rather easily...
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 04-04-2011, 12:31 AM   #3
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Check out my solution here:
http://www.camaro5.com/forums/showthread.php?t=123818
Retains all your stock parts.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 04-04-2011, 04:28 PM   #4
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Avalnch is absolutely on the right track here. Using a flat piece of wood, and a socket as a drift would be an excellent way to remove that bearing. Cutting is another good method for bearing removal. If you're still having issues a machine shop or really anyone with a press should be able to get it out no problems.
We replace that stock upper bearing with one of our own design because it allows us to ditch the stock upper spring perch and run a standard diameter linear spring. Using these springs is a huge benefit to our advanced track users because it allows for much easier sourcing of different spring rates for different tracks and conditions.
If anyone has questions with bearing removal just let us know!
Old 04-04-2011, 05:18 PM   #5
blazzin1
blazzin1's Avatar
Thanks for all the responses. I brought them to my work and used a mechanical press, and surprisingly, they popped right out. Thanks, now on to the fun stuff!!!
Old 04-06-2011, 05:43 PM   #6
fargomike
The Dude Abides
fargomike's Avatar
Drives: Black 2SS M6
Hey Keith , when you are done you can do mine if you want !
2010 Black 2SS/LS3/M6 Kooks 1 7/8 Ceramic Coated Headers, Borla ATAK CB , JRE Tune , Halltech Yellow Jacket CAI ,VMax Ported TB, PFADT Coilovers,Forgestar CF5's Textured Gunmetal w/Nitto Invo's 275/315 ,Hurst Billet Plus 2 Shifter AAC P13W Plasma LEDw/DRL Harness ,30% Tinting,
fargomike is offline   Reply With Quote
Old 04-06-2011, 07:46 PM   #7
blazzin1
blazzin1's Avatar
Yeah Sure Mike!!! Bring your car over and we can knock it out in an afternoon over a couple beers!!! I have mine installed now, pretty easy job, I just have to go and adjust the rears up some, and the fronts down some, and get an alignment.
Old 04-06-2011, 09:17 PM   #8
fargomike
The Dude Abides
fargomike's Avatar
Thanks Keith ,I am actually doing springs , let you know when they are in! I will bring the beer !
DIY : Install Performance Swaybars in 2010 Camaro Nine Ball Camaro DIY & HOW-TO instructions & discussions 17 09-14-2015 01:36 AM
Rear view camera and LCD mirror install on my vert. SUX2BU Camaro Convertible Forum 62 08-18-2012 07:40 PM
DIY - 2010/11 Camaro AAC LED Side Markers Install with Turn Signals GearHeadPeter Camaro DIY & HOW-TO instructions & discussions 0 03-03-2011 02:30 PM
PFADT rear trailing arm install question bigsquirrel Suspension / Brakes / Chassis 5 12-25-2010 05:28 PM
rear speaker install (pictures) Shadowjack Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 11 11-03-2010 06:44 PM
