Old 04-04-2011, 06:54 PM   #1
reedster20
Drives: 2010 Camaro 2SS/RS LS3
tow truck ride again
just now had the wrecker service pick up my car to haul to the dealer. leaky transmission lines. not just a drip either.
i had just got home from the bank and could smell what seemed to be gear oil. so i lay down in the driveway and see fluid completely covering the undercarriage! it started at the cooler lines by the radiator all the way to the rear valance!
i couldnt pinpoint the starting point until i jacked up the car,put it on jackstands and started the engine. thats when i could see a large stream coming out of the connection where the metal line is crimped onto the rubber hose.
after further inspection the line looked bent and the routing looked awkward. im thinking when my car was involded in a front end collision last year this "bent" hose was not replaced and has now caused a failure.
i will be talking with the dealership tomorrow morning to find out they will handle it.
reedster20 is offline   Reply With Quote
Old 04-04-2011, 07:00 PM   #2
the Kolektor
Patiently waiting....
the Kolektor's Avatar
Drives: 2007 Jeep Wrangler Sahara
That sucks, hope it's aneasy and quick repair.
You Know......Sometimes you just can't fix stupid!!!!
the Kolektor is offline   Reply With Quote
Old 04-04-2011, 07:04 PM   #3
chadman
Drives: 2011 2SS
There is a service bulletin for a leaky radiator fitting, but I think it was a connection going to the block. I had to have it fixed on my car.
Chad
2011 Camaro 2SS
Edelbrock Super Charger
chadman is offline   Reply With Quote
Old 04-04-2011, 07:12 PM   #4
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
Did you have a chance to look at your transmission oil temp. You might not have had enough oil in it to get a reading.
2010 2SS/RS, Black/Black, LS-3, delivered 6/19/09
Hoss is offline   Reply With Quote
Old 04-04-2011, 07:26 PM   #5
boltmark
Drives: 2010 2 SS/RS IOM Camaro
Hey I got a question. Someone ask me the other day how to tow one of these things? Or how to even get the SS on a flat bed without damaging the front end. How did they do this?
Thanks
boltmark is offline   Reply With Quote
Old 04-04-2011, 07:38 PM   #6
GreenMonster
Its all about the U
GreenMonster's Avatar
Drives: 2010 SGM
sucks hope you get her back soon
GreenMonster is offline   Reply With Quote
Old 04-04-2011, 08:13 PM   #7
reedster20
temp was almost 180. when i back tracked the drive in my truck, the trip odometer measured 2.5 miles from where i first could see the fluid trail in the road until i got to my driveway.
Old 04-04-2011, 08:17 PM   #8
reedster20
Thanks
we just stuck some 1x6's behind the front tires when the nose started to get close to the ground as he winched it up the flatbed
Old 04-04-2011, 08:30 PM   #9
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
Thanks
You have them put the car on backwards....
DevilsReject97 is offline   Reply With Quote
Old 04-04-2011, 08:52 PM   #10
reedster20
even putting it on backwards the nose of the car still gets to close to the ground. the bed is at a slope therefore as the car is being winched up, the front of the car gets lower the farther up the flatbed it goes.
Old 04-04-2011, 09:05 PM   #11
20Camaro11
20Camaro11's Avatar
Drives: SS
I had a car leak Tranny fluid at the Crimped connectin between the rubber hose and steel line into the radiator cooler. It was a $8 fix. Used a pipe cutter to cut the metal pipe. Then attached a longer hose to account for the shorter pipe. Double clamped the hose around the pipe. Drove it for two years that way with no leak. It was leaking at the compression fitting.
20Camaro11 is offline   Reply With Quote
Old 04-04-2011, 10:25 PM   #12
reedster20
good fix but im not gonna jimmy rig a $36000 car that still has warranty
Old 04-05-2011, 06:50 PM   #13
20Camaro11
20Camaro11's Avatar
Drives: SS
Obviously if the car is under warranty, I would have it fixed proper. This particular line is a low pressure line, it really didn't have too much risk attached to it with my jimmy rigged fix.
Old 04-05-2011, 07:14 PM   #14
dragon22
Drives: 2010 Camaro 2SS/RS SIM
Thanks
If you have a deck truck with a "beaver tail" deck, the nose does not contact the deck going on or off. With a regular deck, they just have to ramp it to keep the nose from contacting.
The biggest problem with pulling them onto a deck is there are very few options for hooking on the bridle that attaches to the winch line.
Using the strap type bridle vs. the chain bridle, lessens the chance of paint damage underneath the front fascia.
If the deck driver is caring enough, there will be no damage to the underside of the fascia when he/she is done.
Deck truck operators do not like to winch a vehicle onto the deck backwards unless there is no other option. They want the heavy part of the vehicle facing the front of the deck.
dragon22 is offline   Reply With Quote
GM Unveils Chevrolet Colorado Show Truck FenwickHockey65 General Automotive + Other Cars Discussion 59 07-01-2011 08:04 PM
Winter ride costs me-- BIG!! SILVERHAWK 5th Gen Camaro SS LS LT General Discussions 50 01-01-2011 11:39 AM
My Worst 24 Hours Ever Ryguy 5th Gen Camaro SS LS LT General Discussions 51 10-16-2009 09:27 PM
How many are moving from a truck or SUV? rforbes 5th Gen Camaro SS LS LT General Discussions 68 07-10-2009 09:31 AM
Silverado 2007 Truck Of The Year KILLER74Z28 General Automotive + Other Cars Discussion 1 12-21-2006 01:59 AM
