![]() Drives: Metalic Silver 2010 Camaro 2SS RS Join Date: Jun 2010
R my Stock L99 ECU readings @ idle in the norm range ?
First off I'm monitoring the ECU with a kiwi Bluetooth adapter and the Torque app on my Evo4g Android phone... I apologize for any naive ?'s I type, I'm just beginning to disect what all this ECU info means and I think I'm starting to wrap my head around it somewhat so I'm ready to dive in deeper ... feel free to take me to school but only after you help me see where my data stands please !! Thanks everyone
![]() Here are my results : @ idle Load: 16.1% Revs: 0532 Air temp: 68.F IAT: 86.F Baro: 100.0 Kpa Intake pressure: 29.0 Kpa MAF: 5.1-6.8 g/s Timing Adv: 10.0 Knock Retard: 14.6 Deg Fuel Trim: Bank 1 (-3.1 +6.0) range Bank 2 (-3.1 +5.9) range Are these results normal for a 2010 L99 ? If not what's off ..... What might be causing it to be off ? My only mod is a K&N filter that sits in the OEM air box. I have 25K miles on the car and its a DD !! I don't like how my fuel trim jumps around , Im under the assumption that this means the O2 sensor is having to correct the MAF sensor, is my MAF sensor maybe bad ...? Talk to me people , my brain is a sponge right now .... ![]() |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
hm ya,, something is wrong with your app,, according to your readings you have more knock retard at idle than your actual timing
fuel trims will jump around,, you have short term and long term fuel trims for bank 1 & 2,, the long term fuel trims are an adjusted average of your short term trims
#3 | |
Ahhhh shit my mistake the timing was fluctuating too! In-between 10.0 and I believe 16.9. I forgot to write down the data for the higher # ... I will post the range for the timing when I get off work in a couple hours. Maybe u can take another look and then and let me know what you think? |
#4 | |
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) | robertway | Camaro DIY & HOW-TO instructions & discussions | 313 | 12-16-2023 06:53 PM |
LS3 Tune Only Results .. Also stock LS3 vs. L99 dyno graph | LPFSTheFett | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 5 | 08-05-2009 07:04 AM |
Camaro L99 American Racing Headers (Catted) system with stock exhaust = +42rwhp | pharmd | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 43 | 07-25-2009 10:01 AM |
Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 01:00 PM |
L99 STOCK dyno video and results | pharmd | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 7 | 06-25-2009 10:05 AM |
