![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
aftermarket wheel torque spec?
I just had a set of American Racing Villian wheels installed and was wondering if the torque spec is the same as OEM? No info on this is available for non-dealers at American Racing or wheel pros website. The shop that installed had no idea so I told them to torque to 120 ft/lbs until I find out. Unless I hear otherwise I will re-torque to 140 per OEM spec as soon as I get about 25 miles on them. Is torque spec usually the same for alloy wheels?
Thanks
Dog Is My Copilot
Drives: 2011 2SS/RS LS3 Join Date: Jun 2009
I believe the torque spec has more to do with the wheel stud than the wheel itself. I would torque to factory specs, but I'm no expert...
Drives: 1-800-428-8355 X4664 Join Date: Sep 2010
Torque em to 140 ft lbs. Those look very nice on your car by the way.
![]() Drives: 2011 Camaro Join Date: Jan 2011
Re Torque after 25 miles
Thanks guys, that's kinda what I thought. Will definitely re torque after 25 miles.
#6 |
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT Join Date: Jun 2006
So the standard wheel torque is 140 ft/lbs? My fourth gen was 100.
Bill |
#7 |
knows 2 facts about ducks
Manual says 140 ft/lb. I use that. Trust me here, you don't want to lose a wheel while going 70
#8 |
1,425 hp / supercharged
Drives: (2020 2SS/M6) (2025 GMC Yukon) Join Date: Oct 2009
He's absolutely correct. The torque specs are a function of the stud, not the wheel.
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1969 & 2016 Camaro SS Join Date: Oct 2008
We should start saying "Manual Specs" and "Factory Specs" to be specific when it comes to the Camaro. The actual factory that builds the Camaro sets them at 100 ft-lbs, even though the owner's manual says 140 ft-lbs. Don't believe me? Anyone that has never loosened a lug nut on their Camaro, grab a torque wrench and set it to 90 ft lbs to see if you can loosen a lug before the wrench clicks. Then set it at 95, 97, 98, 99, 100 etc. to see where it comes off. Just about every Camaro I've tested (and owned) is set at 100 ft-lbs. From the "factory".
Fquick.com/NineBall
#10 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
yeah...and I don't think its a stud function...anyone with race wheels that reads the paperwork will know.
-John S.
#11 |
376 cubic inches of fun
#12 |
#13 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
Installed my Forgestar F14's, so when I took off my stock wheels, the lugs were at 100 ft/lbs. And after reading many threads/posts here on C5 it seems to be a great debate 100vs140.
Well if you have aftermarket wheels, chances are you have non-factory lugs and I don't think they are spec'd to take 140 ft/lbs. I had ruined a wheel stud and lug nut trying to get them to 140. I replaced my rear wheel stud and got everything back together today. All my aftermarket lugs are set to 110 just for good measure, and will recheck after 25 miles. Last edited by nancygrl; 05-03-2011 at 09:26 PM. |
#14 |
![]() ![]() ![]() Drives: BLACK 2SS/RS Join Date: Sep 2009
Im running wheel locks on all studs and torque to 100 ft lbs......been doing so for almost two years with no issues and they have never loosened.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
| Recommended Tire Sizes for 2010 Camaro | Nine Ball | Wheels and Tires Talk Sponsored by The Tire Rack | 367 | 04-23-2024 12:22 PM |
| Thinking About Swappin' Gears? Here are the numbers! | Apex Motorsports | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 32 | 04-24-2017 03:12 AM |
| OFFSET and BACKSPACING EXPLAINED | Sir Nuke | Wheels and Tires Talk Sponsored by The Tire Rack | 89 | 11-18-2016 07:41 PM |
| Should aftermarket wheels be torqued to stock wheel specs? | jsharp | Wheels and Tires Talk Sponsored by The Tire Rack | 16 | 06-27-2011 01:33 PM |
| Do Steering Wheel Controls Work with Aftermarket Headunits??? | ZaBeast07 | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 11-10-2010 12:08 PM |
