![]() Drives: 1LT RS Join Date: Mar 2011
Seat Belt Chime
Can anyone tell me the code to shut off the seat belt chime and dash seatbelt warning light in the 2011
camaro.The manual does not have any info on this. |
knows 2 facts about ducks
You go into vehicle settings in the configurations menu on the radio.
Or do you mean the chiming that happens if you aren't buckled? Because there is no way to turn that off. |
36.58625, -121.7568
Wear your seat belt! Wear it! Wear it! JUST WEAR THE DANG SEAT BELT! Please Just wear it!
It was the chime when you are driving and the seat belt is not fastened. I see that it cannot be shut off.
Thanks |
#5 | |
![]() Drives: blk 2011 LS Join Date: Mar 2011
no code but i know of a very simple, two step procedure that will cancel the chime, everytime! here's what you need to do..... enter your vehicle as you normally would. now, while sitting in the drivers seat and facing foward, take your right hand and reach up and over your left shoulder. grab that strap-like device and pull out and down. look for a shiny metal tab on the end of it. it should be fairly easy to find. now look by your right thigh and you will see an object jutting up between the seat and center console. you'll notice an elongated slit running across the top. insert the metal tab into this slit and push it in till you here an audible "click". if done correctly the chime should now be off. |
#6 |
Virologist in the making
Drives: 2010 VR SS/RS LS3 Join Date: Aug 2009
Great...
6000, Delivered to the customer - 12/21/09 ![]() |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS IOM L99 Join Date: Jan 2010
if you don't wear a seat belt,just attach it behind your back.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro 2SS/RS Join Date: Jul 2010
You need to plug an old Nintendo controller into the car's computer, then very carefully enter the following code:
#9 |
![]() Drives: just a car Join Date: Aug 2010
#10 |
ace5.org
lmao
Stock...For Now.
#11 |
![]() Drives: 2011 Red Jewel Camaro 2SS Join Date: Apr 2011
Dissable seat belt ding
I KNOW, WHERE YOUR SEAT BELT.
Can anyone tell me how to dissable the seat belt bell for my 2011 2SS? Usually the owners manual tells you how to do this, but not in this case. Thanks |
#12 |
![]() ![]() Drives: 2010 Camaro SS Join Date: Apr 2009
I'm happy you know where your seat belt is, you should WEAR it tho. You cannot disable the dong, most new cars have this, at least our cars only do it once and then it stops.
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
#13 |
I'm not totally useless..
There are ways, I don't condone them at all. Think about it for a sec and it will come to you...
#14 |
![]() Drives: RS (11/15/10) Join Date: Mar 2010
The same ding drives me crazy, but not because of my seatbelt .Its because i always drive around with my halos on and when my car door is opem it constantly beeps
TEAM LLT
Nov.15th 2010 -- Check out my build thread http://www.camaro5.com/forums/showthread.php?t=116235 |
| baby/car seat question | kellertxgen5 | 5th Gen Camaro SS LS LT General Discussions | 41 | 10-26-2014 05:55 PM |
| KB 2.8LC (black/polished) from Santa aka TPE | sting808 | Forced Induction - V8 | 50 | 02-17-2011 02:16 PM |
| DIY 3rd Seat belt, rear seat mod | overhaulengines | Camaro DIY & HOW-TO instructions & discussions | 12 | 01-11-2011 06:45 PM |
| Seat Belt Creaking / Squeaking? | Giaquinto1989 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 1 | 09-21-2010 06:07 PM |
| TBS on Belt Noise | venice17517 | Forced Induction - V6 | 1 | 01-29-2010 08:51 AM |
